QuickHitRecord Posted August 15 Share Posted August 15 I'm exploring the idea of assembling a set of "super slow" vintage primes with an f/stop of f/3.5 or slower for use on short films, personal projects, etc. Why super slow? Because I want the benefits of shooting wide open (circular bokeh & potentially softer image) without throwing the background totally out of focus. Plus, I've been trying to shoot at a deeper depth of field lately because it is a look that I find myself gravitating towards more and more. Plus, slow lenses shouldn't cost much and might even open up the opportunity to work with some real sleepers that no one really cares about these days. Ideally: Focal lengths: ~20mm, 28/35mm, 50/55/58mm, 85/105mm OR a super simple set like 24mm, 50/55mmm, 85/105mm f/3.5 or slower (preferably all the same f/stop) Same series of lens for consistency Preferred: Old and weird (single-coating, etc.) Adaptable to Canon EF mount Focuses the "right away" (focus scale to the left of infinity) Readily available and under $200/each Does anyone have any recommendations? Link to comment Share on other sites More sharing options...
eatstoomuchjam Posted August 16 Share Posted August 16 I'm not sure of the current prices, but I have an old Elmar 35mm f/3.5 which is one of the most gorgeous pieces of glass I've ever seen or used. Also, I have an old Elmar 90mm f/4 collapsible which is pretty gorgeous. I'd take the 90/2 'cron over it any day, but I'd shed no tears if the 90/4 were the only portrait lens in my bag. Sorry neither one is even remotely adaptable to EF, though! zlfan 1 Link to comment Share on other sites More sharing options...
MrSMW Posted August 16 Share Posted August 16 Carl Zeiss Vario Sonnar f/3.5 40-80 ‘push-pull’ zoom. I have that as my ‘oddball’ lens and used it a few times with an EF-L adapter with built in VND. Quite a few focal lengths covered there in a single lens! Link to comment Share on other sites More sharing options...
stephen Posted August 16 Share Posted August 16 Minolta MD 35-70mm f3.5 + Minolta MD 24-35mm f3.5. Minolta MD 35-70mm f3.5 is very good, Minolta MD 24-35mm f3.5 just OK. For video both are sharp enough,both relatively small and compact and two touch operation. Only drawback for me is that Minolta MD 35-70mm f3.5 zoom is most extended at 35mm. You can add also some of the tele zooms but they are all push pull type. IMHO using zooms would be the best approach as all brands had zooms in the f3.5 to f4 range. If you are willing to use zooms with non constant aperture you'll have much more options. Link to comment Share on other sites More sharing options...
Administrators Andrew - EOSHD Posted August 16 Administrators Share Posted August 16 15 hours ago, MrSMW said: Carl Zeiss Vario Sonnar f/3.5 40-80 ‘push-pull’ zoom. I have that as my ‘oddball’ lens and used it a few times with an EF-L adapter with built in VND. Quite a few focal lengths covered there in a single lens! Have you compared it to the replacement 35-70mm? The latter lens is very handy on the GFX 100 and filmic looking. Ninpo33 1 Link to comment Share on other sites More sharing options...
MrSMW Posted August 17 Share Posted August 17 11 hours ago, Andrew Reid said: Have you compared it to the replacement 35-70mm? Nope, only have the 40-80. The only things I don't like about it are the highlights are a bit too glowy and it's a heavy little fucker! Link to comment Share on other sites More sharing options...
John Matthews Posted August 17 Share Posted August 17 On 8/15/2025 at 10:36 PM, QuickHitRecord said: Same series of lens for consistency Good luck. Manufacturers changed coatings every time they went to the bathroom. They were always getting tweaked. Granted, they often had similar looks. You can find some very unique f/3.5 constant zooms that will do the job. Some of them are sharp and cheap with magnificent and crazy flares. Here are some that I found interesting. I have the Makinon zoom lens. Â Â Link to comment Share on other sites More sharing options...
fuzzynormal Posted August 18 Share Posted August 18 f2.8 on M43 is kinda a sweet spot though, don't ya think?  Or are you trying to Spielberg it? John Matthews 1 Link to comment Share on other sites More sharing options...
Administrators Andrew - EOSHD Posted August 18 Administrators Share Posted August 18 I have tried a number of cheap/crap 28-80ish lenses on the GFX 100 and they all have a knack for covering the sensor perfectly if you zoom in past 35mm So the Makinon I am interested to hunt down in Berlin and try... The Nikon in theory has the perfect focal length for the GFX 100, but I am not sure I share our YouTube friend's enthusiasm for the flare... The Makinon was much nicer to my eye John Matthews 1 Link to comment Share on other sites More sharing options...
eatstoomuchjam Posted August 18 Share Posted August 18 12 hours ago, John Matthews said: Here are some that I found interesting. I have the Makinon zoom lens. I picked up the Nikkor after watching CP's review and doing some searching and seeing how many people described it as not only the worst lens Nikon ever made, but also possibly the worst zoom ever made. They might be right, but I'm sure I'll find the right time to use it someday. I'm not sure if this true of all of them, but mine also has the problem that when I put it on an EF adapter, the back of the aperture selector is so tight against the edge of the adapter that it can't even possibly be moved. I had to use a pliers to take it off to make sure I didn't do something wrong. Maybe there are other EF adapters that would work better, but for anything I'd use the Nikkor to shoot, I'm sure I'd want it wide open anyway. I'm looking forward to watching the video on the Makinon. I've not heard of that one before - and if it's still $30ish on eBay, I guess there's not a reason not to buy it. John Matthews 1 Link to comment Share on other sites More sharing options...
John Matthews Posted August 18 Share Posted August 18 1 hour ago, eatstoomuchjam said: I'm looking forward to watching the video on the Makinon. I've not heard of that one before - and if it's still $30ish on eBay, I guess there's not a reason not to buy it. I have the AR mount version. It's a decent lens by my eye. My copy has a trashed front thread and the rubber missing from the zoom ring- neither are a problem for me. I've seen them in K-mount too, but I'm not sure if there any differences. The fact that it has been used to oblivion is a good sign to me- somebody loved this lens to use it that much. Judging from this video and the video he shot entirely on it, I'd say there aren't any differences. I also have a Pentax 35-105 f/3.5 constant that belonged to my father, but it's almost impossible to use. There's just so much gear noise and you have to go into a full-macro mode to get somewhat close. Here's a video describing it:  Link to comment Share on other sites More sharing options...
John Matthews Posted August 18 Share Posted August 18 Inspired by this post, I tried to make some flares with the Makinon. Some were shot at f/16 and others f/3.5 with an ND filter. I shot in v-log and corrected for exposure and add the official Panasonic LUT. maxJ4380 and mercer 2 Link to comment Share on other sites More sharing options...
Administrators Andrew - EOSHD Posted August 18 Administrators Share Posted August 18 Turns out I had the Makinon in a cupboard all along and will also give it a go. Some of these old zooms have terrible 1.5m+ minimum focus distances or rely on an awkward to engage separate macro mode, but some have the macro mode on the main focus ring and some are even par-focal. The Exakta 28-70mm F4 MC Macro (made in Japan with 62mm filter thread, and mine is an M42 mount version) in particular stands out for me, nice vintage look, nice size and weight, ergonomic to use, decent optics and distortion, covers GFX 100 well, especially in square 1:1 aspect for stills or 16:9 for video, and focuses down to 1:3.2 macro with one turn of the main focus ring (no funny separate mechanism to contend with). The best for flare is the absolutely pre-historic Voigtlander Zoomar 36-82mm F2.8, think it was the first ever zoom lens for SLRs, the distortion is absolutely insane at 82mm but if you stay between 36-70mm it has a lot of cinematic goodness. BTM_Pix and John Matthews 2 Link to comment Share on other sites More sharing options...
kye Posted August 18 Share Posted August 18 On 8/16/2025 at 4:36 AM, QuickHitRecord said: I'm exploring the idea of assembling a set of "super slow" vintage primes with an f/stop of f/3.5 or slower for use on short films, personal projects, etc. Why super slow? Because I want the benefits of shooting wide open (circular bokeh & potentially softer image) without throwing the background totally out of focus. Plus, I've been trying to shoot at a deeper depth of field lately because it is a look that I find myself gravitating towards more and more. Plus, slow lenses shouldn't cost much and might even open up the opportunity to work with some real sleepers that no one really cares about these days. Ideally: Focal lengths: ~20mm, 28/35mm, 50/55/58mm, 85/105mm OR a super simple set like 24mm, 50/55mmm, 85/105mm f/3.5 or slower (preferably all the same f/stop) Same series of lens for consistency Preferred: Old and weird (single-coating, etc.) Adaptable to Canon EF mount Focuses the "right away" (focus scale to the left of infinity) Readily available and under $200/each Does anyone have any recommendations? Canon FD might do it - price might be an issue perhaps?  Plenty of F3.5 or F4 lenses in the lineup, they focus the way you want, and you even get a choice of coatings (normal, S C, or S S C).  Some of the slower ones are macro lenses too! https://cameraville.co/blog/list-every-canon-fd-lens-ever-made Zooms are also an excellent idea. An out of the box idea is to use faster lenses, but to keep the aperture wide open and cut a round hole in a lens cap and get the aperture you want that way.  I'm not sure if this would reduce the DOF in the right way?  It would definitely lower the exposure though, and would definitely keep the bokeh the shape you want. John Matthews 1 Link to comment Share on other sites More sharing options...
MrSMW Posted August 18 Share Posted August 18 All the footage on this one (between approx 1 minute and 2 minutes 15 seconds) was shot on the Zeiss 40-80 f3.5 handheld. I programmed 2x custom settings for the IBIS on the S5ii, one at 40mm and the other for 80mm and then only shot at these focal lengths. I bottled it for the wedding day and went back to Sigma and Lumix AF lenses, but I am considering bringing this lens back as part of my workflow for these day prior and day after parts of a wedding where I am not under any real time constraints and can afford to be more 'creative'... https://firehorsephotographyfrance.com/weddings/jenniedan John Matthews 1 Link to comment Share on other sites More sharing options...
homestar_kevin Posted August 18 Share Posted August 18 I'd go with Super Takumar, Nikkors, or Olympus OM. All have a good selection of 3.5 and 2.8 lenses that can be had cheap. I put together a cheaper Takumar set a few years ago and got great deals on some bundles with the 3.5 primes. John Matthews 1 Link to comment Share on other sites More sharing options...
maxJ4380 Posted August 18 Share Posted August 18 6 hours ago, John Matthews said: Inspired by this post, I tried to make some flares with the Makinon. Some were shot at f/16 and others f/3.5 with an ND filter. I shot in v-log and corrected for exposure and add the official Panasonic LUT. Thanks for sharing, might be the only lens that can compete with the first nikon 43-86 zoom😉 After some research, a little while ago, i got the 2nd edition? of the nikon 43-86mm. One odd thought later (like how bad could it be? ) and a first edition was on its way... easiest way to tell them apart is the first has the text on the inside of the filter ring from memory. The second gives a more pleasing image for the masses, the first is er... more subjective, dare i say it a specialist lens for particular projects. Now i guess i have to find the adapter to suit as its been awhile.   John Matthews 1 Link to comment Share on other sites More sharing options...
QuickHitRecord Posted August 18 Author Share Posted August 18 I went away for the weekend and came back to find some cool posts on this thread! On 8/15/2025 at 10:57 PM, stephen said: IMHO using zooms would be the best approach as all brands had zooms in the f3.5 to f4 range. If you are willing to use zooms with non constant aperture you'll have much more options. There are definitely benefits in terms of consistency. I still haven't been able to find a vintage zoom with a useful focal length that focuses in the right direction and doesn't have smeary bokeh. Also, I'm not a huge fan of the 12+ element stacked flares that usually come with those lenses. The best I've been able to find it he Olympus 35-70 f3.6 but I wouldn't call it a character lens. On 8/17/2025 at 8:19 AM, John Matthews said: I have the Makinon zoom lens. I saw this video about a year ago and tried to get one. I had a seller mislabel their listing and ended up with the variable aperture version. I was pretty irritated by this and it went into a drawer, only coming out when I dropped it off at Goodwill. I haven't looked again since. 17 hours ago, fuzzynormal said: f2.8 on M43 is kinda a sweet spot though, don't ya think?  Or f4 on S35. Absolutely. That's a case for M43 that is seldom made. But it also kind of forces you into wide, expensive glass. At least for vintage lenses. It's a bit of a catch 22. 13 hours ago, eatstoomuchjam said: I picked up the Nikkor after watching CP's review and doing some searching and seeing how many people described it as not only the worst lens Nikon ever made, but also possibly the worst zoom ever made. Bought this one a couple of years ago. It wasn't for me. I was in agreement that it was the worst Nikon lens I'd ever tried. 6 hours ago, Andrew Reid said: The best for flare is the absolutely pre-historic Voigtlander Zoomar 36-82mm F2.8, think it was the first ever zoom lens for SLRs, the distortion is absolutely insane at 82mm but if you stay between 36-70mm it has a lot of cinematic goodness. I found one of these with an M42 mount a few years ago. I really thought that it would scratch the itch but my copy was remarkably sharp. Amazing for the first zoom ever made. 6 hours ago, kye said: An out of the box idea is to use faster lenses, but to keep the aperture wide open and cut a round hole in a lens cap and get the aperture you want that way.  I'm not sure if this would reduce the DOF in the right way?  It would definitely lower the exposure though, and would definitely keep the bokeh the shape you want. This is actually a pretty neat idea. It might also work with step-down rings. It could also be a good way to standardize light transmission between lenses. I think I'm going to try this. kye 1 Link to comment Share on other sites More sharing options...
Ninpo33 Posted August 18 Share Posted August 18 There are so many options out there with those requirements. Any of the major brands had some real gems depending on the era. Anything 2.8 will really clean up at 3.5 and still be vintage soft vs modern and clinical. 2.8 copies will allow you to not get jammed up in low light situations when you might need it but you can live in deep focus the rest of the time. I have the whole Contax Zeiss set and they’re a perfect blend of vintage and not too sharp. great color. Can be found cheap now. Also highly recommend the Yashica M42 stuff and Konica AR for cheap underrated options. Link to comment Share on other sites More sharing options...
Super Members BTM_Pix Posted August 18 Super Members Share Posted August 18 If you want a vintage set from the same range that are pretty uniform and readily available then the Nikon Series E are worth a look. They are available in the following focal lengths. Prime Lenses: E 28mm f/2.8, E 35mm f/2.5, E 50mm f/1.8, E 100mm f/2.8, and E 135mm f/2.8. Zoom Lenses: E 36-72mm f/3.5, E 75-150mm f/3.5, and E 70-210mm f/4.0. Obviously, no wider than 28mm may or may not be a deal breaker for you personally. The zooms are one touch such was the fashion at the time but are good performers. As I say they are all from the same range so are more matched than having to pick from this and that branch of, say, CZJ etc. You can get them for an average across the set of around £75-90 per lens plus budget £10 for each F to EF adapter. Plenty of examples to peruse here https://www.flickr.com/groups/1032976@N23/pool/ If you can stretch the budget, the Contax Zeiss range is compelling but for 1/3rd of the price the Series E range is a decent option. mercer 1 Link to comment Share on other sites More sharing options...
