ND64 Posted September 10, 2025 Author Share Posted September 10, 2025 31 minutes ago, Danyyyel said: Where did you get these. In the gerald Undone test, the DR imatest test, it around the 12.5, which is about the good/middle ground. https://www.nikon-asia.com/cinema-z-r Danyyyel 1 Link to comment Share on other sites More sharing options...
Ilkka Nissila Posted September 10, 2025 Share Posted September 10, 2025 3 minutes ago, ND64 said: https://www.nikon-asia.com/cinema-z-r With dynamic range, the actual number that results from a measurement depends on a number of factors, what SNR level is used as the lower end limit of acceptable quality, and whether the SNR is calculated based on patches or pixels, or something in between. An 8K camera at pixel level will have lower DR than a 4K camera or 8K camera downsampled to 4K which in turn will have lower dynamic range than 2K native camera or a 4K/8K downsampled to 2K, and so on. Noise reduction that is applied to the footage also affects the dynamic range. Only by applying an equal test at equal final presentation resolution can a fair measurement of DR be made. In stills there are well-defined standards (PDR at photonstophotos and engineering DR by DXOMark, for example, all evaluated after resampling the images to 8 MP size) but for video there doesn't seem to be any unified standard which would result in comparable numbers. Danyyyel 1 Link to comment Share on other sites More sharing options...
eatstoomuchjam Posted September 10, 2025 Share Posted September 10, 2025 16 minutes ago, Django said: RED team wanted to protect their line and purposely not give the ZR too many pro features like redundancy recording, open gate Keep in mind that most, if not all of the actual Red cameras from Red don't support redundancy recording. I don't think I ever saw an older one with more than a single Red mag slot. Komodo has a single CFast card. Komodo-X has a single CF Express card. I'm not sure about V-Raptor. As far as open gate, yes, Reds do this, but their sensors are 17:9 so open gate matches that. If they support 3:2 recording, it's by cropping the left and right edges of the frame. I'm not sure if all of their sensors are 17:9, but again, every one that I've seen has been. Danyyyel and Django 2 Link to comment Share on other sites More sharing options...
Super Members BTM_Pix Posted September 10, 2025 Super Members Share Posted September 10, 2025 20 minutes ago, eatstoomuchjam said: Internal raw recording and a flippy screen makes this perfect for an everyday carry camera, especially combined with some of the smaller M mount glass (Collapsible 50/2, Elmar 35) And with the Techart Pro MZ adapter you can have them autofocus as well. andrgl and eatstoomuchjam 2 Link to comment Share on other sites More sharing options...
Django Posted September 10, 2025 Share Posted September 10, 2025 29 minutes ago, eatstoomuchjam said: Keep in mind that most, if not all of the actual Red cameras from Red don't support redundancy recording. I don't think I ever saw an older one with more than a single Red mag slot. Komodo has a single CFast card. Komodo-X has a single CF Express card. I'm not sure about V-Raptor. As far as open gate, yes, Reds do this, but their sensors are 17:9 so open gate matches that. If they support 3:2 recording, it's by cropping the left and right edges of the frame. I'm not sure if all of their sensors are 17:9, but again, every one that I've seen has been. I get that RED cameras don’t offer media redundancy or true Open Gate, but in a small mirrorless form factor, some form of redundancy is more expected, especially with a hot CF/SD slot near the battery that could potentially cause failures. RED at least has RED Connect / IP streaming for backup, and SDI. All we have here is micro HDMI not exactly safe externally either. Even a “pseudo” Open Gate mode could’ve been implemented without needing a bigger sensor, just flexible readout. Maybe I’m being nitpicky, but these shortcomings feel like crippling. Link to comment Share on other sites More sharing options...
Davide DB Posted September 10, 2025 Share Posted September 10, 2025 Hummm, IDK if this could be an everyday camera for all the v-loggers out there. IIUC according to Gerald, all of the codec implementations, with the exception of RedCode, are more than mediocre and are anyway worse than on other Nikon Z cameras. In practice, if you want to use it, you have to use RedCode, but at 6K@60p, it consumes 470MB per second, and a 320GB CF Express card is full in 28 minutes. Surely the FW is alpha or beta, and then with updates, things will change but ATM, we're shooting ants with a cannon. Link to comment Share on other sites More sharing options...
andrgl Posted September 10, 2025 Share Posted September 10, 2025 This is the most exciting cinema camera I've seen since the 5D3 got cDNG RAW with Magic Lantern. Not a fan of Z mount but the camera specs make it irrelevant. I may even buy into their lens ecosystem now. Hopefully Sigma starts making FF natives for their system. Anyway. Instant buy. It's amazing, cuz I never thought I'd own a RED. Nikon buyout is the best thing ever. Edit: Note to self, buy Megadap ETZ21 Pro+ and Sigma 28-45mm f/1.8 in Sony E. mercer and eatstoomuchjam 2 Link to comment Share on other sites More sharing options...
eatstoomuchjam Posted September 10, 2025 Share Posted September 10, 2025 48 minutes ago, Django said: I get that RED cameras don’t offer media redundancy or true Open Gate My turn to be nitpicky: Red cameras do offer true open gate. The sensor itself is 17:9. Open gate refers to using the entire sensor to record. Open gate on a Micro 4/3 camera or GFX would be 4:3 aspect ratio. On most mirrorless or DSLR's, it will be 3:2. Open gate and 3:2 get conflated a lot because that's the ratio for the sensors in the cameras that a majority of people have. 1 hour ago, Django said: All we have here is micro HDMI not exactly safe externally either Micro HDMI sucks really bad. One of the worst connectors I've ever seen. That said, there's also a very nice 4" screen built into the camera and I'd still say that the camera's strength is not in being built out for cinema, but in being small and relatively inexpensive. If you're rigging the camera with a cage, you could use a cable clamp to avoid the connector breaking as soon as somebody breathes near it. If I'm using the camera as a tiny handheld, I'm not connecting an external screen. But definitely, if your use case is to put an external monitor on the camera without a cage, this camera is a terrible choice and you definitely should not buy it. FWIW, the EOS R5 also has a micro HDMI port. I think that was improved in the II, but in a couple of years of owning and casually using the R5 as my small/handheld camera (similar to how I see thie ZR), I don't think it's ever bothered me because I've never connected an external display to it. Anyway, for me, if I were going to rig up a camera, I'd just use an OG Komodo (available used for not much more money than the ZR costs new). I have a pretty nice minimal Komodo rig for handheld and it's pretty light. Still a lot bigger than my R5 which is, in turn, bigger, I think, than the ZR. Link to comment Share on other sites More sharing options...
newfoundmass Posted September 10, 2025 Share Posted September 10, 2025 The lack of a full size HDMI doesn't bother me too much because it doesn't support RAW over it anyway, and the 4 inch screen looks really nice that I don't think an external one is necessary. I suppose it might be frustrating for those who want to rig it out or absolutely need an external monitor, but there are quite a few things about this camera that makes that impractical regardless of what the promotional photos show. It'd be nice to have a full size HDMI, and anything that limits how you can use a camera sucks, but it'd also be nice to have two of the same card slots and not located in the battery compartment. If you need that, or want to rig it up, this camera just isn't for you. Link to comment Share on other sites More sharing options...
Django Posted September 10, 2025 Share Posted September 10, 2025 56 minutes ago, eatstoomuchjam said: My turn to be nitpicky: Red cameras do offer true open gate. The sensor itself is 17:9. Open gate refers to using the entire sensor to record. Open gate on a Micro 4/3 camera or GFX would be 4:3 aspect ratio. On most mirrorless or DSLR's, it will be 3:2. Open gate and 3:2 get conflated a lot because that's the ratio for the sensors in the cameras that a majority of people have. Sure, I get what you're saying and thanks for making the distinction but I guess what I meant by "true open gate" is when a taller sensor (3:2, 4:3, etc.) gives you extra vertical resolution that’s actually recorded, not just the full width of a 17:9 sensor. On RED, if you want 3:2 or 4:3, you’re essentially windowing/cropping horizontally, you’re not capturing new image area above and below the 17:9 frame. That's what I mean by "pseudo open gate". That’s where cameras like ARRI LF, Alexa 35, or mirrorless bodies with 3:2 sensors have an edge: their open gate modes really open up more height for anamorphic or reframing flexibility. Different design philosophies, but that’s the distinction I was getting at. 56 minutes ago, eatstoomuchjam said: Micro HDMI sucks really bad. One of the worst connectors I've ever seen. That said, there's also a very nice 4" screen built into the camera and I'd still say that the camera's strength is not in being built out for cinema, but in being small and relatively inexpensive. If you're rigging the camera with a cage, you could use a cable clamp to avoid the connector breaking as soon as somebody breathes near it. If I'm using the camera as a tiny handheld, I'm not connecting an external screen. But definitely, if your use case is to put an external monitor on the camera without a cage, this camera is a terrible choice and you definitely should not buy it. FWIW, the EOS R5 also has a micro HDMI port. I think that was improved in the II, but in a couple of years of owning and casually using the R5 as my small/handheld camera (similar to how I see thie ZR), I don't think it's ever bothered me because I've never connected an external display to it. Anyway, for me, if I were going to rig up a camera, I'd just use an OG Komodo (available used for not much more money than the ZR costs new). I have a pretty nice minimal Komodo rig for handheld and it's pretty light. Still a lot bigger than my R5 which is, in turn, bigger, I think, than the ZR. I dunno for a camera that’s marketed "Cinema Z" under the RED name, micro HDMI feels like a completely unnecessary weak point. Most modern mirrorless bodies (R5 II, FX3, Lumix, even Nikon Z) have full-size HDMI now. It’s not just about rigging the cam but it’s about having a reliable connection for external monitors or recorders when needed. For a camera that’s trying to position itself as a serious compact cinema tool, micro HDMI in 2025 looks like a surprising step backward. That said yes kudos on them for the bright 4" screen! Link to comment Share on other sites More sharing options...
mercer Posted September 10, 2025 Share Posted September 10, 2025 I know the phrase of the day is content creator, but I, personally, see this as the ultimate, low/no budget, DIY, short film camera. I don't think I have ever been so tempted to hit preorder. I understand its inconveniences and there are a couple things I need to research... battery life (the FP is atrocious), overheating, IBIS quality, etc... but I must say this is the most excited I have been for a camera since I bought my 5D3 and installed ML Raw onto it. Danyyyel and andrgl 2 Link to comment Share on other sites More sharing options...
eatstoomuchjam Posted September 10, 2025 Share Posted September 10, 2025 16 minutes ago, Django said: I dunno for a camera that’s marketed "Cinema Z" under the RED name, micro HDMI feels like a completely unnecessary weak point. Most modern mirrorless bodies (R5 II, FX3, Lumix, even Nikon Z) have full-size HDMI now. I get what you're saying, but I'd also say that almost none of those cameras are a direct competitor for the ZR - either in size or price. Cameras that I would think of as direct competitors to the ZR would be Panasonic S9 (micro), Sony A7C series (micro), and Sigma fp (micro), or Fuji X-H2S (full-size) - or a used R5 (micro). It's weak, but no weaker than a majority of the cameras in a similar size/price range. 22 minutes ago, Django said: It’s not just about rigging the cam but it’s about having a reliable connection for external monitors or recorders when needed. For a camera that’s trying to position itself as a serious compact cinema tool, micro HDMI in 2025 looks like a surprising step backward. That said yes kudos on them for the bright 4" screen! I get that, but I'd say that the intersection between "times when a monitor or recorder needs to be attached" and "times when the camera isn't rigged" is a small one. And again, if that's your main use case, you should almost definitely not pick the ZR. Similarly, even more common use cases like "camera is on a tripod and you want to swap the CF card" are weaknesses. Luckily, they're use cases that are well-covered by a bunch of other cameras. Link to comment Share on other sites More sharing options...
eatstoomuchjam Posted September 10, 2025 Share Posted September 10, 2025 One thing that I'm curious about, and I don't think I've seen it in any reviews yet (though admittedly I've only watched like 2) is whether turning off IBIS comes with a physical sensor lock on this camera as it does on some other Nikons. Given that the camera has <10ms of rolling shutter, I'm really strongly considering selling my Z Cam E2-S6G and remaining Z Cam accessories toward it. My main use for that camera is attaching it to my car on bad roads to film the drive. The ZR could be an ideal and much smaller replacement for that sort of thing - but if the sensor floats even with IBIS off, it becomes a terrible choice. Link to comment Share on other sites More sharing options...
Super Members BTM_Pix Posted September 10, 2025 Super Members Share Posted September 10, 2025 24 minutes ago, eatstoomuchjam said: One thing that I'm curious about, and I don't think I've seen it in any reviews yet (though admittedly I've only watched like 2) is whether turning off IBIS comes with a physical sensor lock on this camera as it does on some other Nikons. In the CVP review, they made a point of confirming that the sensor can NOT be locked. eatstoomuchjam 1 Link to comment Share on other sites More sharing options...
John Matthews Posted September 10, 2025 Share Posted September 10, 2025 Maybe it's me, but the ZR seems more like a S9 with a bigger LCD, internal RAW, and a slightly more functional hotshoe in a heavier body, worse IBIS, not as many tools, and roughly for $1200 more. Am I missing something? The ZR also has 4k 120 in S35, which could be a big deal for some. Link to comment Share on other sites More sharing options...
Super Members BTM_Pix Posted September 10, 2025 Super Members Share Posted September 10, 2025 45 minutes ago, mercer said: I don't think I have ever been so tempted to hit preorder. I was exactly the same watching the CVP review. And then right at the end they showed some Z8 clips. 47 minutes ago, mercer said: I understand its inconveniences The one I’m least arsed about is the HDMI port as no matter the size they can all snap off if you hit them. Theres an argument to say the Micro version is preferable because it’s a smaller target 😂 mercer and eatstoomuchjam 2 Link to comment Share on other sites More sharing options...
eatstoomuchjam Posted September 10, 2025 Share Posted September 10, 2025 17 minutes ago, John Matthews said: Maybe it's me, but the ZR seems more like a S9 with a bigger LCD, internal RAW, and a slightly more functional hotshoe in a heavier body, worse IBIS, not as many tools, and roughly for $1200 more. Am I missing something? That's about the gist of it. But I'd add that the heavier body is also, from what it seems, a more robust body. Also, less rolling shutter, shutter angle setting, 2 hours vs 30 minutes recording, uncropped 4kp60, much higher resolution on the lcd, headphone port, environmental sealing, and CF express. Also, ability to get an adapter and use Sony lenses for people who have invested in them. On the other hand, S9 can do 3:2 recording if that's a selling point for you. And aside from being lighter, it's noticeably smaller in side-by-size pictures. I'd also add that at least a nubbin of a hand grip is preferable to a completely rounded body for a camera that I'd intend to shoot mostly handheld (making the ZR preferable) Danyyyel and John Matthews 2 Link to comment Share on other sites More sharing options...
mercer Posted September 10, 2025 Share Posted September 10, 2025 18 minutes ago, John Matthews said: Maybe it's me, but the ZR seems more like a S9 with a bigger LCD, internal RAW, and a slightly more functional hotshoe in a heavier body, worse IBIS, not as many tools, and roughly for $1200 more. Am I missing something? The ZR also has 4k 120 in S35, which could be a big deal for some. I don't know, I think you answered your own questions... bigger LCD, internal Raw (multiple Raw formats... and ProRes HQ) ... those alone are worth the price increase. When you add internal 32bit float audio (a real game changer) ... as far as tools, I have a feeling some of Red's exposure tools may be implemented... I've heard a lot of folks refer to the stop light as being a really cool one? Listen, I get it. I like Panasonic too. I still really enjoy my GH6 (with LogC) and will probably keep it. Am going to test the pixel:pixel mode today with some old Cosmicar c-mounts, but not every thread, or new camera release, has to be an affront, or comparison, to Panasonic. That said, this idea of Raw video, r3D or otherwise, is NOT for most video shooters and probably unnecessary for most YouTubers and people who frequent this site. The storage requirements are insane. Someone upthread said that you get 28 minutes of footage on a 320GB CFExpress card... I assume that's 6K, so I'll do a little better with 4K but that's still a lot of media and storage needed. But if you look at the camera for what it is... a powerful, entry level, Raw video camera, then even with its quirks, it's an epic release. John Matthews and Danyyyel 2 Link to comment Share on other sites More sharing options...
mercer Posted September 10, 2025 Share Posted September 10, 2025 44 minutes ago, BTM_Pix said: I was exactly the same watching the CVP review. I watched half of Mark Bone's video... I get it. 1 hour ago, BTM_Pix said: The one I’m least arsed about is the HDMI port as no matter the size they can all snap off if you hit them. Theres an argument to say the Micro version is preferable because it’s a smaller target 😂 Last week, I sold the final part to my old BMMCC rig... SmallHD Focus and I have no intentions of ever using an external monitor again. Honestly, I get annoyed with fully articulating LCDs... I use the camera strap method and when articulated, the image is blocked by the strap. That's why I love the GH6's LCD sled. Greatest design for a camera screen ever! Link to comment Share on other sites More sharing options...
Super Members BTM_Pix Posted September 10, 2025 Super Members Share Posted September 10, 2025 1 hour ago, mercer said: Last week, I sold the final part to my old BMMCC rig That’s the end of an era right there. I’ll have to part ex my S5ii and some lenses to get the Z8 like I should’ve done two years ago. Less the end of an era and more the end of an error. mercer 1 Link to comment Share on other sites More sharing options...
