kye Posted April 30 Share Posted April 30 For those interested in small setups, in modestly priced gear, in non-clinical rendering of images, in very fast lenses, in vintage lenses, or older equipment, we exist in a space that has no quantitative reference. There are no numbers to look up and understand things from. It applies to the equipment: Questions like "how sharp is that lens?" don't have an answer (that is intuitive anyway - MTF charts aren't intuitive and often aren't reliable or even available). Even if it did, that answer would only be true at one aperture setting, and even then, is only true for the middle of the frame or the edge of the frame, but not both at the same time. If we shoot at base ISO with a 4K camera then we'll likely get an image with roughly 4K resolution, but at higher ISOs the effective resolution will likely drop due to ISO noise, NR, compression, etc. If we use filtration, like diffusion filters, then these lower the effective resolution of the image. It's literally what they're designed to do. How much do they do this though? Not only is there no published answer to this, but the answer changes depending on focal length, sensor size, etc. It applies to the look we're creating: Any colourist working creatively will be trying to create an image with the right amount of resolution / sharpness / noise / etc, not just "the sharpest" or "the highest resolution". How much is desired? What are the references? I've been struggling with many questions from my own equipment and projects, including: My TTartisans 17mm F1.4 is less than half the weight of my Voigtlander 17.5mm F0.95, but the TT is quite soft at F1.4. How soft is it though? Is it too soft? If I want to shoot low-light with the GX85 (which has terrible higher-ISO NR) then what ISO setting is too soft, and then which lenses do I need to use in which environments to get enough light into the sensor? My Takumar 50mm F1.4 on my generic M42-MFT speed booster has pretty soft edges, but how soft? You'd think the solution to these would be to look at the footage and decide, but (for me at least) it's a double-edged sword because I also don't know what final images I want! I have spent a good amount of time looking at Hollywood films and big budget TV shows (see the original The Aesthetic thread) but apart from just going "I like that" and "I don't like that" we have the problem once-again of there being no way to quantify things. Saying "this show is softer than that show" really doesn't help. My solution is to reference things back to film. I originally did this with my Panasonic GF3, which shoots 1080p so soft you could cut it with a wet noodle, by comparing it to the presets in the Film Look Creator tool for 8mm and 16mm film I concluded that when the GF3 didn't show macro-blocking due to the (very low) bitrate, it was about the same as 8mm film. This was actually a really useful reference for me, because the associations I have for 8mm and 16mm film are quite useful. 8mm film has an aesthetic that is very nostalgic and low-fi, but was never good enough for TV shows, let alone the cinema. My new plan is to reference everything back to film, across quite a number of ways... Texture, which is what I've talked about so far: - I will be trying to "map" my lenses and cameras and codecs to a specific resolution of film (16mm, 35mm, somewhere in between) - I will be trying to "map" my aesthetic preferences to film too, like wanting a certain project to have the resolution of 16mm for example, but further than this - the size and amount of grain can also be a useful reference. These are useful references for me because a lot of the aesthetic references of cinema I have were actually shot on film and so by associating these things back to film it's a relevant reference, not just some arbitrary scale that isn't directly related. Dynamic Range and Contrast: - How does the DR from the GX85 look when put through an image pipeline in Resolve compare to the contrast of a 250D -> 2383 process? - What about the iPhone vs a 16mm process from the 90s? or a B&W process from the Italian Neorealism or French New Wave period? Contrast and DR should be relatively easy to match to various film stocks by just shooting some over/under exposure tests and adjusting my standard Resolve colour pipeline to match what is in the spec sheets. Speaking of spec sheets, not only do the spec sheets for motion picture film contain the Sensitometric Curves that show DR and contrast, but they also contain the MTF curves too as a reference for resolution. When it comes to resolution you don't need to look at the charts though - I asked some film geeks I know to comment on the FLC presets and they said that the 8mm / 16mm / 35mm presets in the Grain panel have about the right amount of image softness and amount of grain (but that the character of the grain isn't accurate), so the FLC is a reasonable reference for the texture of film in a very broad sense. What else? Image stability is another one. 8mm film cameras were larger than modern compact cameras so were more stable with the lenses they were normally fitted with, but 8mm had pretty terrible gate weave (alignment from one frame to the next) so having micro-jitters from hand-holding is compatible with the look. Whereas 16mm would have had more mass and less gate weave but at least at first would have probably been shoulder mounted or on a tripod, so some types of shots / angles will be more compatible with the aesthetic than others. Depth of field is another one. Lots of people think the "Super 16mm look" just means deep DOF, but it's more nuanced than that, as the lenses typically used would have some separation in low-light when focused closer, but due to the lenses at the time the shots might have been softer wide-open, so that's another relationship to understand. There are lots of other parameters that make an image that aren't covered here, but I am finding that getting some kind of reference for texture and contrast fills a very large gap in the landscape for me. The goal isn't to accurately emulate anything, its to develop a keener understanding of the spectrum these things exist in. Where I'm hoping to get to is to be able to develop summaries like: The GF3 is about 8mm at base-ISO, which during the day is equivalent to <some particular F-stop>, so I can put basically any lens sharper than 8mm onto it and the result will still look like 8mm. I can hand-hold this tiny camera with an acceptable level of shake up to about Xmm and it'll still fit the 8mm vintage / amateur / nostalgic vibe. The GF3 is tiny but once you add a lens that is larger than a pancake then I may as well use the GX85, so the only sensible lens is the 15mm F8 bodycap lens. Any other combo doesn't make sense. (This is an actual example I've worked out through testing). The GX85 at base-ISO is equivalent to <film size of some kind.. 16mm? 24mm? 35mm? 50mm?> which requires lenses of <F-stop> during the day and <F-stop> in well-lit night environments. This amount of resolution is suitable for projects with a vibe of <gritty street? vintage? night cinema? high-end commercials? etc?> but not other vibes. (This is still yet to be tested, but once I've worked out the camera then certain lens combinations will reveal themselves to make sense and others will obviously not work) iPhone? Where does it sit in all this? It has huge resolution and very strong codecs (4K Prores HQ or even Prores RAW) but poor DR and even worse ISO performance. GH7. What are the aesthetics I want to create that I can't create with the above (because the above is too limiting). What lenses and shooting styles and approaches are required for these aesthetics? The ultimate thinking is developing "constellations" where there is compatibility / alignment between: a camera, one or more lenses, certain shooting situations and techniques, an image pipeline, and a target aesthetic. I've been working on finding these "constellations" by starting at the camera and working forwards, but also by starting with the end aesthetic and working backwards, and I've identified a number of partial matches, but I think that by relating everything back to motion picture film, I can make more progress fitting the pieces together. Aussie Ash, Emanuel and TrueIndigo 2 1 Link to comment Share on other sites More sharing options...
fuzzynormal Posted April 30 Share Posted April 30 16 hours ago, kye said: just going "I like that" and "I don't like that" we have the problem once-again of there being no way to quantify things. Good write up! I've run the gauntlet as well. My conclusion is that what you wrote above is the thing that'll get me through, so I accept it. And why not? kye 1 Link to comment Share on other sites More sharing options...
kye Posted May 1 Author Share Posted May 1 7 hours ago, fuzzynormal said: Good write up! I've run the gauntlet as well. My conclusion is that what you wrote above is the thing that'll get me through, so I accept it. And why not? An additional barrier that my above approach helps me side-step is the disparity between technical resolutions and aesthetic preferences. What I mean by that is that when we talk about resolutions (4K / 1080p / 720p / 576i / 480p etc) there are a bunch of associations with these. No-one is linking these with aesthetic decisions - no-one says they're shooting for the "480p look"! Any discussion of these is typically in the "more is better" context, or at least in the "1080p vs 4K" realm. However, my image analysis indicates that there are quite a lot of images that are deliberately created with an aesthetic that aligns with 720p or lower! Therefore, if I tried to "map" aesthetic preferences to technical resolutions I would be fighting all these connotations I have from these technical resolutions. However, linking these things to film doesn't have nearly the same associations. People don't talk about 16mm as being "crap" whereas they sure do if you're talking about a 720p camera or timeline resolution. The other challenge I have with the "I like that" and "I don't like that" is that I don't really know what that means. If I can look at an image I like and work out it's equivalent to 20mm film (if such a size existed) and I worked out that a camera/lens combo was also around 20mm film equivalent, then I could "link" that camera/lens combo with that aesthetic, or even that reference. Alternatively, if I shot with my GH7 in Prores HQ (which is likely to be around 50mm film equivalent or more) and a lens that is in that ballpark, but I wanted that 20mm film equivalent look, then I'd know to just adjust the Film Look Creator to align to the 20mm film equivalent settings, and I'd have that look. Speaking of using the Film Look Creator to adjust to various sizes of film, it comes with presets for 8mm, 16mm, 35mm and 65mm, but I did some interpolation and came up with the following values for intermediary values, so it can be used for in-between things too. From the initial image analysis I've done so far, lots of stuff shot on desirable vintage cinema lenses is often in those in-between areas, so this isn't just about using the FLC grain panel to emulate film, it's really about using it to emulate the softness of the final image, which is a result of the combination of: - haze / smoke in the scene - filters (such as diffusion filters, haze filters, beauty filters, OLPF filters, etc) - lens sharpness at a given F-stop - sensor resolution in the readout mode it's in - image processing (such as NR, sharpening, etc) - compression - etc. If you're emulating lenses then the edges might also be softer than the middle, so that would be a separate thing, but you can get quite far using a combination of: - Lens correction in the Edit tab - Round power-window to adjust vignette - Round power-window in combination with Tilt-Shift Blur OFX to emulate edge softness Link to comment Share on other sites More sharing options...
fuzzynormal Posted May 1 Share Posted May 1 Well, I appreciate the mental exercises you're putting yourself through. The questions are interesting. Still, at the end of the day everyone's process is a bit different. Since arts and crafts are subjective, quantifying how those two things merge is only useful up to a point, imo. And, of course, that point is usually wildly different for all of us doing this stuff. 14 hours ago, kye said: The other challenge I have with the "I like that" and "I don't like that" is that I don't really know what that means. I'd ask, do you really wanna chase what that means? It might always be ephemeral as context changes; slipping out of reach. And shouldn't such meaning remain in the realm of intuition anyway? Then again, maybe not. At least not for everybody. Perhaps being in a space without firm answers isn't interesting to you? Maybe striving for technical contentment at the limits of understanding is the thing you enjoy. That's cool too. Engineering can be artful in it's own way as well. Either way, keep poking around. kye 1 Link to comment Share on other sites More sharing options...
kye Posted May 2 Author Share Posted May 2 11 hours ago, fuzzynormal said: Well, I appreciate the mental exercises you're putting yourself through. The questions are interesting. Still, at the end of the day everyone's process is a bit different. Since arts and crafts are subjective, quantifying how those two things merge is only useful up to a point, imo. And, of course, that point is usually wildly different for all of us doing this stuff. I'd ask, do you really wanna chase what that means? It might always be ephemeral as context changes; slipping out of reach. And shouldn't such meaning remain in the realm of intuition anyway? Then again, maybe not. At least not for everybody. Perhaps being in a space without firm answers isn't interesting to you? Maybe striving for technical contentment at the limits of understanding is the thing you enjoy. That's cool too. Engineering can be artful in it's own way as well. Either way, keep poking around. Perhaps the risk you are hinting at is that making things technical will limit them creatively? This is a valid concern, and we know that people can't be analytical and also creative at the same time cognitively, so switching into analysis mode is opposed to creativity in that moment. However I think this is a challenge that we're all already facing and dealing with (in our own ways and to our own various levels of success). The approach I take is: Do the analysis and technical work between projects. This involves doing things like latitude testing, lens testing across apertures, testing codecs and colour spaces, testing colour grading approaches and techniques, comparing export codecs and settings, etc. Save the results of these tests in an easy-to-reference place (I save stills that are labelled clearly). Putting your creative / emotional / aesthetic hat on, assess the results of those tests aesthetically. How do they make you feel? Which ones do you like or dislike and why? When shooting on real projects, remember what you learned from your assessments and make sure the tech is setup right (camera set to 24p not 30p, right resolution / codec / colour profile, etc), and then forget about it and think and act creatively. Great artists know the technical aspects of their craft but are able to move beyond them once they're in place and act creatively. Roger Deakins isn't thinking about ARRI vs RED or thinking about lenses and which aperture to use when he's operating the camera, but he sure as hell has looked at these things and formed his conclusions and made these decisions. If you swapped lenses on him he'd sure notice and not be happy about it - he chose what he chose for good reason. That's how I think about it anyway. I've actually done some initial tests (drawing from my vast backlog of previous camera tests) and worked out the following: GH7 set to 1080p Prores HQ is about equivalent to 35mm film (This might actually be a little low - this was 1080p footage on a UHD timeline so it'll have been softened in the upscale.. however, what this means to me is that it's fine for my purposes and although not as sharp as C4K etc, it's sharper than I need it to be and so I can take the win with storage sizes and editing performance) My Voigtlander 17.5mm @ F0.95 is about 23mm, and my TTartisans 17mm @ F1.4 is about 18mm Not only does this confirm the TT is softer than the Voigt, but I actually think that for lots of my projects a 16mm equivalent image is perfectly fine, so just as I had hoped, the TT has now moved from "oh, that's soft - is it too soft? I don't know" to "it's better than 16mm so probably fine for grittier or dreamier aesthetics" These are both wins in my book! I suspect most people can just look at the images from a setup, see them and assess them on the spot, and then move on using that information. Unfortunately, that isn't me. Link to comment Share on other sites More sharing options...
kye Posted June 13 Author Share Posted June 13 Now I have mostly progressed my GX85 Super-16mm "conversion" I am turning back to a more generalised look at film and The Aesthetic as it pertains to cinema. My next step is to convert my S16 emulation into a 35mm emulation, which shouldn't be that hard as it's the same stuff but just using more of it, so turning down the grain and backing off the softening and size of halation and bloom etc. In order to get my bearings I've collected a bunch of frame grabs from cinema over the decades, and some fascinating things have emerged. Observation One: Film doesn't look like it's gotten cleaner and sharper This is what people say, but when scrolling through the references, you can find things like this from 1952's Bend of the River: and then things like this from 1994s Speed: Obviously you need to be smart about things, so both these shots are likely to be locked off, focus wouldn't be missed, lit naturally and exposed properly, etc. There are lots of shots from Speed that are soft, but it's an action movie so lots of them are probably motion blurred or the action was impacting how well that frame was focused etc. Luckily, License to Kill from 1989 will get us back to safe ground with some nice sharp images: But how are these images possible all the way back then? One thing that comes to mind is that when consulting Kodaks excellent Chronology of Film page, you see that the negative stocks started off as very low sensitivity and increased over time, so it's like comparing the high-ISO of todays cameras to the native ISOs of past cameras. Observation Two: Images look like they've gotten less worse The further back you go, the more you find shots that should be sharp but just aren't. The example above from 1952 was a real outlier, as most of the images from that time looked more like these from 1955s A Bad Day at Black Rock: I suspect the quality of the lenses. All the above looked like wider shots, so maybe that lens wasn't so good (wider lenses are harder to make). Maybe it wasn't at its sharpest F-stop. A lot of the sharpest images across the frame grabs I looked at were close-ups, and I suspect back then a 50mm at it's sharpest aperture and focus distance was a lot better than a wider lens at whatever F-stop and focus distance was required for the scene. Check out these grabs from 1955's The Seven Year Itch: Monroe was at her height of popularity so there's no way she's getting the beat-up lenses from the rental company or a camera team that doesn't know what they're doing. I can't think of any reason these two particular images would be softer than the technology at the time would have allowed. By 1971 things seemed to have gotten a lot more consistent with Diamonds Are Forever: Then if we fast forward to the last few years, we get films like 2024s Trap, which looks quite sharp and even approaching a digital look: but still has films over-emphasis of high-contrast edges: and it's a similar case with 2023's Poor Things which can look quite sharp: but on wides it still has that film look: and it's only when the lenses get crazy that the edges start looking more vintage again: Anyway, lots of food for thought, but it's almost like the sweet spot of film has remained relatively similar in performance but has gotten drastically wider as you can now get images that are that sharp and clean in much less light and across a vastly wider range of lens focal lengths and apertures. Another variable is that prior to digital projection, the final image had to go through many more layers of film than it has to now. Back in the day the image pipeline was something like: negative → interpositive → internegative → release print, rather than just negative -> scan, and it's not like our projection lenses haven't gotten better now too! Let me know if you can think of any more variables that I didn't mention, but it's like we're looking at lenses get better and film be useful in more situations, rather than it get "better". Emanuel 1 Link to comment Share on other sites More sharing options...
Emanuel Posted June 13 Share Posted June 13 Great posts, sticky this! Your contribution here @kye is priceless and a fine example for everyone, myself included : ) It's always a pleasure to read your thoughts! :- ) Keep going… I’m linking to it elsewhere, BTW ; -) Food for my trainee students. : D kye 1 Link to comment Share on other sites More sharing options...
eatstoomuchjam Posted June 13 Share Posted June 13 There are so many variables when it comes to how you're viewing the film images. Negative film has wide dynamic range and soft highlight rolloff. Positive film has much more limited dynamic range and pretty hard highlight rolloff. Faster film tends to be grainier. Filmmakers with a big budget would be choosing their film stock for aesthetic/style reasons. Imagine shooting Taxi Driver on the same technicolor low-grain film stocks that were used for The Sound of Music. Bright saturated colors would have been terrible for Taxi Driver. Scorcese chose less gritty films than some others might, but Travis Bickle lives in a relatively desaturated/dark world and that's for the best. Filmmakers with low budgets were likely to choose the cheapest film stock they could and some even used the leftovers that weren't exposed from the productions of others. Or in the case of John Waters, whatever film he could steal. Next, as you said, for these classic films, you aren't necessarily looking at scans from the master negatives. You might be looking at scans of the release prints. They didn't always save the masters. It could even be a second or third-generation print. Then to add to that, the way the film gets transferred matters. Did they scan the original negatives or a print? How was it scanned? Was the film being scanned perfectly flat? What compression was used on the scanned image? Was it scanned or telecine? If telecine, which projector lens was used during the telecine process? As far as the lenses, razor sharp lenses have been available for a long time, including in the 50's, and including wide angles. Lots of vintage wide angles are a little softer in the corners, but they can be very crisp in the center... but fashion applied in many eras of film, just as it applies now. For some of the softer images, especially close-ups, they might have been using a net filter, made more complicated by the net filter potentially being mounted behind the lens instead of in front. https://www.provideocoalition.com/the-secret-life-of-behind-the-lens-nets/ I'm sure I'm forgetting more things too. Like almost anything going through an analog to digital process, there are about a bazillion variables to consider along the way. kye, Emanuel and mercer 3 Link to comment Share on other sites More sharing options...
kye Posted June 16 Author Share Posted June 16 Good points from @eatstoomuchjam. That's why I went for the sharpest frame grabs I could find - considering the range of variables involved a soft looking grab might have been a scanning issue or provenance issue or there might have just been movement in the frame. Now that I've done that analysis I'm wondering where to from here. One thing I can do is to take my S16mm emulation and scale it 50% of the size and then adjust my power grade to match the grain and halation etc, and see if that looks like a 35mm scan (it should - that's how film works!!). If so then I can proceed on that basis, but if not then I might have to get feedback and iterate again to get something appropriate. Once I've got that sorted out then I should be able to interpolate / extrapolate the parameters that needed changing and get a range of looks that vary from 8mm up towards 16 and 35mm and then beyond. At that point it'll be interesting to explore different combinations of: Film sharpness and grain Lens emulations Filtration (diffusion etc) From these I should be able to get a range of common looks, inspired by different combinations like: 8mm shot on-the-go Bolex 16mm camera shot at night The look: Faster 16mm film with mediocre prime lenses shot wide open Krasnogorsk-3 16mm camera during the day The look: Slower / clearer 16mm film with standard zoom lens (17-69mm F1.9 Zenit) shot stopped down 35mm film camera with master primes, or Cookes, or Panavision C-Series & T-Series, etc (I have a few lens tests with many of these lenses so should be able to recreate something that smells vaguely right by changing the vignetting, edge softness, CA, bloom, etc) I'd imagine that certain combinations will be more convincing than others, as we've likely come to associate certain image attributes together. Obviously I won't be recreating them faithfully, but simply by taking inspiration from these a range of looks can certainly be developed. One thing I have noticed is that lens designers often get custom requests from film-makers to tune a set of lenses to have a customised response. For example maybe they want the speed and bokeh from a set of lenses to remain as-is but want more/less horizontal streaks and much more diffusion, etc. This is noteworthy because if film-makers are are interested in different combinations of lens attributes then I don't feel like I need to try to get a perfect emulation of one lens or another either - it doesn't matter so much when you view it from a creative perspective rather than engineering perspective. This is why my goal in my S16 emulation project wasn't to emulate this or that film stock, but rather to get something that looked like it was shot on some unknown stock with unknown provenance (e.g. maybe it's expired or wasn't stored well etc). eatstoomuchjam 1 Link to comment Share on other sites More sharing options...
Emanuel Posted June 21 Share Posted June 21 Well stated @eatstoomuchjam @kye :- ) eatstoomuchjam and kye 2 Link to comment Share on other sites More sharing options...
