Emanuel Posted June 27 Author Share Posted June 27 On 6/27/2026 at 7:08 PM, eatstoomuchjam said: For me, I'm still not seeing that as especially useful or revolutionary. It's been possible for a long time, probably 10+ years, to do gyro control of larger gimbals (usually through the phone app, but I think I had or saw at least one with an external gyroscope controller in the past). It never took off much and I never saw anybody strap a phone to their head to remotely control their gimbal. I'm not sure if gyro controls are in DJI MIMO, but if they are, it's already basically possible with the Pocket 3. I've found gyro control to be somewhat useful with the Ronin 4D (including with the flex unit). On one shoot, I was getting too tired to carry the camera anymore so the grips started carrying it around while I controlled the frame from the gyro on the high bright remote monitor. It worked... OK. It'd be better if we'd practiced it beforehand, probably. For me, it's more "parlor trick" than "genuinely useful tool" in most cases. The gyro control itself is not new, correct. But I don’t think the interesting part here is simply that “gyro control exists”. Of course it does. Larger gimbals, phone apps, remote monitors and systems such as the Ronin 4D have already explored that territory. The question for me is not whether the underlying idea existed before, but whether it becomes useful in a different way once the whole system becomes small enough, fast enough, integrated enough and unobtrusive enough. Many ideas in cinema technology existed before they became truly useful. Stabilised camera movement existed before Steadicam became the right combination of body, balance, operation and image. Small cameras existed before 16mm, and later DV, changed the way filmmakers could move through reality. Remote operation existed before it became practical in the hands of a one or two-person crew. So yes, if we reduce this to “a gyro controlling a gimbal”, then it may sound like nothing new. But if we look at it as a pocket-sized 1-inch 10-bit Log gimbal camera, with several focal lengths, proper monitoring, autonomous operation and a dedicated head-tracking accessory, then the proposition changes. It is not only the control method. It is the form factor plus the image pipeline plus the operating mode. And this is also where the remote / detachable screen side becomes important. If this is not a meaningful step forward, then how do we explain that DJI, despite all its experience in this category, still seems one step behind on this specific point? Not necessarily behind in image quality or engineering as a whole, but behind in this particular operational concept. The comparison makes that fairly easy to see. DJI can offer remote control through its ecosystem, apps and accessories, but Luna Ultra brings the detachable screen, remote monitoring and camera control directly into the body concept itself. To be fair, DJI still has a major advantage in ecosystem continuity. If, apart from the optical accessories, the Osmo Pocket 3 accessories remain compatible with the Osmo Pocket 4P/Pro, that is obviously a strong point. It means users are not forced to abandon an existing accessory ecosystem. But that is a different kind of strength. It is backward compatibility and ecosystem maturity, not necessarily a new operating concept. That matters because the remote is not just a convenience feature. It changes the way the camera can be used. There are also small operational trade-offs on the DJI side that are worth noticing. For instance, the dedicated low-light video mode tops out at 4K30p, while Luna Ultra records up to 4K120p in regular video mode and offers PureVideo low-light capture up to 4K60p. Not the whole story, of course, but another sign that Insta360 seems to be moving ahead of DJI* in a few practical areas here. And yes, we have already seen Insta360 explore part of this same logic with the GO line, namely the GO Ultra. With the GO Ultra, for instance, you already have that very useful modular idea of separating the camera unit from the monitoring/control/battery side of the system. In the Luna Ultra, this logic is taken into a different class of camera: the detachable touchscreen remote allows independent monitoring of battery information for both the main unit and the remote, and the system manages charging between both parts. Even if the remote does not appear to support fully independent USB-C charging while detached, the operational concept is still important. The monitoring/control side and the image-capturing side start to behave as distinct elements of the same camera system. That is precisely the point. The more the monitoring, battery handling and control are separated from the visible camera body, the easier it becomes for the device to disappear into the situation. And for documentary, BTS, production diaries or observational work, that can be a much bigger deal than it first appears. A phone strapped to your head controlling a larger gimbal is one thing. A compact dedicated device that can sit inside a BTS, documentary or walk-around setup, become boring after a while, and follow intention without the operator constantly raising, aiming and correcting the camera is another thing. That is where I think the usefulness may appear. Not necessarily for everyone. Not necessarily for controlled narrative setups. And probably not as a replacement for a skilled operator with a proper camera package. But for small crews, making-of work, observational documentary, rehearsals, production diaries, street work and situations where the act of operating the camera visibly changes the behaviour of the people being filmed, I can absolutely see the value. In that sense, I don’t see it as revolutionary because gyro control is new. I see it as potentially revolutionary because a previously awkward idea may finally be arriving in a form factor where it can become natural, invisible and operationally useful. *And not only when compared with DJI or another compact device... ; ) take a look at this higher-end comparison too : X shooter 1 Link to comment Share on other sites More sharing options...
Emanuel Posted June 28 Author Share Posted June 28 These two [1*] [2] Korean hands-on videos are probably among the most useful references I have seen so far on the Luna Ultra / Pocket 4P discussion. EDIT — plus this one from another reviewer elsewhere: [3] Not because they end the debate, on the contrary : ) but since they also help show the real operational trade-offs better than most spec-sheet comparisons, while still offering some fairly clear findings on the usual comparison points, such as outcome, colour or dynamic range, whenever those aspects are covered. source *In this 1st video, right from the start, you can see exactly that approach: using this kind of camera as a serious B-cam tool (Osmo Pocket 3) in commercial work, very close to the way I have also been using small capture devices in a similar role, as mentioned before. shooter 1 Link to comment Share on other sites More sharing options...
filmmakereu Posted July 2 Share Posted July 2 On 6/27/2026 at 2:28 AM, Emanuel said: I think the POV Head Tracker should not be seen merely as a vlogging gimmick or as another accessory for people who want to film themselves walking down the street. There are many different ways of filming, framing and capturing reality. The most “professional” approach is often understood as the most controlled one: you plan the shoot, you discuss the framing, you block the scene, you decide where the camera goes, you decide what the subject is supposed to give you, and then you execute. That is obviously valid, and it is the basis of a lot of good cinema. But it is not the only way to make images. There is also another tradition: a more intuitive, observational, physical and spontaneous way of filming, where the camera is less a machine imposing a pre-decided frame on the world and more an extension of the filmmaker’s presence inside that world. That is where I think something like the Insta360 POV Head Tracker becomes interesting. The question is not only “what can it do technically?” The question is: what kind of relationship with reality does it allow? When you are operating a camera in the conventional way, you are always doing several things at once. You are looking, framing, correcting, adjusting, deciding, reacting, and at the same time you are also visibly present as “the person filming”. That presence changes the situation. It changes the people in front of you. It changes the rhythm of what happens. It can intimidate, formalise, freeze or theatricalise reality. In documentary, this is especially important. The more you plan, the more you risk fixing the subject before you have really encountered it. You may think you are observing reality, but you are already working on a construction of reality. You are no longer only receiving what is in front of you. You are fabricating a gaze, and the subject starts to exist inside that fabrication. Of course, complete objectivity does not exist. Every image is already a point of view. But there is still a big difference between a camera that constantly announces itself as an intervention and a camera system that allows the filmmaker to remain more physically and psychologically inside the situation. This is why the POV Head Tracker interests me. It may allow the filmmaker to film without constantly “operating” in the traditional sense. The camera can follow the natural direction of the filmmaker’s attention. The image can become closer to a lived point of view rather than a pre-composed shot. Not perfect objectivity, obviously, but perhaps a more immediate form of subjectivity. That distinction matters. A head-tracked gimbal camera could be useful not because it replaces deliberate cinematography, but because it opens another mode of acquisition: a more instinctive, embodied, less intimidating mode. It lets you be present with the subject while still filming. It can reduce the gap between seeing and recording. In that sense, I see a possible historical parallel with what happened when smaller 16mm cameras became available. Those cameras did not simply make cinema smaller. They changed the grammar of cinema. They allowed filmmakers to move differently, to follow people differently, to enter rooms differently, to film streets, faces, accidents, gestures, private moments and unstable situations in ways that would have been much harder with heavier, more industrial tools. You can connect that to cinéma vérité, direct cinema, the Nouvelle Vague, the New American Cinema, Jonas Mekas in New York, underground and independent filmmaking, and later the influence of that freer, more mobile language on figures like Cassavetes, Scorsese, and the whole post-studio generation. Even mainstream cinema eventually absorbed some of that looseness, that handheld energy, that search for immediacy. Jonas Mekas is not just an abstract reference for me. I had the privilege of knowing him personally in the mid-1990s, at the Figueira da Foz International Film Festival, which he used to attend. In that same context, I was also fortunate enough to receive an award as best daily press film critic. More importantly, a project I am still developing today was born precisely from that contact with Mekas. So when I refer to him here, I am not only invoking a name from film history. I am also referring to a very concrete personal encounter with a way of understanding cinema as diary, presence, immediacy, memory and life. The technology did not create those artistic revolutions by itself. But it made certain gestures possible. And when a tool makes a new gesture possible, it can also make a new kind of cinema possible. That is how I would look at the POV Head Tracker. Not as “AI tracking for creators”, but as a small step toward a different relation between body, gaze and camera. From the end of last month and carrying into this June, I worked on the making-of for A NOITE, Leonel Vieira’s film adaptation of José Saramago’s homonymous play. During the shoot, we used the Osmo Pocket 3 alongside other cameras, including a Sony A7S III, an FX30, a Panasonic GX80/GX85 and other small-format tools, Insta360 included. The film itself was being shot on two ARRI cameras, so this kind of low-profile equipment was obviously not what people on a cinema set are most used to seeing. Even Leonel Vieira, the director, looked at the Osmo Pocket 3 and jokingly said it looked like a toy camera. But that was precisely part of the point. I took the initiative to use it without hesitation, accepting the risks of bringing that kind of device into a professional film set, and combining it with different optical tools, including black mist filters to create atmosphere, Sirui anamorphic lenses and other accessories. In that context, I became very aware of how valuable it would be to have a device that lets me film without constantly managing the camera as an object. Not to mention that 10-bit Log recording is now available on the Luna Ultra as well. In a making-of situation, the best moments often happen before people know they are “performing” for the camera. They happen between takes, in hesitations, glances, silences, rehearsals, small gestures, private exchanges, and moments when the machinery of cinema briefly becomes human again. But the moment you raise the camera, adjust the frame, move closer, correct the angle, ask for space or visibly operate, you can lose the very thing you were trying to capture. The reality in front of the lens changes because of you. And that is fundamental in a making-of context: to be as minimally intrusive as possible, so as not to disturb the set of the main film being shot. The reactions of the professionals involved are, in many ways, the real subject of a making-of, and those reactions should not be manipulated by the visible presence of the image-capturing device itself. In our case, we were working with a very small crew: two to three people at most. In fact, it was necessary to convince Leonel Vieira to accept a maximum of three people, because ideally he preferred two, and sometimes only one person could be present. In those situations, when only one person was shooting and I still needed two possible angles, a camera A and a camera B, the only viable option was to have a B camera as autonomous and unobtrusive as possible, which is exactly how the Osmo Pocket 3 was used. With a device such as the Luna Ultra and its POV Head Tracker, that kind of work would become much easier, not only during the shoot itself but also later, when reaching the post-production suite and needing more options in the edit. So a device that lets the camera follow your attention, while your hands and your body remain less occupied by the act of filming, could be extremely useful. It could allow the operator to be less intrusive, less theatrical, less visibly extractive. It could make the camera feel less like a weapon pointed at reality and more like a witness moving through it. That does not mean this is for every situation. It is not a substitute for composed cinematography, lighting, blocking, lenses, or intentional mise-en-scène. But it could be very valuable for documentary, making-of work, rehearsal footage, street filming, travel, observational cinema, and any situation where spontaneity matters more than perfect formal control. The professional instinct is often to control everything. But sometimes cinema gains power when we control less. Sometimes the most authentic image is not the one we planned best, but the one we were able to receive before reality became aware of our plan. That, to me, is where the POV Head Tracker could become genuinely interesting. Most people will probably end up buying both and using them with two different focal lengths, as in the case of the filmmaker you referred to. That level of flexibility is hard to beat. After all, they’re portable and easy to carry around. The footage matches pretty well too. I wouldn’t even mind making a few minor tweaks, if any are needed. shooter and Emanuel 2 Link to comment Share on other sites More sharing options...
Emanuel Posted July 3 Author Share Posted July 3 On 7/2/2026 at 12:07 PM, filmmakereu said: Most people will probably end up buying both and using them with two different focal lengths, as in the case of the filmmaker you referred to. That level of flexibility is hard to beat. (...) Now, about using it in summer... are we talking about a mild summer, or an actual summer that isn’t even properly hot, where the camera doesn’t need to suddenly remember it has thermal limits? Here’s a useful 45-minute guide: And last but not least, one of the best comparison tests I've found so far, if not the most interesting with a unique range of pros and cons is here, as well as probably the smartest use of a fine example for low light is there (serves as tutorial too). To those who still think this unique accessory called the POV Head Tracker is merely pointless/meaningless, take a look at what Insta360’s CEO Insta360’s CEO said on the matter, when he said he hopes “that one day everyone will forget cameras even exist” : o EDIT — Worth adding too: the new Pocket 4P/Pro filters are already starting to appear, alongside the brand-new D-Log 2 enabled by an equally new next-generation LOFIC image sensor. And what about noise texture or quality of the grain in D-Log and D-Log 2 when testing the ISO range? A 2nd test, colour included, plus a comparative analysis between the two and against S-Log3 no less*, from another reviewer here. BTW... Also not to forget the bitrate difference likewise highlighted by this old-school written comparison/review: Pocket 4P/Pro goes up to 180 Mbps versus Luna Ultra’s 120 Mbps, exactly 50% higher. The question is: what will be the real-world impact of that extra compression headroom in demanding scenes and heavier Log grading? * A 5-stop difference in D-Log 2 and a full stop in D-Log... a 4-stop gap between the two! Well, who would have guessed? ; ) + another test: compared with the full-frame a7 V [LINK] : X Katrikura and shooter 1 1 Link to comment Share on other sites More sharing options...
shooter Posted July 4 Share Posted July 4 On 7/3/2026 at 6:02 AM, Emanuel said: EDIT — Worth adding too: the new Pocket 4P/Pro filters are already starting to appear, alongside the brand-new D-Log 2 enabled by an equally new next-generation LOFIC image sensor. And what about noise texture or quality of the grain in D-Log and D-Log 2 when testing the ISO range? A 2nd test, colour included, plus a comparative analysis between the two and against S-Log3 no less*, from another reviewer here. BTW... Also not to forget the bitrate difference likewise highlighted by this old-school written comparison/review: Pocket 4P/Pro goes up to 180 Mbps versus Luna Ultra’s 120 Mbps, exactly 50% higher. The question is: what will be the real-world impact of that extra compression headroom in demanding scenes and heavier Log grading? * A 5-stop difference in D-Log 2 and a full stop in D-Log... a 4-stop gap between the two! Well, who would have guessed? ; ) + another test: compared with the full-frame a7 V [LINK] : X Amazing jump. One stop already means 2x light. Now imagine five stops! Emanuel 1 Link to comment Share on other sites More sharing options...
Emanuel Posted July 27 Author Share Posted July 27 Luna Ultra firmware update... v1.0.283: I-Log monitoring, zoom and general operation have improved a lot, while the POV Head Tracker (one of my favs, as you already know ; ) now also works with the camera mounted upside down, with better control accuracy and standby power consumption on the detachable display has also been reduced : ) Link to comment Share on other sites More sharing options...
kye Posted July 31 Share Posted July 31 CineD tests are published, and the DJI kicks the Insta360s butt completely and utterly. https://www.cined.com/dji-osmo-pocket-4p-lab-test-rolling-shutter-dynamic-range-and-exposure-latitude/ https://www.cined.com/insta360-luna-ultra-lab-test-rolling-shutter-dynamic-range-and-exposure-latitude/ Link to comment Share on other sites More sharing options...
Super Members BTM_Pix Posted July 31 Super Members Share Posted July 31 The niggle with the P4P comes with the tele lens. The first being that 60mm equivalent might actually be a bit too tight for some purposes. It has an alluring shallow depth of field that vloggers will be drawn to using for filming themselves but it’s just that too tight to be held at a distance that will give a decent framing. The second of course is that it can’t use the new D-Log2 as it’s got a different sensor which means another step in post in swapping in correction LUTs on shots that use it. This is compounded by the utterly ridiculous limitation that you have to stop recording and manually change profiles. So if you are on the 20mm enjoying your bonkers 17 stops of dynamic range you can’t zoom through to get a tighter shot without stopping recording and selecting the lower profile. The answer is to always stick in the lower profile )or even a standard non-LOG one) but DJI really need to have a firmware update to allow a way of automatically transitioning if you are using DLog-2. It will still require the recording being stopped (automatically though if they implement it) and the extra step in post of making sure you have the correct LUT for each type of shot but it avoids the titting about with the small touch screen to change profiles, something which will be become very old very quickly. For me, I’d keep it in the standard Dlog profile for general use and treat the D-Log2 as more of a special case when I need more stops than a church organ. The lens though is not something that can be solved with a firmware update and for some people (not me as I am as averse to my own face as other onlookers are) it will be an issue when they start using it in earnest. Link to comment Share on other sites More sharing options...
Anaconda_ Posted July 31 Share Posted July 31 There are already wide converters to put on the 20mm lens. How long until someone releases one for the 60mm tele. You could sell a set of 30 / 40 / 50mm attachments. Or a tele converter to turn the 20mm lens into 60mm and then you can keep D-Log2. kye 1 Link to comment Share on other sites More sharing options...
kye Posted July 31 Share Posted July 31 7 hours ago, BTM_Pix said: The niggle with the P4P comes with the tele lens. The first being that 60mm equivalent might actually be a bit too tight for some purposes. It has an alluring shallow depth of field that vloggers will be drawn to using for filming themselves but it’s just that too tight to be held at a distance that will give a decent framing. The second of course is that it can’t use the new D-Log2 as it’s got a different sensor which means another step in post in swapping in correction LUTs on shots that use it. This is compounded by the utterly ridiculous limitation that you have to stop recording and manually change profiles. So if you are on the 20mm enjoying your bonkers 17 stops of dynamic range you can’t zoom through to get a tighter shot without stopping recording and selecting the lower profile. The answer is to always stick in the lower profile )or even a standard non-LOG one) but DJI really need to have a firmware update to allow a way of automatically transitioning if you are using DLog-2. It will still require the recording being stopped (automatically though if they implement it) and the extra step in post of making sure you have the correct LUT for each type of shot but it avoids the titting about with the small touch screen to change profiles, something which will be become very old very quickly. For me, I’d keep it in the standard Dlog profile for general use and treat the D-Log2 as more of a special case when I need more stops than a church organ. The lens though is not something that can be solved with a firmware update and for some people (not me as I am as averse to my own face as other onlookers are) it will be an issue when they start using it in earnest. Yeah, as someone who shoots out and about (but doesn't vlog) 20mm and 60mm equivalents seem a little odd to me, although the 20mm makes sense for vlogging as it's just wide enough, and I guess having anything shorter than 60 would be a little too close to the 20 perhaps? Then again, I've worked out that I can do this odd thing called "cropping" which involves getting less than 4K in the final image, which is why no-one has ever thought of it before. It all still seems very cumbersome though. The log profile swapping etc smells like they'll release firmware updates to make it much easier. I often get the impression that the manufacturers get their product design feedback from people who film very deliberately and slowly, and only when it hits the market and people all point out the workflow gotchas that firmware updates eventually fix strange things like this. Link to comment Share on other sites More sharing options...
Super Members BTM_Pix Posted July 31 Super Members Share Posted July 31 5 hours ago, Anaconda_ said: There are already wide converters to put on the 20mm lens. How long until someone releases one for the 60mm tele. You could sell a set of 30 / 40 / 50mm attachments. Or a tele converter to turn the 20mm lens into 60mm and then you can keep D-Log2. This is the wide angle adapter. Wouldn’t take much of a leap for them to have a wide angle adapter in the unpopulated area where the tele lens sits behind. Or make one with removable magnetic tc/wa adapter set to choose which one you want (or not) in front of which lens. I expect Ulanzi will have such a set out within the month 😂 Link to comment Share on other sites More sharing options...
Super Members BTM_Pix Posted July 31 Super Members Share Posted July 31 18 minutes ago, kye said: and I guess having anything shorter than 60 would be a little too close to the 20 perhaps? It lets them hit attractive spec points like 3x optical zoom and 12x zoom when using the digital shenanigans. Although the 3x optical zoom is actually 3x switch as the intermediate points are digital and if you are in D-Log2 then it’s a hard switch as there is no digital zoom. I think 45mm equivalent would’ve been better from a practical point of view but 2.25x optical zoom and 9x total zoom doesn’t look as good in the marketing. Even though 20-190mm equivalent is still not too shabby ! A good practical look at the challenges around shooting with it in this video. kye 1 Link to comment Share on other sites More sharing options...
kye Posted August 1 Share Posted August 1 10 hours ago, BTM_Pix said: It lets them hit attractive spec points like 3x optical zoom and 12x zoom when using the digital shenanigans. Although the 3x optical zoom is actually 3x switch as the intermediate points are digital and if you are in D-Log2 then it’s a hard switch as there is no digital zoom. I think 45mm equivalent would’ve been better from a practical point of view but 2.25x optical zoom and 9x total zoom doesn’t look as good in the marketing. Even though 20-190mm equivalent is still not too shabby ! I recently watched a video where a street photographer tested his first 40mm lens, after only ever shooting with 35mm and 50mm lenses previously, and he couldn't really make heads-or-tails out of it in the week he had it. You could tell from the video that he found it different than a 35mm or 50mm, and that didn't surprise me, but what did catch my attention was that he didn't really even know how to explore and learn a new focal length. After reflecting on that video for some time I realised that: Lots of people must "learn" the focal lengths by sort-of memorising them based on external influences rather than just using them and learning first hand through experimentation With MFT and S16 cameras I'm used to using all sorts of "odd" focal lengths because I'm adapting all kinds of lenses from other systems with/without speedboosters and add-on anamorphic and spherical adapters I'm also used to getting a new focal length and using it blind and over the course of many outings of shooting with it gradually learning what impacts it has on what I shoot, how I shoot, how I walk around, how I begin to look at the world, how the world adapts to me once I adapt, how I feel when the world reacts to that, etc.. Using a zoom isn't like having a complete set of primes at all, it's almost like a different genre or different type of shooting entirely, but I'm quite familiar with that as well Now, when I think about using a particular focal length that I'm familiar with, all kinds of stuff comes to mind, and when I think about using one I am not familiar with, I don't know how to think about it at all.. the focal lengths are all so incredibly different. Having a camera with a 20mm and a 60mm seems like: - the people who don't know what they're doing won't notice (as they're confused about everything already) - the people that are used to shooting with primes will have an awkward and steep learning curve that they might not navigate that well - the people that know how to learn new focal lengths will probably adapt, but given the 35mm and 50mm FOVs are at the worst end of the main lens, they'll likely have a difficult experience choosing between a 2.5x crop of the main camera to get 50mm, or losing the DR and colour profile on the 60mm lens It might be that these are actually ideal for the type of shooting that people will use this camera for, and it's the normal FOVs that are ill-suited, but if you've "learned" the 24/28/35/50/85/100mm FOVs then it'll be a serious transition to navigate. Link to comment Share on other sites More sharing options...
Super Members BTM_Pix Posted August 1 Super Members Share Posted August 1 5 hours ago, kye said: Using a zoom isn't like having a complete set of primes at all, it's almost like a different genre or different type of shooting entirely, but I'm quite familiar with that as well It depends on the range really. A 24-70mm is definitely 3-4 primes for me but something like the Canon 35-350mm is a different animal. Leica used to do these two lenses They are referred to as MATE (Medium Angle Tri-Elmar) and WATE (Wide Angle Tri-Elmar) and are “zoom” lenses with fixed focal length stops. The MATE is stepped at 28-35-50mm and the WATE at 16-18-21mm which on their intended use (Rangefinders) were used with a specific ad on viewfinder that was so clunky it is known as the Frankenfinder. They are not fast but are compact and have focal length stops that make sense so are very much a bag of primes (and very much more useful adapted on to an EVF body). Some Panasonic fixed lens cameras (LX10 and LX100 spring to mind) emulate this by allowing you to use the zoom ring to increment to fixed focal lengths and it is a good feature especially on those with return to position on power on functionality. I *think* some of the Sony RX100 do this as well. kye 1 Link to comment Share on other sites More sharing options...
kye Posted August 1 Share Posted August 1 55 minutes ago, BTM_Pix said: It depends on the range really. A 24-70mm is definitely 3-4 primes for me but something like the Canon 35-350mm is a different animal. Leica used to do these two lenses They are referred to as MATE (Medium Angle Tri-Elmar) and WATE (Wide Angle Tri-Elmar) and are “zoom” lenses with fixed focal length stops. The MATE is stepped at 28-35-50mm and the WATE at 16-18-21mm which on their intended use (Rangefinders) were used with a specific ad on viewfinder that was so clunky it is known as the Frankenfinder. They are not fast but are compact and have focal length stops that make sense so are very much a bag of primes (and very much more useful adapted on to an EVF body). Some Panasonic fixed lens cameras (LX10 and LX100 spring to mind) emulate this by allowing you to use the zoom ring to increment to fixed focal lengths and it is a good feature especially on those with return to position on power on functionality. I *think* some of the Sony RX100 do this as well. Good discussion and I think this cuts to the heart of how different the thought process really is. If I'm shooting in public with a single prime then this is how I am thinking about it: - I have a fixed FOV, but I can move around and closer/further and when I do that I change all of the following at once: - the size of the subject in the frame - the perspective I have on the subject - the size and position of the subject compared to the items in the foreground and background - my distance to the subject - my influence on what I am shooting - So I visualise the situation in 3D and estimate where I need to move to create the composition I want - I move there and refine the camera position and take the shot If I'm shooting in public with a zoom then this is how I am thinking about it: - I have a flexible FOV and I can move closer/further so when I do that I can: - zoom, which changes the size of the subject and foreground and background in the frame without changing their relationships, or my distance, or without changing my influence on the subjects - move, which changes the perspective I have on the subject and therefore the relationships of the objects in the scene to each other, and it changes the subject distance and my influence on what I am shooting - So I visualise the situation in 3D and estimate a line/cone of positions I can be in to create broadly the composition I want through varying combinations of focal length and my position - I weigh up my priorities, trading subject distance, my influence on the subject/scene, and composition against each other to work out what I think is the best balance - Depending on the layout, I also consider how fast I can get there compared to what is happening in the scene - I move there and refine the camera position and zoom simultaneously, and take the shot One is starting with a single FOV and working from there, the other is starting with an infinite number of FOVs. The thinking is completely different. When I'm using a prime the idea of zooming is completely alien and when I am using a zoom the idea of there being set focal lengths is completely alien. It's like I have two programs in my head, one for primes and one for zooms, and I just run the appropriate one for what lens I am using at the time. The idea of taking a zoom and limiting it to preset lengths might seem like a miracle compared to having a prime, but it's a disaster compared to having a zoom lens. I spoke more about this in my dedicated thread about it, and once you start thinking beyond composition and into aesthetics and tone the idea that a 35mm vs 50mm FOV are 'similar' is about as ridiculous as a photo editor only allowing you to crop the image by 0% or 30% (this is the difference in FOV between a 50mm and a 35mm). I'm sure you're aware of these fundamental differences from your own shooting and you'll have been doing all this consciously or unconsciously. If you start from a technical perspective then a zoom is just like a set of primes, but from a creative perspective it's nothing like a set of primes whatsoever. Emanuel 1 Link to comment Share on other sites More sharing options...
Super Members BTM_Pix Posted Sunday at 08:18 AM Super Members Share Posted Sunday at 08:18 AM Yeah, “Unconsciously Stumbling Upon The Appropriate Lens Choice Since 1978” is definitely something I’d like to have as an epitaph. kye 1 Link to comment Share on other sites More sharing options...
Emanuel Posted Sunday at 09:11 AM Author Share Posted Sunday at 09:11 AM On 7/31/2026 at 7:54 AM, kye said: CineD tests are published, and the DJI kicks the Insta360s butt completely and utterly. https://www.cined.com/dji-osmo-pocket-4p-lab-test-rolling-shutter-dynamic-range-and-exposure-latitude/ https://www.cined.com/insta360-luna-ultra-lab-test-rolling-shutter-dynamic-range-and-exposure-latitude/ I think “completely and utterly” may be doing a little too much work there @kye : P There is also a slightly amusing irony in relying on CineD here, given that Andrew’s forum rules have historically discouraged linking to the site whenever possible, although, of course, he also made clear that such links would not be censored. That aside, the DJI result is undeniably impressive. The 20mm LOFIC camera in D-Log2 seems to be in a different league when it comes to measured dynamic range and exposure latitude. I’m just not sure that this particular test supports such a definitive verdict on the two complete camera systems. Those spectacular figures apply specifically to the 20mm camera in D-Log2. The 60mm camera does not offer D-Log2 and produces considerably more conventional results. On the Luna side, the CineD test seems mainly to reveal that its current I-Log processing is seriously problematic, particularly because of the aggressive internal noise reduction. They did not test the standard profiles, which they themselves suggest may currently be the better option. So, to me, the fair conclusion is that DJI’s best sensor and profile comprehensively outperform Luna’s present I-Log implementation in these specific laboratory tests. That is still a major win for DJI. Just not necessarily a complete and utter defeat of the Luna in every respect. In these comparative tests [A | B] though ; ) the result is rather less one-sided : ) Now compare the Luna’s 8K with the Pocket’s 4K [1 + 2 already posted up there or directly here] and judge for yourself ; ) Lab tests are extremely useful because they isolate specific variables and give us repeatable measurements, but they are not the same thing as real-world shooting. They cannot fully account for colour, detail rendering, motion, sharpening, texture, highlight roll-off, subject separation or simply which image looks more convincing in an actual scene. As these comparisons and the footage itself demonstrate, a camera that appears decisively superior on a chart does not necessarily produce the preferable image once we step outside the lab bubble and look at the actual footage. LU I | LU II | LU III | 4P I | 4P II | 4P III Part of it has already been posted, among others, for instance right there. Both are irresistible to me. Whichever one comes out ahead in any particular test, I think both cameras are genuinely worthy of the OOAK label. The Pocket 4P is unique in what it achieves with its 20mm LOFIC sensor and D-Log2 in such a small body, while the Luna Ultra is equally singular in its modular design, detachable remote screen, internal 32-bit float stereo audio and overall shooting concept, particularly with its innovative POV Head Tracker. They are not merely two versions of the same product competing on a laboratory chart; each offers something that currently exists nowhere else. shooter 1 Link to comment Share on other sites More sharing options...
kye Posted Monday at 12:51 PM Share Posted Monday at 12:51 PM On 8/2/2026 at 5:11 PM, Emanuel said: I think “completely and utterly” may be doing a little too much work there @kye : P One has 16 stops of DR (or 17.2 with SNR=2) with little if any NR, and the other has so much NR that the DR is measured as 13 stops for both SNR=1 and SNR=2, which is a completely ridiculous result. One has 10+ stops of latitude and the other has something like 4-5 stops of latitude. Considering that the primary purpose of these cameras is to shoot wide scenes in uncontrolled situations, DR is always a major challenge. NR is normally the issue with cameras like this too, and one has results that are remarkably good for cameras of any price, and the other is remarkable for how heavy the NR is. When the one that scores better in all of the above is the cheaper one, that's also saying something. I don't think that "completely and utterly" is overselling it at all. On 8/2/2026 at 5:11 PM, Emanuel said: There is also a slightly amusing irony in relying on CineD here, given that Andrew’s forum rules have historically discouraged linking to the site whenever possible, although, of course, he also made clear that such links would not be censored. Hey, if someone else wants to publish lab tests on these things then I'll link to them instead. Unless you think they're lying about the lab test results, then the discussion is normally better when it involves actual objective measurements than if it doesn't involve any at all. I'm not saying that measurements are the only thing that matters, but if you're comparing two cameras that have a difference in performance of 4 stops then that's an incredible amount and when shooting outside in available light on wide angle lenses then that is something that really matters in real-world situations. Link to comment Share on other sites More sharing options...
Emanuel Posted Tuesday at 03:52 AM Author Share Posted Tuesday at 03:52 AM 18 hours ago, kye said: One has 16 stops of DR (or 17.2 with SNR=2) with little if any NR, and the other has so much NR that the DR is measured as 13 stops for both SNR=1 and SNR=2, which is a completely ridiculous result. One has 10+ stops of latitude and the other has something like 4-5 stops of latitude. Considering that the primary purpose of these cameras is to shoot wide scenes in uncontrolled situations, DR is always a major challenge. NR is normally the issue with cameras like this too, and one has results that are remarkably good for cameras of any price, and the other is remarkable for how heavy the NR is. When the one that scores better in all of the above is the cheaper one, that's also saying something. I don't think that "completely and utterly" is overselling it at all. Hey, if someone else wants to publish lab tests on these things then I'll link to them instead. Unless you think they're lying about the lab test results, then the discussion is normally better when it involves actual objective measurements than if it doesn't involve any at all. I'm not saying that measurements are the only thing that matters, but if you're comparing two cameras that have a difference in performance of 4 stops then that's an incredible amount and when shooting outside in available light on wide angle lenses then that is something that really matters in real-world situations. No, @kye I do not think they are lying. Where exactly did I write such a thing?! : ) The reference to Andrew’s forum rules was precisely what I called it: a slightly amusing, good-natured bit of irony meant entirely in a friendly spirit! Nothing more than that : ) BTW, one small correction: the result is 16 stops at SNR=2 and 17.2 at SNR=1, not the other way around. The Luna’s supposed 13-stop result is not really a valid 13-stop measurement either. CineD explicitly says that the aggressive NR prevented IMATEST from distinguishing the different patches correctly, thereby invalidating the result. They will not even include those figures in their database. So yes, their test demonstrates very clearly that the current I-Log implementation is seriously problematic. No disagreement there. But charts and real-world footage are two very different things. A chart isolates one particular variable under one very particular set of conditions. It does not shoot a street, a face, movement, changing available light, colour, texture, skin, foliage, fine detail or an actual scene. This is precisely why the comparative footage posted above matters. Objective measurements are useful, of course. But only for as long as they help us evaluate an image rather than begin evaluating it on our behalf. There are limits to everything, including measurable advantages and human perception. Someone worth $1.6 billion is sixteen times richer than someone worth $100 million. A huge objective difference, no doubt. Yet if both go out to buy a pizza, chances are they will end up buying exactly the same pizza ; ) The extra wealth only begins to matter when what they want to do actually requires it. What about someone worth $160 million vs $10 million...? The same : P And so on ; ) Likewise, an 8K image contains roughly sixteen times as many pixels as a 2K image. Another enormous and objectively measurable difference. Yet once both are projected onto a cinema screen and viewed from a normal seating distance, many people may struggle to tell them apart at all. The additional resolution only becomes meaningful when the screen size, viewing distance and image content actually allow us to see it. And @kye this is especially worth remembering in your case! LOL ; ) Considering how often you have quite rightly defended 1080p as being more than sufficient in the real world : ) Which is precisely why you know that a measurable advantage does not automatically become a meaningful real-world one. Probably better than most camera lovers : ) More is more. It is not automatically more relevant forever. Four additional stops can obviously be extremely valuable when a particular scene actually requires them. I have never denied that (take a look up there! ; ) But a four-stop advantage on a latitude chart does not mean that the resulting image will look four stops better, or even necessarily better at all, in every real-world shot. And this particular latitude comparison was not even entirely like-for-like. The Luna was tested in 8K25 I-Log at around 120 Mbps, while the Pocket’s headline result came from 4K25 D-Log2. CineD did see the same aggressive NR in the Luna’s 4K wide modes, correct, but they did not repeat the complete latitude test in 4K. Nor did they test the standard profiles, which they themselves suggest may currently be the better choice. It is also worth remembering that D-Log2 is only available on the Pocket’s 20mm wide camera. The 60mm module falls back to regular D-Log, where CineD measured 11.6 stops at SNR=2 and 8 stops of exposure latitude. By comparison, the Luna’s tele camera in its valid 8K25 I-Log mode measured 9.7 stops at SNR=2 and 5 stops of exposure latitude. So the gap there is about two stops in measured dynamic range and three stops in latitude. Still a clear win for DJI, certainly, but rather less apocalyptic than the headline comparison between the two wide cameras ; ) The digitally extended 120mm view naturally derives from that same 60mm camera too, so the Pocket’s spectacular D-Log2 figures cannot be extrapolated across its complete 20mm to 120mm shooting range. So the honest conclusion is still that DJI’s 20mm D-Log2 implementation completely and utterly defeats Luna’s current I-Log implementation in this particular lab test. That is not the same as saying that one complete camera system completely and utterly defeats the other. Sometimes all the technical blah blah blah is extremely useful. Other times it is worth close to zero and can even contaminate the evaluation, especially once people have already been told which image is supposed to win before they look at the actual footage. At that point, the chart is no longer informing the eye. It is replacing it ; ) Take another look at the real-world comparisons above. The difference is certainly not “complete and utter” there. In fact, the Luna’s 8K image often appears to resolve visibly more fine detail than the Pocket’s 4K, particularly in the comparisons of tele shots or whenever the image is cropped and magnified. That may not be attributable to pixel count alone, since lens performance, sharpening, noise reduction and the complete processing pipeline all play their part. Even so, whatever the precise combination behind it, the visible result is there, and in some of those shots the result may even go the other way, depending on what each of us values in an image. In these comparisons, the Luna’s additional resolution is not merely a spec on paper. So I think we are not very far apart on the measurements themselves. We simply disagree about the amount of territory those measurements allow “completely and utterly” to occupy ; ) E. :- ) Link to comment Share on other sites More sharing options...
kye Posted Wednesday at 05:50 AM Share Posted Wednesday at 05:50 AM On 8/4/2026 at 11:52 AM, Emanuel said: No, @kye I do not think they are lying. Where exactly did I write such a thing?! : ) The reference to Andrew’s forum rules was precisely what I called it: a slightly amusing, good-natured bit of irony meant entirely in a friendly spirit! Nothing more than that : ) BTW, one small correction: the result is 16 stops at SNR=2 and 17.2 at SNR=1, not the other way around. The Luna’s supposed 13-stop result is not really a valid 13-stop measurement either. CineD explicitly says that the aggressive NR prevented IMATEST from distinguishing the different patches correctly, thereby invalidating the result. They will not even include those figures in their database. So yes, their test demonstrates very clearly that the current I-Log implementation is seriously problematic. No disagreement there. But charts and real-world footage are two very different things. A chart isolates one particular variable under one very particular set of conditions. It does not shoot a street, a face, movement, changing available light, colour, texture, skin, foliage, fine detail or an actual scene. This is precisely why the comparative footage posted above matters. Objective measurements are useful, of course. But only for as long as they help us evaluate an image rather than begin evaluating it on our behalf. There are limits to everything, including measurable advantages and human perception. Someone worth $1.6 billion is sixteen times richer than someone worth $100 million. A huge objective difference, no doubt. Yet if both go out to buy a pizza, chances are they will end up buying exactly the same pizza ; ) The extra wealth only begins to matter when what they want to do actually requires it. What about someone worth $160 million vs $10 million...? The same : P And so on ; ) Likewise, an 8K image contains roughly sixteen times as many pixels as a 2K image. Another enormous and objectively measurable difference. Yet once both are projected onto a cinema screen and viewed from a normal seating distance, many people may struggle to tell them apart at all. The additional resolution only becomes meaningful when the screen size, viewing distance and image content actually allow us to see it. And @kye this is especially worth remembering in your case! LOL ; ) Considering how often you have quite rightly defended 1080p as being more than sufficient in the real world : ) Which is precisely why you know that a measurable advantage does not automatically become a meaningful real-world one. Probably better than most camera lovers : ) More is more. It is not automatically more relevant forever. Four additional stops can obviously be extremely valuable when a particular scene actually requires them. I have never denied that (take a look up there! ; ) But a four-stop advantage on a latitude chart does not mean that the resulting image will look four stops better, or even necessarily better at all, in every real-world shot. And this particular latitude comparison was not even entirely like-for-like. The Luna was tested in 8K25 I-Log at around 120 Mbps, while the Pocket’s headline result came from 4K25 D-Log2. CineD did see the same aggressive NR in the Luna’s 4K wide modes, correct, but they did not repeat the complete latitude test in 4K. Nor did they test the standard profiles, which they themselves suggest may currently be the better choice. It is also worth remembering that D-Log2 is only available on the Pocket’s 20mm wide camera. The 60mm module falls back to regular D-Log, where CineD measured 11.6 stops at SNR=2 and 8 stops of exposure latitude. By comparison, the Luna’s tele camera in its valid 8K25 I-Log mode measured 9.7 stops at SNR=2 and 5 stops of exposure latitude. So the gap there is about two stops in measured dynamic range and three stops in latitude. Still a clear win for DJI, certainly, but rather less apocalyptic than the headline comparison between the two wide cameras ; ) The digitally extended 120mm view naturally derives from that same 60mm camera too, so the Pocket’s spectacular D-Log2 figures cannot be extrapolated across its complete 20mm to 120mm shooting range. So the honest conclusion is still that DJI’s 20mm D-Log2 implementation completely and utterly defeats Luna’s current I-Log implementation in this particular lab test. That is not the same as saying that one complete camera system completely and utterly defeats the other. Sometimes all the technical blah blah blah is extremely useful. Other times it is worth close to zero and can even contaminate the evaluation, especially once people have already been told which image is supposed to win before they look at the actual footage. At that point, the chart is no longer informing the eye. It is replacing it ; ) Take another look at the real-world comparisons above. The difference is certainly not “complete and utter” there. In fact, the Luna’s 8K image often appears to resolve visibly more fine detail than the Pocket’s 4K, particularly in the comparisons of tele shots or whenever the image is cropped and magnified. That may not be attributable to pixel count alone, since lens performance, sharpening, noise reduction and the complete processing pipeline all play their part. Even so, whatever the precise combination behind it, the visible result is there, and in some of those shots the result may even go the other way, depending on what each of us values in an image. In these comparisons, the Luna’s additional resolution is not merely a spec on paper. So I think we are not very far apart on the measurements themselves. We simply disagree about the amount of territory those measurements allow “completely and utterly” to occupy ; ) E. :- ) You make excellent points, but it really comes down to your perspective. The detail from the 8K will be completely irrelevant, except in cinemas, where exactly zero people will ever watch this footage. The extra DR will absolutely be visible, even on smartphones, even with a film emulation applied, and especially because these cameras are designed for wide FOV shooting outdoors where there is a high probability of having huge DR (and even the sun) in the frame. We can look at images in controlled lighting, this is true. However under such conditions the vast majority of cameras from the last decade will look just fine. In fact, if the older cameras have the same bit-depth in their codecs but less DR then they might look BETTER than the modern cameras as the bits will be less stretched! So if we're going to compare modern cameras in very controlled conditions then the comparisons should include the vast hundreds of models released in the last decade or so, but if you do mention them then people go berserk because these older cameras fall short in other areas, and you can make a good argument that the controlled tests are nice but not entirely sufficient for evaluation. In which case, the stunning differences in DR between these cameras is now back in the consideration and the DJI is miles ahead of the Luna. To summarise that a bit, if you're taking everything into consideration then the DR really matters and if you're not then why aren't you comparing dozens of older cameras, and if you desperately want a tiny gimbal but only shoot in controlled conditions then isn't that a niche application so narrow that it really can't be justified to evaluate the cameras overall? In terms of me reminding people that lower DR 1080p cameras are fine for many practical tasks, this is true, but modern camera releases have basically nothing to do with practical tasks at all. There is no justification for 8K codecs. Period. The justification for 8K sensors that let you crop 2x for a 4K image is borderline but fine. Then there's 17K - seriously... Most camera discussions departed reality long ago and the discussions about this or that camera have the same rigour as discussing which super-hero can win against which other super-hero. Link to comment Share on other sites More sharing options...
