Repairing mirrorless cameras - the truth about each brand's build quality
Andrew - EOSHD
Leica M Typ 240... 2012, this was before Panasonic got more involved with making Leica's stuff.
I'll give this a 10/10. The whole motherboard slides out really easily. I baked it in the oven to bring it back to life from completely dead. The solder needed a reflow apparently. 200 degrees C at 7 minutes did the trick. Custom chips all over the place. Utterly beautiful mechanically and in terms of the quality of connectors, cables, lots of metal parts and brilliantly designed internals.
Next up another older camera, Nikon D700.
Very impressive motherboard with separate analogue to digital converters.
Probably why the colour science still has the edge on the newer sensor designs with their inline on-chip A/D.
Nikon own branded chips.
By contrast in the newer Leica Q...
It's actually a Samsung.
And the lens relies on a LOT of digital correction, so it's certainly not in same league as a Leica M when it comes to the quality of parts or optics.
End result in terms of the images is very nice though.
We'll call it the Samsung Q.
Onto Fuji now and I have fixed an X-Pro3 and the old X-Pro1. The original had a lot of Fujifilm's own CPUs inside.
It's very well made but has a lot of traditionally soldered wires on the mainboard, old-school style. This continues with some of the newer models too.
X-Pro3 was an easy fix, a ribbon cable (FPC) had come loose where the sensor plugs into the mainboard. Some tape over the socket had shrunk in the heat and pulled it ajar.
Pictured above is the X-Pro1 circuitboard, it's more proprietary whereas X-Pro3 looks a bit more generic on the inside.
Here is an oven bake of a Panasonic LX15 mainboard...
The components can withstand very high-heat and usually cold solder joints are responsible for a wide range of issues.
Unfortunately in this case I made a mistake with the stop watch and the card slot fell off 🙂
Here is a sensor with hot mirror... the IR cut filter glows pink in this shot.
If you remove it you get an IR capable camera and can also shoot normally if you add the IR cut filter to the front of the lens instead.
I think this sensor is from my Lumix LX100 II or could be Sony RX100, I forget 🙂
Now onto Sony and their smaller cameras are too tightly packed.
FPC cables develop cracking over time as some of the metal is folded and bent too tightly to fit the smaller bodies.
This is an RX100 and it's very common to see these fail on the cable that connects the lens.
A relatively easy fix actually and replacement FPCs are $5 on Aliexpress.
But I don't rate Sony's quality as highly as Fuji or Panasonic so far.
Onto Canon and I have had a very bad experience so far with their modern cameras. The DSLRs were much better made (i.e. 5D Mark III which was easy to tear down and remove the OLPF back in the day!)
They use extremely fragile FPC connection sockets and the ribbon cables themselves are brittle and cheap. Sometimes a few bends and they tear. Doesn't make for a stress free repair that's for sure.
In contrast to Panasonic, with the lovely GX80 it's in a different league and take a bit of extra abuse by an amateur repairer.
I've done a lot more than what I have time to post today but probably will do a deeper look at stuff for YouTube or the blog.
I rate as follows the brands then...
1. Leica (the extra cost is noticeable on the inside)
2. Panasonic (they know how to sensibly build a camera and logically lay out stuff, and they don't scrimp on component quality)
3. Fujifilm (high repairability score and robust, sensible designs)
4. Nikon (high repairability but many of the newer cameras not up to high-standards they set during DSLR era)
5. Sony (they try to pack in too much)
6. Canon (really quite terrible, cheap cost cut components, and badly laid out)
Stay tuned for more. I do this just for fun, and really enjoy it. Plus now I have a oven baked Leica 240 to play with 🙂
  • Andrew - EOSHD changed the title to Repairing mirrorless cameras - the truth about each brand's build quality
@Andrew Reiddo you think there is a DIY way to strengthen the micro-HDMI ports' connection to the motherboard in these newer cameras - particularly Canon's R5C? Most people use the usual port protectors from Canon and Smallrig but I've seen reports of the ports stilll having issues, even when those steps are taken. Personally I just do not use the micro-HDMI and USB-C ports at all but wondering if there is a way to fortify those connections?
Thats pretty hardcore..  I once pulled a nikon coolpix 950 apart and removed the hot filter, i tried to keep it together as much as possible and photo'd  most of the steps to give myself some chance  of getting it back together properly. Surprisingly it still works, i did however have one ity bity little screw left over...  Without the the proper thickness of glass to replace the hot filter it only works with close focus things like flowers. If i had to do it again , i think i'd just buy something that had already been converted. kudos to you for being more adventurous.
Canon are absolutely the worst in my experience for the flimsy ports, thin circuitboards, cheap connectors and brittle ribbon cables (FPCs). Not seen how the R5C is built but usually the port is secured not even with a screw but sandwiched between two bits of plastic and the case, then the flex of the joint on the mainboard where it's soldered cracks the solder over time, you'd have to take the mainboard out and put it in the oven, risky business. To do a proper HDMI mod you would have to completely disconnect the port from the mainboard and reconnect it with a flexible ribbon cable. Then the cable would take the brunt of any flex over time, rather than the solder.
The camera companies are too dumb to do that, and they don't leave enough space between the mainboard and edge of the case to fit a small FPC.
With the IR cut filter over the sensor, I've never needed to replace it with clear glass of equal thickness, no focus issues so far.
Just another normal evening in the Reid kitchen.
Meanwhile, other folks around the world are sliding a lasagne out of theirs.
I have to torn apart my Lumix FZ1000, which have dust in the sensor, and I guess some haze from a sea city (the haze is more pronounced in the EVF optics - probably this will stay, I think that the EVF could not be torn apart - but I guess some of it is on the sensor too). Bought it for 1/3 of the usual price, besides the dust (unseen in almost 95% of the pics) and maybe a bit of sensor haze, and a non functional HDMI port (that I dont use), is it perfect.
iFixit have a very detailed guide, and I bought a digital gauge to take measurements of the sensor assembly height to try to keep the focal plane in check.
Haven't you got an Air Frier yet? Or is there something about France that forbids progress in the kitchen 🙂
Nice.
With a bit of practice it's less scary than it sounds, and you just need the right tools and steady hand.
A JIS standard screwdriver is a must... they use weird Japanese screw-head geometry, which the normal Philips head screwdrivers have a habit of stripping.
The only things I don't go near are modern lenses... Hellish.
Especially the zooms if you go deeper than taking the rear mount off.
you can make lasagna in an air fryer ? Now that's a video I'd like to see..
i guess the concept of an air fryer could differ from country to country. Ours had a blade that turned chips over as it rotated and cooked and thats about it.
Japanese screw-head geometry, thats torx head  or what we call torx head over here? A cross between  a phillips head and hex bit ?
  • 3 weeks later...
Hey Andrew, how about this one? Would be quite the deal if it could be fixed. Camera is about an hour from me so I am tempted to experiment. Otherwise an expensive paperweight. Salt water damage is probably up there with one of the worst things to do dona camera.
