eatstoomuchjam Posted August 17 Share Posted August 17 13 minutes ago, Ilkka Nissila said: The hand grip of the Z6 III is not just a grip, it houses the battery which is in a different orientation in the ZR I understand that the grip of the Z6 III holds the battery. Judging by pictures, it also holds the memory cards - which includes a UHS-2 full-size SD card instead of a UHS-1 micro-SD card like the ZR has. Oh, and you can also change the cards while the camera is on a tripod or gimbal. 13 minutes ago, Ilkka Nissila said: EVF use on mirrorless cameras is often not practical as it's fundamentally incompatible with gimbal use, I had no idea that mirrorless cameras couldn't be used without a gimbal. That's quite a limitation. Without being aware of it, I've been using mine mostly without a gimbal for a while now. 14 minutes ago, Ilkka Nissila said: many shotgun mics like the MKE 600 would not make it possible for me to use a viewfinder. You know the microphone is supposed to point toward the front of the camera and not the back, right? That should reduce the risk of poking out your eye with it when holding up the EVF. 😉 Anyway, the Z6 III has a screen that is still pretty decent-sized at 3.2". 15 minutes ago, Ilkka Nissila said: Why is the size of the LCD important? I want to clearly see what I am shooting without touching the camera (potentially shaking it). From your description, it sounds like your needs could be better met by using a Black Magic Cinema Camera 6K instead of a Nikon ZR. The BMCC has a bigger rear screen at 5". The EVF is optional so you won't need to use it if you don't want to. While L mount isn't quite as versatile as Z mount, it's still quite good. The BMCC6K also has 2 mini-XLR mic inputs which can be used along with the internal mics for 4-channel audio. If you want smaller files, you can increase the compression ratio for BM raw. Even at the maximum compression on the UC12K (12:1, I think?), it still looks very good. I usually use the Ursa at 8:1 except for VFX shots where I go up to 5:1. The main limitation against the ZR is that the BMCC is a bit bigger and heavier. But as a person who wants "the best back LCD I can have," the BMCC blows the ZR and its puny 4" screen out of the water. You'll also get a full-size HDMI port and not a garbage micro-HDMI port in case you want to connect to an even bigger 7" screen. ArashM 1 Link to comment Share on other sites More sharing options...
Jahleh Posted August 17 Share Posted August 17 Having detachable EVF as good as Z6iii has would be even better than having only the ZR display. Still the 4” display is joy to use, and regular 3” or 3.2” LCD’s feel quite tiny after using ZR. The main problem is still the lack of saving trimmed R3D NE files as R3D NE. If you shoot from sticks and put the camera far away you end up getting a lot of unwanted data you can’t get rid of. Unless you save the R3D NE trims to H.265. Shame on Nikon and RED as NRaw works fine. Luckily you can use Parallax monitor app to control the ZR, Z6iii, Z8 and it has pretty good exposure tools too, false color, red traffic lights, scopes, zebras, and even focus peaking with LUT, frame guides, desqueeze, just to name a few of the features. ZR could be so much better if saving R3D NE trim was fixed. The file size itself is not that big of an issue itself. After shooting almost two hundred days with ZR the R3D NE looks a bit better and needs less grading than NRaw, especially in low light. Link to comment Share on other sites More sharing options...
MrSMW Posted August 18 Share Posted August 18 10 hours ago, eatstoomuchjam said: The BMCC has a bigger rear screen at 5" I dream of having a tool of this magnitude. Being serious, as someone who really does not want to rig out his cameras as after all, I am a hybrid shooter, the larger, clearer and brighter the rear LCD is, the better because I shoot exclusively with the things. It’s also why I prefer a tilt over a flip out. Fully articulated works better for me for the stills side, but tilt for video. Hopefully all cameras in the future will increasingly work on having these physical features which probably benefit more folks than massive pixel counts or bloated codecs. 10 hours ago, Jahleh said: ZR could be so much better if saving R3D NE trim was fixed. The file size itself is not that big of an issue itself. After shooting almost two hundred days with ZR the R3D NE looks a bit better and needs less grading than NRaw, especially in low light Less grading is financial boon to the small business as time saved is time that can be put to use elsewhere, or increase profitability. That is what draws me to the Red codec, but as things stand, that storage costs defeats any savings for me, but the grading time is a draw… ArashM 1 Link to comment Share on other sites More sharing options...
eatstoomuchjam Posted August 18 Share Posted August 18 6 hours ago, MrSMW said: Being serious, as someone who really does not want to rig out his cameras as after all, I am a hybrid shooter, the larger, clearer and brighter the rear LCD is, the better because I shoot exclusively with the things. Yeah, a big screen is nicer. No doubt about it. It just wouldn't be, for me, the main selling point of one camera vs another. That said, you are already in L mount and I've heard that the recently-released autofocus on the BMCC is quite good... Link to comment Share on other sites More sharing options...
Emanuel Posted August 27 Share Posted August 27 https://www.eisa-awards.org/awards/nikon-zr/ Interesting to see the Nikon ZR taking EISA’s Photo/Video Camera 2026–2027 award. On paper, I can understand it. The overall package is unusually strong, particularly for the money, and Nikon has clearly managed to turn the RED acquisition into something rather more tangible than a logo on the box. Still, awards like this always make me wonder what is actually being judged. A camera can be outstanding as a specification sheet, and even as an overall product, while still having one or two behaviours that matter disproportionately once you start using it seriously (codec implementation, processing, noise reduction, workflow, etc.). That does not necessarily make the award wrong. It just shows how different “best camera” can look depending on whether you are judging features, image quality, value, or the less glamorous realities of actually shooting and finishing a project with it. The ZR may well deserve the trophy. I'm rather more interested in whether Nikon keeps refining the bits that do not fit quite so neatly on the award plaque ; ) That said, kudos to ZR! EAG :- ) mercer 1 Link to comment Share on other sites More sharing options...
Ilkka Nissila Posted August 27 Share Posted August 27 On 8/17/2026 at 10:28 PM, eatstoomuchjam said: I understand that the grip of the Z6 III holds the battery. Judging by pictures, it also holds the memory cards - which includes a UHS-2 full-size SD card instead of a UHS-1 micro-SD card like the ZR has. Oh, and you can also change the cards while the camera is on a tripod or gimbal. I had no idea that mirrorless cameras couldn't be used without a gimbal. That's quite a limitation. Without being aware of it, I've been using mine mostly without a gimbal for a while now. You know the microphone is supposed to point toward the front of the camera and not the back, right? That should reduce the risk of poking out your eye with it when holding up the EVF. 😉 Anyway, the Z6 III has a screen that is still pretty decent-sized at 3.2". From your description, it sounds like your needs could be better met by using a Black Magic Cinema Camera 6K instead of a Nikon ZR. The BMCC has a bigger rear screen at 5". The EVF is optional so you won't need to use it if you don't want to. While L mount isn't quite as versatile as Z mount, it's still quite good. The BMCC6K also has 2 mini-XLR mic inputs which can be used along with the internal mics for 4-channel audio. If you want smaller files, you can increase the compression ratio for BM raw. Even at the maximum compression on the UC12K (12:1, I think?), it still looks very good. I usually use the Ursa at 8:1 except for VFX shots where I go up to 5:1. The main limitation against the ZR is that the BMCC is a bit bigger and heavier. But as a person who wants "the best back LCD I can have," the BMCC blows the ZR and its puny 4" screen out of the water. You'll also get a full-size HDMI port and not a garbage micro-HDMI port in case you want to connect to an even bigger 7" screen. The ZR does allow the main card and battery to be replaced without taking the camera off the tripod provided that the plate or rig is designed right for the camera and a suitable head is used. Yes, the micro slot is unfortunate. But for video, no Nikon camera has dual card recording anyway, so the main card is where it's at. The orientation of the battery and main card along the width of the body makes the body a bit wider than it could have been if there had been a larger grip, but if optimizing for the fraction the LCD takes up of the camera's back side surface, this design is understandable. The MKE 600 shotgun microphone is 25 cm long and with the supplied cold shoe foot, its rear end extends quite a bit behind the camera, like with many longer shotgun mics it blocks comfortable access to the viewfinder. Longer shotguns give better side rejection and can sound less distorted but because they are long and mirrorless cameras tend to be short, there is a bit of a compatibility issue which does not exist with professional camcorders that are long enough to accommodate these mics without interfering with the picture or the shooter's forehead. However, camcorders typically give lower image quality at wide angle focal lengths which are a priority for me for many situations where I want the camera to be close to the subjects. My desire for a larger screen is not without limitations, the camera must be small and light enough to comfortably use on a gimbal (for potentially long shoots), for those situations where I do want to use one. Of course, one can use a camera without a gimbal, but I have situations where it is useful and a priority. A BMCC would make the gimbal setup too heavy. I have Nikon lenses so it makes economic sense for me to use Nikon camera bodies as well, and get lens corrections automatically applied to the video footage. Yes, 3.2" is usable but 4" would be better. I find particularly for manual focusing a larger screen would be better. I already have the Z8 which has a full-sized HDMI, though it has no XLR connections. I imagine Nikon would within the next few years make a higher-end video-first model that would sit between the ZR and the Komodo, and be more head-to-head competitor with the FX5. The ZR is just one camera in presumably a lineup that Nikon have yet to make. Why do I want to use a gimbal with a mirrorless camera? Let's say I am shooting a parade with music and performances moving across the streets. I need wide angle (because subjects can be tall) with keystoning controlled, and since there is no guarantee that a fixed spot along the way will give me the best moments, a tripod is not ideal. The gimbal keeps keystoning from appearing (with a suitable lens and appropriate mode), and keeps the camera level while I'm moving. The drawback is that I need a separate sound person - which is a big drawback. Link to comment Share on other sites More sharing options...
Super Members BTM_Pix Posted September 8 Super Members Share Posted September 8 Nikon have announced an interesting firmware update for 2027. Could be a confidence that’s announcing this three days before IBC or maybe someone else is announcing a competing camera there that Nikon need to get ahead of. Either way, it looks like a great update for existing users. Full details here https://www.nikon.com/company/news/2026/0908_01/ jbCinC_12 1 Link to comment Share on other sites More sharing options...
PPNS Posted September 8 Share Posted September 8 If the h265 is still 4:2:0, of what use is this slightly different log profile? zerocool22 1 Link to comment Share on other sites More sharing options...
Ilkka Nissila Posted September 8 Share Posted September 8 3 hours ago, PPNS said: If the h265 is still 4:2:0, of what use is this slightly different log profile? Presumably it is so that the footage from the ZR can be more easily color graded by those who are familiar with RED footage, and the material from the ZR can be mixed with that from RED cameras with easier and better color compatibility. Nikon's issue is that the video from its hybrid cameras (especially in SDR mode) is designed to color match with the stills from Nikon cameras and cinema people have their own preferences that differ from that of the stills world. Nikon has been gradually adding features to make it easier to make the footage look similar to that of RED cameras, and this is another step in that process. Personally I like the SDR colors from Nikon cameras in video as they are so familiar to me as a stills shooter, and if I want to present video and stills from an event, they match by default. I appreciate that for video there are reasons to use log formats for encoding the data in a more efficient way to get a wider range of tones and colors recorded while keeping file sizes in check, and this encoding can vary from camera brand to camera brand, making mixing the footage across brands to a cohesive whole more challenging. The 4:2:0 vs. 4:2:2 has to do with how the colors of adjacent pixels are encoded to save space, I don't necessarily see how this would affect the overall "look" or dynamic range of the footage, which the log profile might affect. Nikon does support 4:2:2 in Prores in the ZR. I would assume the RED Log profile would likely be available for Prores files as well, after suitable firmware updates have been made available. ArashM 1 Link to comment Share on other sites More sharing options...
Emanuel Posted September 8 Share Posted September 8 13 hours ago, BTM_Pix said: Nikon have announced an interesting firmware update for 2027. Could be a confidence that’s announcing this three days before IBC or maybe someone else is announcing a competing camera there that Nikon need to get ahead of. Either way, it looks like a great update for existing users. Full details here https://www.nikon.com/company/news/2026/0908_01/ Yeah, you beat me on that one... Same link to post, thanks anyway, glad you did it : ) For existing and some others to come as soon as they'll address the complaints : X These are very promising news, I guess I'll have to buy one this time, thanks to this, so you see how much this matters to many of us ; ) Exciting announcement... BTW one of my fav cams today, mid to late 2026 (EAG :- ) Link to comment Share on other sites More sharing options...
jbCinC_12 Posted September 8 Share Posted September 8 Yes, I heard it just today. Saw Mr. Talbot's info on it and Nikon's press release. It is such good news; I still love mine - firmware or no firmware. Now, hopefully the folks who were antsy about a FW release will breathe a sigh of relief - well... hopefully. 🤞 Link to comment Share on other sites More sharing options...
Ilkka Nissila Posted September 9 Share Posted September 9 13 hours ago, jbCinC_12 said: Yes, I heard it just today. Saw Mr. Talbot's info on it and Nikon's press release. It is such good news; I still love mine - firmware or no firmware. Now, hopefully the folks who were antsy about a FW release will breathe a sigh of relief - well... hopefully. 🤞 The problem is that people online gather to complain (if they are happy they are usually silent), and the more appealing the price is, the more they seem to want to be sure they are getting their money's worth, assuming that every missing feature is an attempt to scam them of their money. The ZR price puts it into the radar of bargain hunters who have this mindset. I'm confident enough that Nikon will improve h.265 log footage adequately to make it satisfying to use for those situations where RAW or Prores footage takes up too much space. It might not be the best h.265 nor does it have to be, given the price of the camera, but it shouldn't be noticeably soft, either. I also hope the Prores LT codec comes soon, and that the noise reduction can be adjusted when using Prores HQ and LT formats. jbCinC_12 1 Link to comment Share on other sites More sharing options...
MrSMW Posted September 9 Share Posted September 9 I wonder if it will ever get the 'Red-lite' raw codec 'everyone' wants... If that ever happens, what a fucking camera it would be. Emanuel and eatstoomuchjam 2 Link to comment Share on other sites More sharing options...
HockeyFan12 Posted September 9 Share Posted September 9 How bad is the dynamic range on this camera? Particularly the highlights? (I tend to just rate at base ISO and shoot traditionally rather than ETTR.) I was hoping Red's highlight recovery (which isn't that great imo as you lose all color information) would help, but it seems to be disabled in RedCineX? I had sworn off new cameras but I sold my old ones and might need something for work. mercer 1 Link to comment Share on other sites More sharing options...
Jahleh Posted September 17 Share Posted September 17 Nothing wrong with ZR dynamic range IMO, and highlights look good too. With NRaw ETTR just below clipping point is needed, but with R3D NE exposing correctly by false color works well. Just get Cinematools false color LUT to ZR, make your own in Resolve or use Parallax Monitor app. The ZR is no pocket 4P with DLog2 DR wise, but pocket 4P IQ still does not look even closely as nice as ZR, and guess which one breakes sooner in very low light. The pocket 4P IQ as a gimbal camera is still nice step up from earlier oversharpened stuff and does not look bad when mixed with raw shot with ZR and Z6iii. Have not used RedCineX much after discovering it does not support R3D NE trim save either. HockeyFan12 and kye 2 Link to comment Share on other sites More sharing options...
Jahleh Posted September 18 Share Posted September 18 It seems RED SDK beta 9.3.0 released in 9th of September has this line: Added: trim support for R3D NE. Hopefully it’s not long until both Resolve and RedCineX Pro include this SDK🙂 HockeyFan12 and eatstoomuchjam 2 Link to comment Share on other sites More sharing options...
floydvulture99 Posted September 19 Share Posted September 19 Jahleh said: It seems RED SDK beta 9.3.0 released on the 9th of September has this line: Added: trim support for R3D NE. That sounds promising, especially if the support is already present at SDK level. Hopefully it means the remaining wait is mostly down to when Resolve and RedCineX Pro integrate the updated SDK rather than RED still having more work to do on the feature itself. took long enough for trim to land, my drives are gonna be way happier once resolve actually picks it up. Jahleh 1 Link to comment Share on other sites More sharing options...
greycondor95 Posted September 19 Share Posted September 19 Jahleh said: It seems RED SDK beta 9.3.0 released in 9th of September has this line: Added: trim support for R3D NE. Hopefully it’s not long until both Resolve and RedCineX Pro include this SDK🙂 Trim support for NE finally landing in the SDK is nice, been waiting on that one. Now it just has to actually show up in Resolve, those updates always seem to take forever lol. Jahleh 1 Link to comment Share on other sites More sharing options...
stephen Posted October 5 Share Posted October 5 On 8/17/2026 at 10:42 PM, Jahleh said: Luckily you can use Parallax monitor app to control the ZR, Z6iii, Z8 and it has pretty good exposure tools too, false color, red traffic lights, scopes, zebras, and even focus peaking with LUT, frame guides, desqueeze, just to name a few of the features. ZR ctl or Paralax Monitor is great. Interface is good and allows to change practically any major video related setting. For somebody like me who is not familiar with Nikon menus it is a great help. Connectivity with the camera is breeze too. Just plug the USB cable. It solves also another problem which Z6 III has - lack of LUT support. It is important for me as I use LUTs to set exposure. Using a LUT is by far the best and easiest way to set exposure for video and also save lots of time in post. Kudos to the creator. On 8/16/2026 at 2:15 PM, Emanuel said: The Samyang V-AF 24mm has already been shown working with AF on the ZR through the Megadap ETZ21 Pro+, so at least part of that E-mount investment could potentially follow you across. Megadap ETZ21 Pro+ is the first adapter that I know which allows you to stack electronically two adapters ! Any A-Mount Lens + LA-EA5 + Megadap ETZ21 Pro+ can autofocus on Nikon Z bodies. Same with Canon EF lenses and Metabone adapter + Megadap ETZ21 Pro+. Almost any Sony or third party lens for Sony E mount works (can autofocus) with Megadap ETZ21 Pro+ on Nikon Z bodies. Practically I can use all the lenses that I use on Sony. Of course there will be some penalty with continuous autofocus but I rarely use it anyway. Nikon Z mount cameras have some quirks too. For example they lack the third wheel that most mirrorless camera have. You need to push and hold a button and keep it pushed while changing ISO. Assuming that for video we lock the shutter at 2x frame rate, 2 wheels will do the job. Nikon however don't give the option to assign ISO on some of the wheels. You can only switch them - one for shutter and one for aperture and vice versa. I bought Nikon Z6 III instead of Zr. Z6 III has full size HDMI and great EVF plus a physical shutter for photos. Flip out screen being small or big is not that useful for me. A monitor or smartphone that serves as a monitor and sits on top of the camera and slightly in front is much better. Price second had is now around 1600/1500 E mark. Low enough to get it and scratch this internal RAW view itch 🙂 Jahleh 1 Link to comment Share on other sites More sharing options...
Jahleh Posted October 5 Share Posted October 5 On 9/19/2026 at 11:04 AM, floydvulture99 said: took long enough for trim to land, my drives are gonna be way happier once resolve actually picks it up. Latest RedCinex Pro beta has the R3D NE trim and it works! Just open the clip in RedCinex Pro, set IN and OUT points in viewer, select export, export Clip in viewer, Format R3D Trim, check output location and export. Not like Resolve but not hard either. Already trimmed one almost full 4TB 990 Pro to few hundred GBs of important data🙂 Link to comment Share on other sites More sharing options...
