Emanuel Posted July 25 Share Posted July 25 @newfoundmass@MrSMWFX30's stabilization is not necessarily bad at all... it requires a proper operator! : P Maybe @kye is serious up there, maybe not ; ) I am :- ) kye 1 Link to comment Share on other sites More sharing options...
MrSMW Posted July 26 Author Share Posted July 26 Never tried it but I suspect the FX30 stab would be good enough for my handheld needs which are basically ‘static’. I move more and more however towards the combo of absolutely locked off or floating moving with nothing in between. Lumix are great in this regard because if you have everything dialled up to the max, albeit at the expense of some cropping, these things stay incredibly still. It’s really only if there is any static foreground that you notice any movement so wider establishing shots, I always use a tripod or something. Emanuel 1 Link to comment Share on other sites More sharing options...
ND64 Posted July 27 Share Posted July 27 On 7/25/2026 at 7:20 PM, Ilkka Nissila said: (1) how to compress the data so that it will be possible to write on CFexpress type A cards, (2) how overheating can be avoided, (3) what kind of compression to apply, and (4) what kind of dynamic range is possible given the sensor read time (dual gain output readout) and high frame rate (240 fps). None of these are unknown for the firmware team that already finished the development. Its not something they need time to discover. Also, when they promise the update in the marketing materials, they're officially admitting they have the solution. Heck they even let Philip Bloom to test it. Link to comment Share on other sites More sharing options...
newfoundmass Posted July 27 Share Posted July 27 On 7/25/2026 at 11:56 AM, Emanuel said: @newfoundmass@MrSMWFX30's stabilization is not necessarily bad at all... it requires a proper operator! : P Maybe @kye is serious up there, maybe not ; ) I am :- ) For fast action sports where you're moving quickly it's just not sufficient from what I've seen. If you're largely standing still I imagine it's sufficient but when you're running around a wrestling ring, not so much. My use case though is admittedly unique. Emanuel and kye 2 Link to comment Share on other sites More sharing options...
Emanuel Posted July 27 Share Posted July 27 10 hours ago, newfoundmass said: For fast action sports where you're moving quickly it's just not sufficient from what I've seen. If you're largely standing still I imagine it's sufficient but when you're running around a wrestling ring, not so much. My use case though is admittedly unique. The lens can also play a relevant role in order to reach the result you intend or need : ) even though, Oly or Panasonic may overcome it indeed :- ) Link to comment Share on other sites More sharing options...
newfoundmass Posted July 27 Share Posted July 27 4 hours ago, Emanuel said: The lens can also play a relevant role in order to each the result you intend or need : ) even though, Oly or Panasonic may overcome it indeed :- ) No lens is going to help stabilize running enough on any of the current Sony cameras to watch Lumix IBIS unless you use Catalyst Browse which just isn't an efficient option for 3 hour long events. Link to comment Share on other sites More sharing options...
Emanuel Posted July 27 Share Posted July 27 Actually, I was making exactly the opposite point from the one you made it sound as though I was making : D when I mentioned Lumix alongside the Oly case ; ) The other point is simply that one lens isn’t necessarily the same as another ; )) While much also depends on the way the operator handles the camera, a lens with optical stabilisation can make a night-and-day difference... speaking as someone who uses glass with and without it every day on the FX series :- ) newfoundmass 1 Link to comment Share on other sites More sharing options...
kye Posted July 28 Share Posted July 28 On 7/27/2026 at 4:19 PM, newfoundmass said: For fast action sports where you're moving quickly it's just not sufficient from what I've seen. If you're largely standing still I imagine it's sufficient but when you're running around a wrestling ring, not so much. My use case though is admittedly unique. I've filmed a lot while walking, often on uneven ground, and I agree with your assessment. Even using Dual-IS (lens OIS and IBIS) on Panasonic cameras like GH5 / GX85 / GH7 you'd have to be much more ninja-like than I manage to be most of the time. I haven't tried the EIS setting on top of the Dual-IS, but by looking at the footage afterwards, I can tell that I'm not hitting the limits of the stabilisation by only a small amount - it tends to be stable and then jump pretty abruptly. I've filmed with setups that only had OIS or no stabilisation at all and so I appreciate the magic Panasonic is working, but there are limits to everything. I can't imagine what it would be like trying to follow people who are likely to be pretty unpredictable and jumping around etc trying to surprise their opponent. Have you ever used any of the newer breed of action cameras that have the ultra-hyper-giga-maxxed-stabilisation modes? I haven't, but they look basically like magic, stabilising people running and biking etc which is well beyond the OIS / IBIS / EIS territory on normal cameras. It would be fascinating if someone made a normal camera with a mode like that where it takes a large crop into the lens but delivers that kind of stabilisation. I can imagine using a wider prime, like a 16mm or 24mm with that mode to grab shots that are 2x cropped but smooth like butter. Link to comment Share on other sites More sharing options...
newfoundmass Posted July 28 Share Posted July 28 18 hours ago, Emanuel said: Actually, I was making exactly the opposite point from the one you made it sound as though I was making : D when I mentioned Lumix alongside the Oly case ; ) The other point is simply that one lens isn’t necessarily the same as another ; )) While much also depends on the way the operator handles the camera, a lens with optical stabilisation can make a night-and-day difference... speaking as someone who uses glass with and without it every day on the FX series :- ) Sorry if I misread! 1 hour ago, kye said: Have you ever used any of the newer breed of action cameras that have the ultra-hyper-giga-maxxed-stabilisation modes? I haven't, but they look basically like magic, stabilising people running and biking etc which is well beyond the OIS / IBIS / EIS territory on normal cameras. It would be fascinating if someone made a normal camera with a mode like that where it takes a large crop into the lens but delivers that kind of stabilisation. I can imagine using a wider prime, like a 16mm or 24mm with that mode to grab shots that are 2x cropped but smooth like butter. I have! And it's TOO smooth for my tastes. It's very impressive, but I still want some natural handheld movement. It helps with the immersion. It's why I have never used a gimbal for the ringside action. The biggest issue with action cameras, even the new ones, is the low light just isn't great in most of these venues that don't have professional lighting rigs set up. Emanuel and kye 2 Link to comment Share on other sites More sharing options...
Emanuel Posted July 29 Share Posted July 29 On 7/28/2026 at 3:22 PM, newfoundmass said: Sorry if I misread! I have! And it's TOO smooth for my tastes. It's very impressive, but I still want some natural handheld movement. It helps with the immersion. It's why I have never used a gimbal for the ringside action. The biggest issue with action cameras, even the new ones, is the low light just isn't great in most of these venues that don't have professional lighting rigs set up. No worries : ) On a slightly different note, this new generation of pocket cameras, such as the Insta360 Luna Ultra and DJI Pocket 4 Pro, may well point in another direction altogether... They offer impeccable stabilisation ; ) Granted, it is not exactly the handheld look you seem to favour, but that is precisely the kind of character Sony’s less effective IBIS can give you, especially when paired with a lens without optical stabilisation ; )) And very strong low-light performance too: LU1 | LU2 | LU3 | LU4 on a film set | LU5 + LU6 shot in exactly that kind of venue by someone who, like you, says he had never been particularly keen on using pocket or action cameras. Well, until this one came along... & 4P1 | 4P2 | 4P3 There is far less need to worry about professional lighting rigs today. To put it very simply, both have changed the whole game IMHO : )) especially at such an affordable price range nowadays : X What a time to be alive and kickin'! :- ) Link to comment Share on other sites More sharing options...
kye Posted July 29 Share Posted July 29 11 hours ago, newfoundmass said: I have! And it's TOO smooth for my tastes. It's very impressive, but I still want some natural handheld movement. It helps with the immersion. It's why I have never used a gimbal for the ringside action. The biggest issue with action cameras, even the new ones, is the low light just isn't great in most of these venues that don't have professional lighting rigs set up. I agree about it being too smooth, especially because the position of the camera isn't stabilised so there can be huge parallax movement which clashes with there being no movement in the direction of the camera at all. I raised the topic because it would be interesting to see a combination of OIS + IBIS + Super EIS where the EIS smoothes the motion rather than locking the image completely. It's much harder to get the locked stabilisation than just smoothing it and leaving some of the motion in the image, so it's definitely possible to tone it down a lot. Perhaps this topic will be what people are arguing about when the GH10 and FX5 IV and R5 mk 5 are all being released on top of each other, so we've got to leave something on the table for then! Emanuel 1 Link to comment Share on other sites More sharing options...
Administrators Andrew - EOSHD Posted August 7 Administrators Share Posted August 7 Why does nobody talk about the FX2? Much better value for money! Davide DB and ArashM 2 Link to comment Share on other sites More sharing options...
MrSMW Posted August 7 Author Share Posted August 7 48 minutes ago, Andrew - EOSHD said: Why does nobody talk about the FX2? Much better value for money! The Forgotten camera! (I had myself!!) Link to comment Share on other sites More sharing options...
shooter Posted August 7 Share Posted August 7 The FX2 makes a lot more sense than people give it credit for. If you actually need open gate, internal RAW, 4K120 or the stacked sensor, then sure: FX5. If you don't, you're paying nearly another $2K for features you may never use. FX2 gives you full frame, 4K60, S-Log3, proper AF and an EVF already built in. For a lot of jobs that's enough. Different job. Different tool. ArashM 1 Link to comment Share on other sites More sharing options...
Benjamin Hilton Posted August 10 Share Posted August 10 On 8/7/2026 at 9:59 AM, Andrew - EOSHD said: Why does nobody talk about the FX2? Much better value for money! Yeah the FX2 is a great camera. We've come to rely on the A7IV a lot because they are cheap, and just produce a darn good image in almost any situation. Now queue the FX2, basically just a better version of that. I'm probably going to buy a bunch of them here pretty soon for a new studio setup. Link to comment Share on other sites More sharing options...
MrSMW Posted August 12 Author Share Posted August 12 I’m actually seriously considering going over to Sony for stills at least, purely due to the lenses and the FX2 is a contender, but the A7RV more likely. It’s lenses. L Mount still does not have viable contender for: 28-70 f2 50-150 f2 70-180 f2.8 OK, there is the Sigma 28-45 f1.8 and the 28-105 f2.8 but the pairing of Sony’s 28-70 for mainly indoor work and their 50-150 for outdoor, would be a dream single body set up for me. Most likely Megadapted on a Z8 body… But then again, all L Mount need to do to retain me is produce at least a longer focal range sibling to the 28-45 f1.8 and I’ll be a happy boy. ArashM 1 Link to comment Share on other sites More sharing options...
mtol Posted August 12 Share Posted August 12 I am actually finding that I use open gate a lot, not for content creation or vertical video but just for a taller aspect ratio. And something in a rugged doc-ready form factor would be a huge asset - I'm getting sick of shooting video on a stills body. This puts the FX5 at the top of the list currently for me. Price of the body itself doesn't strike me as particularly unreasonable given that it will hold its value, but its the accessories (the cards, new adapters, etc) that make the whole switch to E-mount dreadful right now. It's also hard to pull the trigger when the S1HII is overdue. Link to comment Share on other sites More sharing options...
Davide DB Posted August 19 Share Posted August 19 A short from Filippo Chiesa Thanks to Sony Italy, I had the opportunity to put the new FX5 through its paces on a real project I’m currently working on. I shot everything in X-OCN LT 5K open gate, using spherical lenses. The FX5’s sensor is truly wonderful, and I believe its performance sets a new benchmark for cameras of this type—and beyond. MrSMW and Snowfun 1 1 Link to comment Share on other sites More sharing options...
ade towell Posted August 19 Share Posted August 19 Ooh that opening shot gives me tingles Snowfun 1 Link to comment Share on other sites More sharing options...
