kye Posted May 30 Share Posted May 30 I bought an EF-MFT speed-booster, now I need some lenses! It's a VILTROX EF-M2II, and I tried my 50mm F1.8 and the AF was somewhere between functional and like it had a mind of its own. The focus ring on the lens has such a short travel that it's impossible to use as a MF lens (which it wasn't designed for so I understand). I'm looking for some interesting / fast / cheaper EF lenses that will be fine manually focusing. I'm especially interested in lenses F1.4 or faster but are still budget lenses. My thoughts immediately turn to the early days of cheap Chinese glass, but I can't seem to find any as any search is overrun with Canon AF lenses, or with new MF lenses that are for EF-M mount but are incorrectly labelled as EF (even Meike has a lens labelled as EF that is clearly a mirrorless lens!), and while EF was the only mount people never bothered to include that information and so things don't appear in searches. Laowa doesn't even let you browse their products by mount! Our new robot overlords suggested some options: The Samyang/Rokinon series: 35mm 50mm 85mm F1.4 Zhongyi Mitakon Speedmaster 50mm f/0.95 (nice but it's over AUD1000!) Zeiss ZE series: 35mm f/2, 50mm 85mm f/1.4 MEIKE 50mm F1.2 Anything else I should be looking at? I really thought there were more third-party options around than just those. Link to comment Share on other sites More sharing options...
Anaconda_ Posted May 30 Share Posted May 30 I love the sigma 30mm f1.4. When I was using the GX80, it was pretty much the only lens I used. zerocool22 and kye 2 Link to comment Share on other sites More sharing options...
stephen Posted May 30 Share Posted May 30 Samyangs at f1.4 are not cheap plus they are big and heavy. As far as I remember you don't like big and heavy. Maybe older sigma lenses from HSM generation as Anaconda_ suggested. Sigma 24mm f1.8, 30mm f1.4, 50mm f1.4 HSM. They are all under 200 E/$. Not small though. If you want smaller and cheaper lenses then you have to accept they start at f1.8, f2 and f2.8. Then you have lots of option and not only with Canon. You can also adapt vintage lenses to EF adding second adapter. With speed booster they become f1.4 to f2 both quite usable in low light on m43 in my personal experience. I was in this place more than 5 years ago with BMPCC 4K. Went trough speed boosters, calculating focal lengths, spending lots of time researching and trying to build decent lens sets both vintage and modern. My frustration grew with time as I realized this won't be cheap nor ideal to my goals. Went FF and never looked back. My decision was driven specifically by lenses. I realized the hard way a well-known truth: We buy systems not cameras and lenses are more important than cameras. If I want to use vintage lenses, cheap lenses, have access to the largest pool of lenses - FF is the right choice. I may change one FF camera system with another, my vintage lens sets stay, lenses have the same focal length and character. Same is true for Canon EF lenses. A FF system is no longer more expensive than m43, especially when we include the lenses. Example Panasonic S5 vs Panasonic GX85 + speed booster. Paradoxically a FF system (body + lenses) may even come cheaper due to large pool of lenses than m43 + speed booster. j_one and Aussie Ash 2 Link to comment Share on other sites More sharing options...
kye Posted May 31 Author Share Posted May 31 18 hours ago, Anaconda_ said: I love the sigma 30mm f1.4. When I was using the GX80, it was pretty much the only lens I used. As a 47mm F2.2 it's pretty close to a 50mm, so a pretty good FOV if that's the look you like. I've just bought the Panasonic 25mm F1.7, which is 50mm F3.4 on the GH7, and it's my first 50mm FOV lens, so I'm keen to start taking that out and about and "learning" that focal length. It probably seems odd to most that I've never shot with that focal length, but it's never really suited the situations I've been shooting in. 14 hours ago, stephen said: Samyangs at f1.4 are not cheap plus they are big and heavy. As far as I remember you don't like big and heavy. Maybe older sigma lenses from HSM generation as Anaconda_ suggested. Sigma 24mm f1.8, 30mm f1.4, 50mm f1.4 HSM. They are all under 200 E/$. Not small though. Big and heavy isn't desirable, especially as I have some pretty killer combinations in that range already. I've got the Voigtlander 17.5mm and 42.5mm F0.95 lenses, which are 35mm and 85mm F1.9 equivalents, and with the Sirui 1.25x adapter they're as wide as 28mm and 68mm F1.5. Problem is those combinations are each 1300g / 4.6oz (2100g / 74oz with GH7) which is usable for hand-held shooting but my arms are pretty much done after a few hours. Of course, I'm also pretty much done with being on my feet for that long too so the setup isn't the limiting factor. These setups also have the advantages and coolness factor of being anamorphic too, so there's that! I'm slightly tempted by some other much stronger anamorphic adapters too, but in playing with the Sirui I've learned that they're very dependent on the taking lens, and some lenses work and other lenses that seem very similar are an absolute train wreck, so it's basically a blind purchase and these things aren't that cheap. 14 hours ago, stephen said: If you want smaller and cheaper lenses then you have to accept they start at f1.8, f2 and f2.8. Then you have lots of option and not only with Canon. You can also adapt vintage lenses to EF adding second adapter. With speed booster they become f1.4 to f2 both quite usable in low light on m43 in my personal experience. My current preferred Night Cinema combo is the Takumar 50mm F1.4 and M42-MFT speed booster, and I bought the EF-MFT speed booster to try and get a slightly cleaner image, but unfortunately the 50/1.4 -> M42-EF adapter -> EF-MFT speed booster stack doesn't work as the back element of the Takumar interferes with the EF SB glass. I figured that the EF SB would open up a whole new world, as EF used to be the default standard for about half the worlds camera users, plus EF and PL were the de facto standards for cinema. My recollection was that there were tonnes of interesting and super-fast third party EF lenses, but now I go looking there doesn't seem to be so many to be found. If budget was no-option then there are a lot of cinema lenses that are very interesting, even anamorphic ones, but budget is a consideration so unfortunately things like the USD1400 Blazar Cato 85mm T2.8 2x anamorphic lens will have to just remain a dream! 14 hours ago, stephen said: I was in this place more than 5 years ago with BMPCC 4K. Went trough speed boosters, calculating focal lengths, spending lots of time researching and trying to build decent lens sets both vintage and modern. My frustration grew with time as I realized this won't be cheap nor ideal to my goals. Went FF and never looked back. My decision was driven specifically by lenses. I realized the hard way a well-known truth: We buy systems not cameras and lenses are more important than cameras. If I want to use vintage lenses, cheap lenses, have access to the largest pool of lenses - FF is the right choice. I may change one FF camera system with another, my vintage lens sets stay, lenses have the same focal length and character. Same is true for Canon EF lenses. Apart from this being like me asking "can you recommend a lawnmower?" and you suggesting "just sell your house and move to a NYC apartment", I actually don't think it's true. I've done a lot of "what if" scenarios for what I'm trying to achieve, and while it might have worked for you specifically, when I look at the lenses for a given system I find every system to be very lacking. Sure, you can get fast lenses at 28/35/50/85, but there are all kinds of other gaps that MFT just doesn't have. This is gradually changing, as manufacturers gradually fill out the various lens lineups, but my impression of the current landscape is that most FF systems have the fast primes and holy trinity zooms (28/35/50/85 and 16-35/24-70/70-200) but very limited and patchy coverage of small and light lenses and in-between focal-lengths, etc. Adapting vintage SLR lenses gives access to character lenses, but only FF ones, not really S35 cinema ones (unless you go to crop mode which is throwing away resolution and now you're half-way to MFT!), and not the S16 ones. You sort of get the standard focal lengths in modern and in vintage, but that's it. MFT has all the small and light and in-between focal-lengths, but the weakness is in the fast primes and fast zooms. MFT used to have all the advantages of mirrorless essentially being able to adapt any SLR lens, but as time goes on, more and more of the interesting lenses are designed for mirrorless APSC/FF cameras and therefore not usable (or only available in MFT mount so you don't get a SB advantage) or are EF cinema lenses and are huge/heavy/expensive because they compromised on size and cost to ensure they're sharp sharp sharp sharp sharp enough for modern use. As an example, I have a tracking sheet of all the lenses I own (not every one available) and it's FF equivalent. This table includes: 15mm 18mm 26mm 28mm 30mm 31mm 34mm 35mm 40mm 50mm 53mm 56mm 59mm 64mm 70mm 71mm 75mm 78mm 80mm 82mm 83mm 85mm etc. I don't even think it's complete! Most of those are different characters too, being a mix of different manufacturers, vintages, and combinations of being native / with a SB / with an anamorphic adapter / with SB and anamorphic adapter, etc. So yeah, if you happen to want a fast standard focal length, or a fast trinity zoom (that's enormous), then FF is great, but the rest is pretty lacking. The other reason I'm not moving to FF is that most of what I shoot is on a native 10x zoom, which FF doesn't really have a good answer for. The other other reason is that the work for me to sell all my MFT equipment and re-buy in FF would make it so that I should just work those hours at my day job and increase my budget, so selling things isn't really cost effective. The other other other reason is that the GX85 has all sorts of configurations that FF can't match, so I wouldn't be selling that anyway. Link to comment Share on other sites More sharing options...
Super Members BTM_Pix Posted May 31 Super Members Share Posted May 31 23 hours ago, kye said: The other reason I'm not moving to FF is that most of what I shoot is on a native 10x zoom, which FF doesn't really have a good answer for There are actually good answers to the 10x question for each FF mount. Sigma 20-200mm is an answer for E mount and L mount. Sony has their own 24-240mm too. Nikon have a 10x near miss with their 24-200mm and an over the top 14.2x 28-400mm. Canon has their 24-240mm too and if you don’t mind mimicking trombone playing while zooming then their old 35-350mm EF is a great bargain. I actually have one of the latter and the range is great. eatstoomuchjam, kye and mercer 3 Link to comment Share on other sites More sharing options...
eatstoomuchjam Posted May 31 Share Posted May 31 3 hours ago, BTM_Pix said: Canon has their 24-240mm too and if you don’t mind mimicking trombone playing while zooming then their old 35-350mm EF is a great bargain. For years now, the EF 35-350 has been near the top of my "will I or won't I" pile. So far, still "won't I," but one of these days, i'm gonna get a wild hair to search and find a great deal.. kye 1 Link to comment Share on other sites More sharing options...
kye Posted June 1 Author Share Posted June 1 Soooooo...... no more EF manual focus lenses around I should know about? Link to comment Share on other sites More sharing options...
Super Members BTM_Pix Posted June 1 Super Members Share Posted June 1 5 hours ago, kye said: Soooooo...... no more EF manual focus lenses around I should know about? As you aren’t bothered about the AF aspect then Nikon F mount lenses adapt easily to EF so you could open up that path. The issue is that with the f1.4 requirement you’re looking at fairly pricey options in both vintage and more modern versions. Similarly, M42 and C/Y to EF adapters open up other paths for you. To be honest though, in my view, the path of least resistance to get fast manual focus glass on to MFT cameras economically probably lies in native MFT lenses from 7Artisans and TTArtisans. More size appropriate for what you have in mind for them too. kye 1 Link to comment Share on other sites More sharing options...
kye Posted June 1 Author Share Posted June 1 11 minutes ago, BTM_Pix said: As you aren’t bothered about the AF aspect then Nikon F mount lenses adapt easily to EF so you could open up that path. The issue is that with the f1.4 requirement you’re looking at fairly pricey options in both vintage and more modern versions. Similarly, M42 and C/Y to EF adapters open up other paths for you. To be honest though, in my view, the path of least resistance to get fast manual focus glass on to MFT cameras economically probably lies in native MFT lenses from 7Artisans and TTArtisans. More size appropriate for what you have in mind for them too. Somewhat embarrassingly, I originally bought the EF-MFT SB to replace my M42-MFT SB, but when I put my Takumar 50mm F1.4 on an M42-EF adapter and that onto the EF-MFT SB, the rear element of the Takumar interfered with the EF SB glass when I tried to focus more than a few meters away (nowhere near infinity focus). I probably could have determined that before I bought it if I'd searched enough, which is the embarrassing part. I'm not really sure how to tell which M42 and C/Y options would have this problem too.. is there a way to know? What Nikon lenses would be F1.4 or faster? and are there issues with the SB? The native MFT lenses from TTartisan / 7artisans are good options, but aren't as fast as the two Voigtlander F0.95 lenses I have, and are also bettered by a F1.4 lens on a SB. I did shoot with the TTartisans 50mm F1.2 in Japan and it seemed pretty good, but at 100mm equivalent FOV it's on the long end for my hand-held stuff. The Zeiss ZE Planar 50/1.4 looks like a potential option, being cleaner than the Takumar+M42-SB combo. The Mikaton 50mm F0.95 would be a stop faster than the Zeiss, and would be cleaner than the Takumar too, but is more expensive. I should look at the Sigma F1.4 primes too, in case something there stands out, although they're competing with the Zeiss Planar, which I would imagine is tough competition? I already have a ton of options and combined with my very specific requirements I'm really pushing things to find any options I haven't thought of, but I didn't think it would be so difficult to find super-fast FF EF lenses! Link to comment Share on other sites More sharing options...
Super Members BTM_Pix Posted June 1 Super Members Share Posted June 1 57 minutes ago, kye said: I'm not really sure how to tell which M42 and C/Y options would have this problem too.. is there a way to know? Your mileage may vary for your particular speed booster but if you look at the options for MFT on MetaBones versions they are transparent about which lenses may have restrictions with their products. For Nikon lenses, for example, there are limitations for their modern E range lenses (as distinct from their older lenses for their E Series cameras). 1 hour ago, kye said: What Nikon lenses would be F1.4 or faster? and are there issues with the SB? This is a typical set of available options for the manual only lenses. Fungus optional. https://www.ebay.co.uk/b/bn_16098984 For completeness, here is a rated list of fast Nikon AF lenses. https://phillipreeve.net/blog/the-rated-list-of-the-fast-nikon-af-s-f-1-4-f-1-8-f-2-0-f-mount-primes/ 1 hour ago, kye said: I should look at the Sigma F1.4 primes too The EF Art ones are excellent but are chunky fuckers. kye 1 Link to comment Share on other sites More sharing options...
maxJ4380 Posted June 8 Share Posted June 8 On 6/1/2026 at 6:18 PM, kye said: I probably could have determined that before I bought it if I'd searched enough, which is the embarrassing part. I'm not so sure about that, I have bought several items and most times i try to get as much info as i can to make an informed decision however nothing turns up. Once i have bought the thing and used it then found an issue googling that provides a bunch of responses that weren't available with earlier queries. I suspect my search terms or the wording is inadequate somehow. I will say i haven't had the the issue the my cheaper sb that you have had, my issues have been different... I did just have a quick look at my m42 takumars, they all look to have slightly different length protrusions from the rear. Theres also 4 types of 50mm takumars from takumars to super takumars and a couple of smc takumars. If you have a micrometer we could do some math and figure out the differences. But that wont solve your problem. kye 1 Link to comment Share on other sites More sharing options...
kye Posted June 12 Author Share Posted June 12 The plot thickens.... My Zeiss ZE 50/1.4 arrived and (apart from being an incredible chunk of glass and metal) it won't focus to infinity on the Viltrox EF-M2II. The Zeiss is properly seated on the Viltrox, the Viltrox is properly seated on the camera, and it's talking to the camera fine. I'm blaming the Viltrox because both the Zeiss and M42 Takumar both have the same issue, plus, the Zeiss has a hard-stop for infinity so it will be well calibrated and I'd trust their engineering over Viltrox any day! The advice online is that the optical element inside the Viltrox can be rotated to fix the issue, which makes perfect sense, only mine doesn't rotate, and I gave it a good go (with just my fingers) but it wouldn't budge. Do I just need to (carefully) attack it with tools? Any advice? Link to comment Share on other sites More sharing options...
maxJ4380 Posted June 12 Share Posted June 12 After mixing up 2 wheel barrow loads of cement, my back doesn't think very much of me.. thought i'd do some math instead. My digital calipers have decided to throw in the towel, bit like my back... tried different batteries no change. Was getting different readings, but consistent readings, so i took some measurements with the idea of helping kye out. Measuring from the back of the m42 lens to the furthest the lenses can protrude backwards on focusing gives me these measurements, er we have to minus 23.60 as thats what the calipers have decided is zero 🙄 17mm smc fisheye 30.80 - 23.60 - 7.2 35mm 3.5 super tak 31.80 23.60 - 8.2 35mm 2 super tak 31.70 23.60 - 8.1 50mm 1.4 super tak 32.00 23.60 - 8.4 85mm 1.9 super tak 0.3 so close to being flush 100mm smc macro flush to flange no change in length So it seems like the 50mm can protrude the furthest from what i have measured. With an ef adapter on the 50mm tukumar i get a distance of 7.4 Which makes sense as the thickness of the adapter looks to be 1mm. Which also has the effect of moving the lens away from the glass of the speed booster i would think. I am wondering at this point about your M42-EF adapter ? everything else works fine on it ? I have had 2 bad experiences with cheap adapters curious if yours is cheap ? I'd be tempted to reexamine your adapter. 50mm at full extension. Thats 8.4 mm from lens protrusion to the back of the lens. Anything on youtube as to altering the viltrox ? maybe a lens clamp seen them used on pulling lenses apart. Link to comment Share on other sites More sharing options...
maxJ4380 Posted June 12 Share Posted June 12 A very quick search found this Link to comment Share on other sites More sharing options...
kye Posted June 12 Author Share Posted June 12 1 hour ago, maxJ4380 said: A very quick search found this I watched the same video, but he rotates his with his fingers and I put little dents in the ends of my fingers trying and failing to get it to move. Also of note is he seems to have the EF-M2 and I have the EF-M2II (the second version of the EF-M2). Link to comment Share on other sites More sharing options...
kye Posted June 12 Author Share Posted June 12 Got it! It was just quite stiff, and the technique is to take a microfibre cloth and to grip the element from both sides pressing in on the glass elements themselves to turn it. Foolishly I wasn't using the full surface of the glass! I swear I could feel the surface of the glass bend slightly to get enough traction to get the lens to move, but it seems to have worked, and I now have slightly past infinity focus. I can adjust it to dial it in but I'm curious to see if that's enough clearance for the Takumar and M42-EF adapter, so will try that tomorrow and see how I go. Damn the Zeiss is a highly engineered object though! Link to comment Share on other sites More sharing options...
Anaconda_ Posted June 12 Share Posted June 12 A quick headsup with the Viltrox adapter. Years ago, I hacked a Canon 10-18mm to make it fit, which it did. However, one day, I took it out my bag and was getting some really crazy lens flares. Turned out, the back lens element was touching the glass in the adapter when at around 12mm. In my bag, it cracked the glass in the Viltrox, and I learned there's a pretty good reason the combo didn't work without being hacked. So if you get any EFs lenses, be careful - or you'll end up with a one of a kind, megaflare adapter (I've used it a few times since because of the 'creative flaring', so it's not all bad) This photo is from the moment I noticed something was wrong. Luckily, it was on my GX85 at the time, which I was using for behind the scenes stills. So nothing was lost or ruined in a 'professional' sense. kye, maxJ4380 and eatstoomuchjam 3 Link to comment Share on other sites More sharing options...
kye Posted June 12 Author Share Posted June 12 1 hour ago, Anaconda_ said: A quick headsup with the Viltrox adapter. Years ago, I hacked a Canon 10-18mm to make it fit, which it did. However, one day, I took it out my bag and was getting some really crazy lens flares. Turned out, the back lens element was touching the glass in the adapter when at around 12mm. In my bag, it cracked the glass in the Viltrox, and I learned there's a pretty good reason the combo didn't work without being hacked. So if you get any EFs lenses, be careful - or you'll end up with a one of a kind, megaflare adapter (I've used it a few times since because of the 'creative flaring', so it's not all bad) This photo is from the moment I noticed something was wrong. Luckily, it was on my GX85 at the time, which I was using for behind the scenes stills. So nothing was lost or ruined in a 'professional' sense. Wow - that's one hell of a sun star! You could use that to gain both power and respect on the entry-level stills photography sites.. they'd fall on their knees before you!! After going through the exercise of seeing what EF glass was out there I didn't see a lot of options that tempted me, so I suspect that I'll just end up leaving it attached to the Zeiss 50/1.4 and that will be that. If the image from the Zeiss is half as good as the lens' physical construction then it would be worth buying the Viltrox just to use with the Zeiss lens alone! Someone else pointed out that the Viltrox is probably only capable of F1.2 at maximum, so that would mean the Mikaton 50mm F0.95 lens is out of the running, and it was the only other thing I was really tempted by. Link to comment Share on other sites More sharing options...
eatstoomuchjam Posted June 12 Share Posted June 12 1 hour ago, kye said: Someone else pointed out that the Viltrox is probably only capable of F1.2 at maximum, so that would mean the Mikaton 50mm F0.95 lens is out of the running, and it was the only other thing I was really tempted by. The faster the lens being boosted, the more likely you'll have some speed booster artifacts. Even with Metabones, I don't think I'd go past 1.2. If you really wanted to go that way, and it's off-topic for this thread, but I'd suggest looking at the Voigtlander 29/0.8 which, IIRC, is native for M43. Link to comment Share on other sites More sharing options...
maxJ4380 Posted June 13 Share Posted June 13 18 hours ago, kye said: Got it! It was just quite stiff, and the technique is to take a microfibre cloth and to grip the element from both sides pressing in on the glass elements themselves to turn it. Foolishly I wasn't using the full surface of the glass! I was going to suggest one of those friction clothes, mum has a few in the kitchen drawer for hard to open jam jars. If that didn't work, one drop of wd-40 on the threading left to sit over night, only one drop mind you as you dont want to find out that wd-40 might be also good at delaminating glass elements Link to comment Share on other sites More sharing options...
