Jahleh Posted September 24, 2025 Share Posted September 24, 2025 It seems if you set Resolve color management like Sidney Baker-Green describes earlier on this page, duplicate your NRaw clips, rename the other as R3D, and take both to timeline, you get Red’s tone mapping and highlight rolloff controls to NRaw clips as well. They just work from Project settings to all clips at the timeline. As a bonus you have your regular NRaw raw controls as well. Link to comment Share on other sites More sharing options...
Danyyyel Posted September 24, 2025 Share Posted September 24, 2025 1 hour ago, Jahleh said: It seems if you set Resolve color management like Sidney Baker-Green describes earlier on this page, duplicate your NRaw clips, rename the other as R3D, and take both to timeline, you get Red’s tone mapping and highlight rolloff controls to NRaw clips as well. They just work from Project settings to all clips at the timeline. As a bonus you have your regular NRaw raw controls as well. If it is true, for me, the pefect workflow for RAW use, will be the 4k Nraw converted to RED raw. As it should be around 350 Mbs, which is very good for RAW. The only thing I don't know is how do they get this from a 6k sensor. In Gerald Undone, it did look a bit mushy, but I don't zoom 400% in my shots. The 4.1 k from my Z9 is perfectly usable. But in this case it is just half of the pixel. jbCinC_12 1 Link to comment Share on other sites More sharing options...
Jahleh Posted September 24, 2025 Share Posted September 24, 2025 Tried it myself after checking Sidney's video about NEV to R3D conversion, and out of curiosity copy pasted my NRaw project clips to project created with Red settings. The NEV to R3D clips look a bit like Nraw with RED LUTs and Nraw clips look the same than in usual project created for NRaw. Hopefully the ZR R3D colors look as nice as in many YT videos. With R3D you get chroma NR though and Red's ISO settings in Raw panel. Just wanted to get familiarised what editing R3D would mean to draw conclusion whether to try ZR as a 2nd cam or not. Here are the RED project settings. The magic being Output DRT set as RED IPP2 which unlocks Output tone map and Highlight roll off. Input colour space does not matter, and Timeline cooler space can be changed to DWG or something else. Link to comment Share on other sites More sharing options...
stephen Posted September 25, 2025 Share Posted September 25, 2025 Here is my understanding about 4K NRAW in Nikon Z6 III / Zr and Z8. I don't have the camera just gathered info from Internet. Correct me if I am wrong. Z8 as others already mentioned uses two different methods to get 4.1K NRAW / RED RAW from 8K. Gerald Undone gets a lot of criticism on this forum but he mentioned those methods in his Z8 review while many other reviews don't. Typically for all 4.1K from 24fps to 60fps and 120fps Nikon Z8 uses line skipping with all artifacts that come with this method. Only for 24p,25p and 30p Nikon Z8 has a special EXTENDED OVERSAMPLING mode. This method of course gives more detailed / better image. It is not without it's own issues. Those issues becomes logical when we ask ourself how do they over sample a RAW video stream and at the end get another RAW video stream ? https://alikgriffin.com/nikon-z8-color-shifts-4k24p-nraw/ https://www.youtube.com/watch?v=YyyiKwlRXCA IMHO this small green cast in the shadows will be easy to fix. Still will require some work and time. The extended oversampling is not available for 60p and 120p. In this case APS-C crop is an option for better non line skipped image. Nikon Z6 III / Zr 4K NRAW is line skipped, but 6K full sensor width NRAW has only slightly higher bit rates when shooting with NORMAL quality. They are comparable to Sony Intraframe codecs. IMHO for RAW video 24Mpx sensors represents the best balance between resolution and speed. Too many mega pixels and large portion of them should be discarded somehow for 4K RAW video or we have to deal with huge 8K filesand do the down scaling in editing. 12Mpx sensor on the other side actually has less pixels than theory suggest are needed for perfect 4K DCI debayering. Rumors about what Sony using probably a fully stacked 24Mpx sensor in next FX3 make sense. Nikon Z6 III / Zr Achilles heel in NRAW so far is dynamic range / latitude. All tests of Nikon Z6 III so for show 1 stop less of both dynamic range and latitude compared to sensors in Nikon Z8, Sony 12Mpx one in ZV-E1, A7S III, FX3, FX6, 50 MPx one in A1, Sony Venice 2. They all have dynamic range between 12 and 13 stops and 8 stops of latitude. I really hope Red Raw better log profile, chroma noise reduction and 6K to 4K resolution down-scaling will give one more stop of DR and make this sensor on par with the rest. After all same sensor in non DR Boost mode in Panasonic S1 II when using ProRes RAW codec reached 9 stops of latitude. It is hard to believe Nikon used some trimmed down version of the same sensor. x265 10bit 4:2:0 in latest Nikon hybrid cameras is visibly of lower quality compared to RAW video but it may turn out to be perfectly fine for most tasks and most people. Nikon x265 10 bit 4:2:0 may turn out to be as good as other brands x265 10bit 4:2:2. I don't know until I try it myself or see a detailed test. Between Nikon Z6 III and Zr I would choose Z6 III. It has good EVF, shutter, Full HDMI port and is a true hybrid. Internally for video they are practically the same and by renaming NRAW video files we get access to the better RED RAW pipeline and color science in Resolve. Current Nikon Z6 III price in a local photo shop is 2050E. Nikon Zr price is 2375 Euro and camera is not yet available. Nikon Z6 III doesn't sell well, price was decreased significantly from original 2500-2800 Еuro most likely because it doesn't offer significant upgrade for photo shooters and all those talks about lower dynamic range. Second hand Z6 III bodies pop up locally from time to time in the 1700-1800 Euro range and still with warranty. IMHO Nikon Z6 III and Zr are for people who want to shoot RAW video. Theory and practice tell us 10bit 4:2:2 is equally good but sometimes we just want something 🙂, for whatever reason. 12bit NRAW with RED RAW hack is really a great choice because it offers fairly compressed industry standard RAW codec. ProRes RAW has higher bit rates. I edited in Resolve some sample NRAW video clips from Nikon Z8 and Z6 III and can say that if video is exposed properly there is no need of noise reduction. Editing, color correcting and grading them is not more difficult or time consuming than SLog3 internal footage from Sony. They take more space but still nothing crazy and for certain projects and people it could be acceptable. Bottom line: If you want to shoot RAW Nikon Zr, Z6 III and Z8 as well are great options, first two being quite affordable. I am worming up to the idea to get Nikon Z6 III. Use it some time and compared it with Sony ZV-E1 which has one of the best Sony sensors for video. Then eventually keep one of the two and sell the other. gethin and Jahleh 2 Link to comment Share on other sites More sharing options...
Jahleh Posted September 25, 2025 Share Posted September 25, 2025 Pretty good summary. After shooting NRaw almost a year now with Z6iii I can relate to almost all of that. According to Gerald and Cinematools Z6iii FX 4k NRaw is line skipped but DX is pixel to pixel, which is the reason why in Cinematools’ Z8 vs Z6iii comparison the 4k120p with Z6iii looks better. The only extra step with NRaw IMHO is to use Resolve to trim the NRaw files and export important parts via Resolve’s Media management. If you do the Red Raw hack after export, Resolve won’t accept the renamed files. If you do the hack first, Resolve won’t export the trimmed R3D files. Have not tried Red CineX pro though. Hopefully it or some other method works with the Zr’s R3D NE Raw files. gethin 1 Link to comment Share on other sites More sharing options...
Emanuel Posted September 26, 2025 Share Posted September 26, 2025 Link to comment Share on other sites More sharing options...
ND64 Posted September 26, 2025 Author Share Posted September 26, 2025 ZR 4k raw is not line skipped. Its read out speed is the same as 6k raw. So it uses the whole pixels, but some kind of digital downconversion happens that has SN ratio of 3k image but resolution of 4k image, with a downside of some high frequency aliasing. Link to comment Share on other sites More sharing options...
Ilkka Nissila Posted September 26, 2025 Share Posted September 26, 2025 The extended oversampling ON/OFF (in the Z8/9) only affects 4K h.265 and Prores 422 HQ video at 50 and 60 fps and it should not affect raw video formats. Link to comment Share on other sites More sharing options...
Danyyyel Posted September 26, 2025 Share Posted September 26, 2025 6 hours ago, ND64 said: ZR 4k raw is not line skipped. Its read out speed is the same as 6k raw. So it uses the whole pixels, but some kind of digital downconversion happens that has SN ratio of 3k image but resolution of 4k image, with a downside of some high frequency aliasing. On Gerald Undone example, it looked not that good. But I think it is at pixel level!!! Link to comment Share on other sites More sharing options...
ND64 Posted September 26, 2025 Author Share Posted September 26, 2025 21 minutes ago, Danyyyel said: On Gerald Undone example, it looked not that good. But I think it is at pixel level!!! If you gain something in SN ratio, sure you lose something in details. Its almost impossible to extract "true" 4k bayer from 6k bayer. Link to comment Share on other sites More sharing options...
Emanuel Posted September 26, 2025 Share Posted September 26, 2025 On 9/25/2025 at 6:44 PM, stephen said: Gerald Undone gets a lot of criticism on this forum but he mentioned (...) Nothing against the man (never had, and my previous posts speak for themselves, so I cannot be under any suspicion — quite the contrary : P). But Stephen, for someone who claims to be just a simple tech reviewer making a living out of it, while simultaneously having nothing to do with filmmaking, and then someone else sees Philip Bloom promoting GU LUTs (!) — as with the most recent DJI bird (Mini 5 Pro)... well, that really makes me laugh! : ) And yet, to still be frank, never has a PB video looked so bad :- ) Link to comment Share on other sites More sharing options...
Davide DB Posted September 27, 2025 Share Posted September 27, 2025 Do you know if anyone has posted raw files to download? I would like to get an idea between the C50 and the ZR. Link to comment Share on other sites More sharing options...
jbCinC_12 Posted September 28, 2025 Share Posted September 28, 2025 Rumored SSD recording via USD by Firmware update: https://thenewcamera.com/rumors-nikon-zr-to-gain-ssd-recording-support-via-usb-with-future-firmware-update/ Link to comment Share on other sites More sharing options...
ND64 Posted September 28, 2025 Author Share Posted September 28, 2025 4 hours ago, jbCinC_12 said: Rumored SSD recording via USD by Firmware update: https://thenewcamera.com/rumors-nikon-zr-to-gain-ssd-recording-support-via-usb-with-future-firmware-update/ Among all the firmware requests by YouTubers and RED shooters, this one was almost out of the radar. Which tells me is an indirect response to whining about raw file sizes. Which means an internal lower bitrate R3D NE became even less likely. jbCinC_12, ArashM and Danyyyel 3 Link to comment Share on other sites More sharing options...
jbCinC_12 Posted September 29, 2025 Share Posted September 29, 2025 5 hours ago, ND64 said: Among all the firmware requests by YouTubers and RED shooters, this one was almost out of the radar. Which tells me is an indirect response to whining about raw file sizes. Which means an internal lower bitrate R3D NE became even less likely. You got a point there. Nevertheless, it's a purchase I'd like to get - for a novice videographer. Link to comment Share on other sites More sharing options...
Danyyyel Posted September 29, 2025 Share Posted September 29, 2025 23 hours ago, ND64 said: Among all the firmware requests by YouTubers and RED shooters, this one was almost out of the radar. Which tells me is an indirect response to whining about raw file sizes. Which means an internal lower bitrate R3D NE became even less likely. Yep, looks more like it. It is good if they supply this as you can get a 2TB for about same price as a 512 GB CFexpress card. But you are still left with gigantic files if you want to achieve your work. Perhaps the best solution would be in Nraw normal, then rename them to RED. Or use the Nikon RED luts. Link to comment Share on other sites More sharing options...
Danyyyel Posted September 29, 2025 Share Posted September 29, 2025 On 9/26/2025 at 10:56 PM, Emanuel said: Nothing against the man (never had, and my previous posts speak for themselves, so I cannot be under any suspicion — quite the contrary : P). I still have problem with Gerald Undone, and this is exemplified with Canon C50 vs Nikon ZR review. I don't question his numbers, but how he interpreted them for his bias. Man pissed on the ZR t every corner, but excused the worst or the worst for Canon. The simple example is the ZR micro hdmi vs Canon C50 lack of IBIS. Yes it is an inconvenience the ZR doesn't have a full size hdmi, but it can be remedied with a 100 USD cage plus lock. But what about the lack of IBIS, you would need a full set of big supporting gear. Either a tripod, shoulder mount or gimbal. But hey, his excuse is that he talked with some first AC, and they told him that they prefer the sensor to be locked, as if the C50 principal use will be on movie sets!!!!! He is revolting, how dare Nikon put cinema on the ZR, but does he think that the ZR/C50/Fx3 will be primarily use on cinema sets!!! Is he crazy, 99.9% of their use will be in events, corporate videos, weddings, reportage, social media content creation etc. At the top you will find them used on small to average advertising production, short films, small to no budget films. And in rare case as specialist camera like crash cam, in higher end production. But again in those 99.9% cases, stabilization is a big big plus for those production. But hey, Nikon dared to put Cinema on the ZR. I mean a camera that has better image than 90% of digital camera just 5 years ago. Emanuel 1 Link to comment Share on other sites More sharing options...
Danyyyel Posted September 29, 2025 Share Posted September 29, 2025 After all the fuss about the ZR h265, with some youtubers including Gerald Undone, high claim that the ZR h265 was unusable. I was very worried, but also perplexed because, even with my D750 24mbit 1080p footage, the h264 and nowadays Nikon H265 had been very robust and good. But until now, very few actual footage in h265 to make an opinion. Until I saw this test. Guess what, all those BShitters were exaggerating as always dunking on Nikon. In this Chinese test, from about 15.30, you have nearly every footage in h265 and the quality is good, even the 4k 120 fps in apsc. I can see every hair of those girls dancing even with YouTube compression on my 65 inch TV. I don't think you need much more for your Bride or CEO shots. Link to comment Share on other sites More sharing options...
stephen Posted September 29, 2025 Share Posted September 29, 2025 I noticed that in Cinema Tools comparison between Nikon Z6 III and Sony FX3 in the first section both cameras use x265 codecs. Watched it on big OLED TV and didn't notice any visible differences in color. IMHO Nikon x265 is perfectly usable option if maximum compression and smaller files are needed. If still in doubt about x265 quality, ProRes 10 bit 4:2:2 at 4K is good alternative. Here are the compression ratios of all Nikon codecs in Z8. We can easily extrapolate them to Z6 III / Zr https://zxi.mytechroad.com/blog/photography/nikon-z8-prores-prores-raw-bitrate-and-compression-ratio/ NRAW / RED RAW normal has a compression ratio of 7.5 which is comparable to BRAW 8:1. NRAW / RED RAW high quality - 4.5 compression ratio comparable to BRAW 5:1. Those are very good compression ratios. ProRes HQ 422 10Bit - 5.2 ProRes RAW - 2. We have several RAW or non RAW codecs and compression options. Last Z6 III firmware version 2.0 brings shutter angle. Z6 III has wave form too. The few options that are missing are open gate, anamorphic desqueez and LUTs. I don't need the first two and can have the last one with external monitor. Overall Nikon Zr / Z6 III are great cameras and quite affordable compared to the image quality in video they give. Danyyyel and Jahleh 2 Link to comment Share on other sites More sharing options...
ND64 Posted September 29, 2025 Author Share Posted September 29, 2025 The h.265 itself is not the problem. Its that you can't turn off the NR with h.265, and in low light its too much. Nikon didn't change this even after all firmware updates they did for Z9/Z8/Z6III, so its safe to say its not going to happen with Expeed 7. Probably because power consumption will be noticeably higher if the encoder has to compress noisy image. Ninpo33 1 Link to comment Share on other sites More sharing options...
