Administrators Andrew - EOSHD Posted May 21 Administrators Share Posted May 21 https://www.wexphotovideo.com/panasonic-lumix-s9-digital-camera-body-with-20-60mm-f3-5-5-6-lens-black-3170471/ £800 off. Which makes it £999 with the 20-60mm kit lens. The body only is down to as little as £750 open box mint used. Down from the RRP of a few months ago £1600. One can only assume they are having massive problems shifting them. Which is a pity because the S9 is a fun little beast. eatstoomuchjam and John Matthews 2 Link to comment Share on other sites More sharing options...
eatstoomuchjam Posted May 22 Share Posted May 22 The discounts don't seem to have come to the US, at least not yet. Used bodies are still about $1,200 here and new is still about $1,400 body-only. Link to comment Share on other sites More sharing options...
Thpriest Posted May 22 Share Posted May 22 I don't see the S9 discounts in Spain but the new S1ii packs are out: 3.850,52 € for the S1ii and the 24-60 2.8. That looks a reasonable offer. Andrew - EOSHD 1 Link to comment Share on other sites More sharing options...
ac6000cw Posted May 22 Share Posted May 22 8 hours ago, Andrew Reid said: https://www.wexphotovideo.com/panasonic-lumix-s9-digital-camera-body-with-20-60mm-f3-5-5-6-lens-black-3170471/ £800 off. Which makes it £999 with the 20-60mm kit lens. The body only is down to as little as £750 open box mint used. Down from the RRP of a few months ago £1600. One can only assume they are having massive problems shifting them. Which is a pity because the S9 is a fun little beast. The first stage of large S9 price drops in the UK started in February - I bought an S9 as soon as it happened, as I'd been interested in getting one for a while. In my case it was a red S9 + 18-40mm kit for around £1100 in 'like new' condition. With further price drops about a month ago that kit is now about £1200 new. I quite like it - nice solid-feeling body, decent battery life and with the 18-40mm a fairly compact kit (for a full-frame camera). Not quite a modern GX80, but close enough for most of my use cases. My main criticism is probably that, for a camera presumably aimed at new/inexperienced users, there's too much of the higher-end video stuff cluttering up the menus with options and choices they probably won't understand or ever use. Sure, you can use filtering, My List, customise the 'quick' menu and set up custom mode dial presets to simplify things - but you've got to understand what the options mean in order to set those up.... Why not split the video bitrate/fps/frame size/codec options into 'basic' and 'advanced' sets out-of-the box? And when you press the 'record' button in photo mode, default it to shutter priority with 180 degree shutter angle, instead of 'P' mode with variable shutter speed/angle (but that is a historical Panasonic issue/feature going back many years - at least the 'flicker decrease' workaround for it is still in the menus). Link to comment Share on other sites More sharing options...
MrSMW Posted May 22 Share Posted May 22 I bought mine at whatever was the launch price, used it once, liked it, but decided I was better off with a 3rd S5ii, so returned for a refund. I then decided over the Winter, I’d actually prefer one over that 3rd S5ii, so bought one back. Happy with that decision plus a trio of f1.8 primes which make for a really capable compact kit. Yes the S5ii is a ‘better’ bit of kit, but it’s not better for my needs. Probably overpriced at launch. John Matthews 1 Link to comment Share on other sites More sharing options...
Administrators Andrew - EOSHD Posted May 22 Author Administrators Share Posted May 22 It's a mark of how far fucked Panasonic are, in that the S9 is now going for Lumix GM5 prices on eBay. https://www.ebay.co.uk/itm/177072111627 2x crop 2015 camera, 10 years old. Vs the 2024 full frame camera they wanted all of Instagram to buy. The last time I saw depreciation like this was with Samsung! Link to comment Share on other sites More sharing options...
Super Members BTM_Pix Posted May 22 Super Members Share Posted May 22 1 hour ago, MrSMW said: Probably overpriced at launch And underlensed. And overbrod with the wrong type of shills. Marketing/timing’s loss is our gain now at those prices, particularly with the 18-40mm lens. The Hybrid Zoom function they introduced with the S9 and now have on the S5ii etc makes it an 18-62mm in 4K and 18-125mm in HD. This cheap HDMI powered EVF that popped up on here recently might also be a good “in the pocket in case” pairing. Andrew - EOSHD 1 Link to comment Share on other sites More sharing options...
Thpriest Posted May 22 Share Posted May 22 7 hours ago, Thpriest said: I don't see the S9 discounts in Spain but the new S1ii packs are out: 3.850,52 € for the S1ii and the 24-60 2.8. That looks a reasonable offer. When comparing to an FX3 for example, which is 4.482,18 €. Hopefully by spring the combo will be around 3500€ which is when I might look to buy them. Link to comment Share on other sites More sharing options...
Administrators Andrew - EOSHD Posted May 22 Author Administrators Share Posted May 22 Are you sure 3850 euros is a reasonable offer? You can get a Z8 for that, let alone Z6 III! You could even get a used Sony a1 for about the same, with a low shutter count. 3850 is 3x mint condition Panasonic S1H. It's nuts. eatstoomuchjam 1 Link to comment Share on other sites More sharing options...
Thpriest Posted May 22 Share Posted May 22 Depends on your needs and budget at the end of the day. Of course I'd like it to be cheaper and I think it will be quite soon. Link to comment Share on other sites More sharing options...
ntblowz Posted May 22 Share Posted May 22 3 hours ago, Andrew Reid said: Are you sure 3850 euros is a reasonable offer? You can get a Z8 for that, let alone Z6 III! You could even get a used Sony a1 for about the same, with a low shutter count. 3850 is 3x mint condition Panasonic S1H. It's nuts. That price is with the new 24-60 which is not bad? Non of the other camera you mentioned do OG 60p so for OG users that is quite the moot point. But for general users who don't care about OG they certainly have more choices. Anyway with Panasonic there is always the fire sale after few months to a year, so for S1II I gonna wait for a year to see how much discount I can get. In the mean time I m rocking with S9 and S5II. Got them both cheap after the discount and free lens to boot (free 85mm 1.8 for NZ one) Thpriest and PannySVHS 2 Link to comment Share on other sites More sharing options...
PannySVHS Posted May 23 Share Posted May 23 It's a broken record playing, but it's always playing when I am thinking about the S9. Panny, please give us pancake primes and zooms, a successor with S1 quality Evf, mechanical shutter and hotshoe. Full size hdmi would be nice too. Matt Frazer, can you hear us!:) Link to comment Share on other sites More sharing options...
Marcio Kabke Pinheiro Posted May 27 Share Posted May 27 This one is probably not discounted, but oh boy looks good. https://www.l-rumors.com/panasonic-japan-announced-the-new-titanium-lumix-s9-edition/ Link to comment Share on other sites More sharing options...
ac6000cw Posted May 27 Share Posted May 27 Panasonic is obviously trying to appeal to the more retro/classic/stylish area of the market, like it has in the past with silver/grey and black versions of some M43 cameras. Certainly looks more stylish than the plain black version (my S9 is a black and red version, which is more at the 'fun' end of the market). Link to comment Share on other sites More sharing options...
MrSMW Posted May 27 Share Posted May 27 Depending on price, I might have been interested when I was shopping for my S9 the second time round (first time black, current red) but I wouldn't trade now purely for looks as I bet the financials would work out close to €1000 not in my favour. I do wish however that more companies would launch cameras with more options than just black! For one thing, it soaks up sunlight and therefore heat in the sun/Summer, whereas something metallic like silver or titanium reflect it. The Zf has some nice colour options, particularly the stone grey and their red is much better than Lumix's S9 options which are a bit too bright. Link to comment Share on other sites More sharing options...
John Matthews Posted May 30 Share Posted May 30 The S9 is now getting interesting at recent prices I've seen it for in France- under 1000 euros. I'm contemplating now. I figure the launch price should have been this. All they had to do is not give out so many of them for free to influencers. It only really has 3 or 4 modern lens options and a slew of vintage options, but it might be enough. eatstoomuchjam 1 Link to comment Share on other sites More sharing options...
MrSMW Posted May 30 Share Posted May 30 3 hours ago, John Matthews said: It only really has 3 or 4 modern lens options Depends on your preferences but all of the Sigma f2/2.8 primes, all the Lumix f1.8/2.8 primes, various small zooms including the new 24-60, all very good combos. I prefer the Sigma f2’s for stills and for their build and looks, but I went with the Lumix f1.8 primes for mine with the 18, 50 and 85. I’m now questioning the 18 and might trade it for the 24 as it’s just a bit too wide for my needs and taste. The 35 is not quite wide enough and a bit close to the 50. The 50 has been my workhorse the last few jobs and the one I am currently on, but whether I stay with L Mount for video or flip to Sony (or Nikon) 99% sure I will pick up a Sigma 28-45mm f1.8 because that would suit my needs best. John Matthews 1 Link to comment Share on other sites More sharing options...
John Matthews Posted May 30 Share Posted May 30 1 hour ago, MrSMW said: Depends on your preferences but all of the Sigma f2/2.8 primes, all the Lumix f1.8/2.8 primes, various small zooms including the new 24-60, all very good combos. I prefer the Sigma f2’s for stills and for their build and looks, but I went with the Lumix f1.8 primes for mine with the 18, 50 and 85. I’m now questioning the 18 and might trade it for the 24 as it’s just a bit too wide for my needs and taste. The 35 is not quite wide enough and a bit close to the 50. The 50 has been my workhorse the last few jobs and the one I am currently on, but whether I stay with L Mount for video or flip to Sony (or Nikon) 99% sure I will pick up a Sigma 28-45mm f1.8 because that would suit my needs best. I already have a few of primes you mention. I have the 24 and 50mm, but I fear they might be only for a pinch. I'll probably use the 18-40 for the moment. I'm going to give it go with my Konica lenses too, especially my 40mm f/1.8 and the 50mm f/1.4. Also, I have the 21mm f/2.8 and the 100mm f/2.8; so, plenty of options there. It should arrive tomorrow. Link to comment Share on other sites More sharing options...
ac6000cw Posted May 31 Share Posted May 31 Re. S9 lens options (and being a 'zoom' rather than 'prime' person), now the 24-60 F2.8 is out, the obvious hole in Panasonic's full-frame small/light zoom range is a longer focal length companion to the 18-40 collapsible zoom e.g. a compact 35-90. (Like the 12-32 plus 35-100 pair they introduced to go with the smaller M43 cameras years ago). The current 'reasonably compact' FF zoom range mounted on the S9 (from the left, 18-40, 20-60, 28-200 and 24-60): John Matthews 1 Link to comment Share on other sites More sharing options...
John Matthews Posted May 31 Share Posted May 31 Oh yes. That would be great to have a 60-180mm f/4.5-6.3 with a 62mm filter thread, under 250g. Let's add on that 28mm or 40mm f/2.8 pancake about the same size as the stupid 26mm MF one. The system would then be complete! Link to comment Share on other sites More sharing options...
