FHDcrew Posted January 15 Share Posted January 15 Just now, Snowfun said: Would it be worth quoting Genesis 1:3 as this would solve the high ISO need… (with apologies) Link to comment Share on other sites More sharing options...
FHDcrew Posted January 15 Share Posted January 15 Just now, FHDcrew said: 1 minute ago, Snowfun said: Would it be worth quoting Genesis 1:3 as this would solve the high ISO need… (with apologies) I’m dead 🤣🤣 kye 1 Link to comment Share on other sites More sharing options...
kye Posted January 16 Share Posted January 16 20 hours ago, FHDcrew said: Some first impressions of the G9II; finally starting to shoot with it but will have my first very demanding shoot this weekend. I did some filming at a worship conference early this week. Image is thick and grades well. Lowlight is clean up to 3200 ISO and gets very noisy very fast. So far I shot on the super efficient mp4 4k 72mbps. When really pushing ISO at 6400 and 12,800 image seems to soften. This might not happen once I try the all-i codecs that have substantially higher bitrates. One thing I noticed, this camera has hybrid PDAF and Contrast-detect AF. At high ISOs the PDAF seems to turn off or become severely reduced...i start to get autofocus pulsing and it is not as responsive. It is not HORRIBLE and is still likely better than a gh5, but its not the snappy reliable PDAF that this camera normally operates at. I need to do more extensive testing, btu it seems up to around ISO 2500 or 3200 you can expect good AF performance, but seems to worsen from there. I will be shooting a big concert-style christian event this weekened and the venue has lots of contrasty DMX lighting which looks beautiful but is def a lower light scenereo. I am toying with shooting in CineD V2 in lowlight. What seems to happen is when I shoot in a flat 709 PP, I can lower my ISO and get a comparable exposure. I know that LOG needs a higher ISO in lowlight bc its capturing a much wider dynamic range...and once you grade LOG if its exposed well the noise differences vanish. But with CINEd V2 i can lower my ISO probably 1 to 1 1/2 stops and get a good exposure. Im thinking in terms of how the sensor behaves, it would allow me to more frequently keep the ISO at below 3200 which in tern means keeping good autofocus performance since it seems to again worsen above 3200 ISO. I am also thinking that since the picture profile will be more contrasty, if i need to crank my ISO ever the autofocus would be better because it is analyzing a more contrasty image. I think it will still grade well; it is still going to be 10 bit and i suppose the extra V-LOG DR is not terribly necessary in low light. Plus, the codec is still 10 bit so colors should manage well; i would run the footage through the same node tree i used for Nikon Z6 Flat 8 bit, which basically is modified CSTs in/out of Davinci Wide gamut with modifications to artificlaly smooth highlight rolloff. Just a note to say that it would probably be worth doing some tests ahead of the event. Situations like this involve many variables and most often people don't consider all of them because they don't do any methodical tests. You are assuming that the AF will work differently between different picture profiles, but I would suggest the AF would be operating on the image before the picture profile is applied, so it shouldn't matter... but, once again, you should test this to confirm. Another thing to consider is if you can push the shutter angle to 270 degrees or even 360 degrees. If it's a worship setting then making the footage seem a bit more surreal might be appropriate, and you can get another half or full-stop of exposure this way. You should also test NR in post - it's not ideal but it might give a better result overall considering none of your scenarios are operating in the cameras ideal operating range. I've done a lot of shooting with cameras at/beyond their capabilities and when you're pushing things you're trading off the drawbacks of each strategy. FHDcrew and ac6000cw 2 Link to comment Share on other sites More sharing options...
kye Posted January 16 Share Posted January 16 I'm not sure how this would translate, but my GH7 does far better when I raise the ISO to get a proper exposure in-camera vs shooting under exposed and raising the exposure in post. For some reason the shadows are quite noisy, even at native ISOs. This is shooting in C4K Prores so it's not a codec issue. FHDcrew 1 Link to comment Share on other sites More sharing options...
FHDcrew Posted January 16 Share Posted January 16 10 hours ago, kye said: Just a note to say that it would probably be worth doing some tests ahead of the event. Certainly agree I took a bit of time to test some stuff out yesterday evening. I do switch my picture profile from VLOG to FLAT I can lower my ISO from 5,000 to 1,000. Gotta do further test though on my ultimate thoughts on the autofocus. Link to comment Share on other sites More sharing options...
FHDcrew Posted January 16 Share Posted January 16 12 hours ago, kye said: I'm not sure how this would translate, but my GH7 does far better when I raise the ISO to get a proper exposure in-camera vs shooting under exposed and raising the exposure in post. For some reason the shadows are quite noisy, even at native ISOs. This is shooting in C4K Prores so it's not a codec issue. Curious how you find the gh7 autofocus fares at the higher IsoS Link to comment Share on other sites More sharing options...
kye Posted January 16 Share Posted January 16 2 hours ago, FHDcrew said: Certainly agree I took a bit of time to test some stuff out yesterday evening. I do switch my picture profile from VLOG to FLAT I can lower my ISO from 5,000 to 1,000. Gotta do further test though on my ultimate thoughts on the autofocus. Just make sure you're testing the options in the full image pipeline, so comparing finished 709 grades. So many people only test one part of the pipeline and ignore the rest. 4 minutes ago, FHDcrew said: Curious how you find the gh7 autofocus fares at the higher IsoS I haven't really experimented much with the AF on the GH7 as I'm used to the AF on the GX85 etc, and I tend to use manual lenses in lower light. AF is very difficult to test as well, and @Davide DB has posted before about how lens-dependent it can be too. Maybe there are AF tests online? Playing peekaboo with your camera seems a popular camera reviewer pastime! FHDcrew 1 Link to comment Share on other sites More sharing options...
FHDcrew Posted January 16 Share Posted January 16 1 hour ago, kye said: Just make sure you're testing the options in the full image pipeline, so comparing finished 709 grades. So many people only test one part of the pipeline and ignore the rest. Definitely. I did a brief comparison of a VLOG frame and shooting the same in flat with ISO lowered, I used the same node tree I did with my Nikon z6 8 bit flat and was able to get color and highlight rolloff real close. kye 1 Link to comment Share on other sites More sharing options...
kye Posted January 17 Share Posted January 17 9 hours ago, FHDcrew said: Definitely. I did a brief comparison of a VLOG frame and shooting the same in flat with ISO lowered, I used the same node tree I did with my Nikon z6 8 bit flat and was able to get color and highlight rolloff real close. Nice! The other thing to consider when testing ISO and noise in the final image is the delivery part of the pipeline. If I shot in two different modes and then processed them differently in my NLE, I might be able to tell the difference between them in my NLE. But no-one except you is watching your footage in your NLE, so you'll be exporting it, probably to h264 or h265, and you might not be able to tell the difference between them at this point. If you're going to be uploading them to a streaming service, then that service will decompress, process (NR, sharpening, who knows what else) and then brutally re-compress it. Lots of things are visible in the NLE and are completely gone or mangled beyond recognition in the final export or stream. FHDcrew and John Matthews 2 Link to comment Share on other sites More sharing options...
SMGJohn Posted January 27 Share Posted January 27 Micro Four Thirds is probably not gonna exist in the near future duo to exceptionally poor sales since both Matsushita and OM Group has decided to deinvest, OM-Systems might maintain a lineup for a few years although I am interested in what they will do now that the TowerJazz 20 megapixel photography sensor is getting more difficult to buy in bulk since the 12 day war. Less sales also means higher price for buying fewer sensors, guess they will be forced to take industrial Four Thirds sensors and adapting them to MFT mount. I have used medium format for aurora pictures just as a funny test, but gotta say, I did not enjoy how shallow depth of field even on a wide lens once you crank the aperture wide open. On MFT its much easier to maintain deep depth even with F1.2. Also with MFT you can use Metabones adapter to push physics to its limits, Canon 50mm F1.2 with the Ultra x0.64 XL will essentially give you 64mm F0.8 - it does however perform more like T1.4 however in terms of light transmission when measured accurately - Both the Lumix G9 and G9II basically perform the same in photography, the G9M2 however is an absolute THE best hybrid camera money can buy, everything is very reliable, its got the best video codecs - people praise Sony but their video codecs are absolute garbage and limited choices, Fujifilm still struggles with autofocus specially on their older lenses with the stepping motors. Canon are all heavy, limited glass the Canon R7 and Canon R8 are well priced but suffers from slow sensors and the R8 has no IBIS, the R7 IBIS is mediocre but better than Nikon by miles. At least Canon APS-C has Sigma. Rumours of professional APS-C cameras from all the main characters will probably kill off the MFT cameras in terms of competitiveness, APS-C lenses are not super big compared to MFT. Link to comment Share on other sites More sharing options...
kye Posted January 28 Share Posted January 28 13 hours ago, SMGJohn said: Micro Four Thirds is probably not gonna exist in the near future duo to exceptionally poor sales since both Matsushita and OM Group has decided to deinvest, OM-Systems might maintain a lineup for a few years although I am interested in what they will do now that the TowerJazz 20 megapixel photography sensor is getting more difficult to buy in bulk since the 12 day war. Less sales also means higher price for buying fewer sensors, guess they will be forced to take industrial Four Thirds sensors and adapting them to MFT mount. I have used medium format for aurora pictures just as a funny test, but gotta say, I did not enjoy how shallow depth of field even on a wide lens once you crank the aperture wide open. On MFT its much easier to maintain deep depth even with F1.2. Also with MFT you can use Metabones adapter to push physics to its limits, Canon 50mm F1.2 with the Ultra x0.64 XL will essentially give you 64mm F0.8 - it does however perform more like T1.4 however in terms of light transmission when measured accurately - Both the Lumix G9 and G9II basically perform the same in photography, the G9M2 however is an absolute THE best hybrid camera money can buy, everything is very reliable, its got the best video codecs - people praise Sony but their video codecs are absolute garbage and limited choices, Fujifilm still struggles with autofocus specially on their older lenses with the stepping motors. Canon are all heavy, limited glass the Canon R7 and Canon R8 are well priced but suffers from slow sensors and the R8 has no IBIS, the R7 IBIS is mediocre but better than Nikon by miles. At least Canon APS-C has Sigma. Rumours of professional APS-C cameras from all the main characters will probably kill off the MFT cameras in terms of competitiveness, APS-C lenses are not super big compared to MFT. MFT has been dead for decades now - everyone who hasn't been living under a rock for the last 10 years knows this. What people don't know is that due to a quirk in quantum physics and the way that time works, MFT was actually dead before it was invented. This means that my GH7 and GX85 and OG BMPCC and BMMCC never existed, don't exist, and when MFT finally "dies" somehow will disappear from my house. I bet you even think the earth is round... some people are just too much! John Matthews 1 Link to comment Share on other sites More sharing options...
FHDcrew Posted February 3 Share Posted February 3 Sadly sold the G9II. I realized I need good high ISO performance, and seems PDAF is disabled at real high ISOs. I scored a canon r6 for $929 and other than the overheating it’s great. And I can live wijt the overheating for how I shoot. IBIS can genuinely compete with LUMIX by having DIS on standard and using adobe’s warp stabilizer, somehow warp stabilizer absolutely thrives at stabilizing the type of leftover shakiness and artifacts of canon’s IBIS + DIS combo. Very consistently stable without warpy artifacts. Great high ISO performance. Lovely image in CLOG3. I did like the G9II. Its image was great. Best Ibis I’ve ever used. Very comfortable. Just realized I need better high ISO performance. Yes I could have gotten a super fast zoom like the sigma 18-35 1.8/speedbooster or Panasonic 10-25mm 1.7. But sometimes I REALLY need to push things at weddings or concerts, shooting at ISOs like 25,600. That’s beyond what the Gh7/G9II can handle. kye 1 Link to comment Share on other sites More sharing options...
kye Posted February 4 Share Posted February 4 13 hours ago, FHDcrew said: Sadly sold the G9II. I realized I need good high ISO performance, and seems PDAF is disabled at real high ISOs. I scored a canon r6 for $929 and other than the overheating it’s great. And I can live wijt the overheating for how I shoot. IBIS can genuinely compete with LUMIX by having DIS on standard and using adobe’s warp stabilizer, somehow warp stabilizer absolutely thrives at stabilizing the type of leftover shakiness and artifacts of canon’s IBIS + DIS combo. Very consistently stable without warpy artifacts. Great high ISO performance. Lovely image in CLOG3. I did like the G9II. Its image was great. Best Ibis I’ve ever used. Very comfortable. Just realized I need better high ISO performance. Yes I could have gotten a super fast zoom like the sigma 18-35 1.8/speedbooster or Panasonic 10-25mm 1.7. But sometimes I REALLY need to push things at weddings or concerts, shooting at ISOs like 25,600. That’s beyond what the Gh7/G9II can handle. Good to hear you got a solution that works for your (very challenging) shooting requirements - that's what truly matters! Low-light is now the current limitation for the high-end MFT line-up. The GH7 sacrifices having a dual-base-ISO in favour of having the dual-readouts and the DR boost that architecture gives. I shoot uncontrolled external locations in available light, which means low-light performance is a consideration for me too, but the GH7s performance is enough for my needs. I suspect the low-light capabilities of MFT would be described as "Very Good to Excellent", but the latest FF cameras now have low-light capabilities that would be described as "Absolutely Incredible" and so MFT lags by comparison. You can't cheat the laws of physics! It wasn't that long ago that cameras weren't really usable above ISO 1600 or 3200, so things have advanced very quickly. Suggesting that you "need" to shooting weddings at ISO 25,600 would have been considered a joke and saying you were serious would have started arguments and gotten you banned as a troll! Personally I think the "if todays cameras can't do it then you don't need it" is a silly perspective, because it implies that there aren't any new situations or circumstances that are worth recording, and obviously that's just plain ridiculous. I wonder how the GH7 compares to the original A7S. The difference might be smaller than you'd think. FHDcrew 1 Link to comment Share on other sites More sharing options...
FHDcrew Posted February 5 Share Posted February 5 On 2/3/2026 at 11:46 PM, kye said: It wasn't that long ago that cameras weren't really usable above ISO 1600 or 3200 Yep. Also you can lowkey get full frame at a similar size with slower lenses and higher high ISO. The Canon R6 at 25,600 ISO is much cleaner that the G9II in 6400 ISO. 2 stops cleaner. But also r6 is applying a lot more internal NR which is up to users taste on if they like. I don’t mind saves me time in post but I get how some might want a more pure image they can Denoise later. Link to comment Share on other sites More sharing options...
FHDcrew Posted February 5 Share Posted February 5 On 2/3/2026 at 11:46 PM, kye said: I suspect the low-light capabilities of MFT would be described as "Very Good to Excellent", but the latest FF cameras now have low-light capabilities that would be described as "Absolutely Incredible" and so MFT lags by comparison. You can't cheat the laws of physics! Very true. My first camera was a Panasonic G7. The g9II still obliterates the g7 in lowlight lol. But yeah most of the full frame options from the last 7 years are all outstanding. Also it’s funny how 5-7 yr old full frame bodies are still excellent. My Canon R6 came out 5 yrs ago. The Nikon Z6 I used to shoot with came out 7 yrs ago. I filmed recently with an original Sony a7iii at 8,000 ISO (but a very very well exposed image) and the image was incredibly clean. We are so spoiled with choices anymore. Link to comment Share on other sites More sharing options...
FHDcrew Posted February 5 Share Posted February 5 Just now, FHDcrew said: Very true. My first camera was a Panasonic G7. The g9II still obliterates the g7 in lowlight lol. But yeah most of the full frame options from the last 7 years are all outstanding. Also it’s funny how 5-7 yr old full frame bodies are still excellent. My Canon R6 came out 5 yrs ago. The Nikon Z6 I used to shoot with came out 7 yrs ago. I filmed recently with an original Sony a7iii at 8,000 ISO (but a very very well exposed image) and the image was incredibly clean. We are so spoiled with choices anymore. Makes me feel we haven’t gotten amazing IQ leaps in the last 5 yrs…I mean heck the fx3 sensor in the a7siii also came out 5 yrs ago and I don’t see any “superior” lowlight cams on the market. Only “comparable”. For example a c50 will hold its own against the a7siii. But it’s not better. Or worse. Just a 5 year newer camera. Link to comment Share on other sites More sharing options...
kye Posted February 6 Share Posted February 6 10 hours ago, FHDcrew said: Makes me feel we haven’t gotten amazing IQ leaps in the last 5 yrs…I mean heck the fx3 sensor in the a7siii also came out 5 yrs ago and I don’t see any “superior” lowlight cams on the market. Only “comparable”. For example a c50 will hold its own against the a7siii. But it’s not better. Or worse. Just a 5 year newer camera. Well, we've gotten drastically better pixels, but because everyone has been screaming incoherently about wanting sharper images the manufacturers took the higher performance and kept the same overall image performance but made the pixels smaller so there's more of them. Everyone said they wanted a camera that could match the 2.5K Alexa, but because there were more people screaming for resolution than screaming for quality the industry took it's improvements and gave us mediocre 4K cameras, then more improvements and we got good but not great 5K downsampling cameras, then more improvements and we got quite good 6K cameras, and since then the flagship bodies have given us 8K / 12K / 17K cameras with pixels that are close to rivalling the 2.5K Alexa. So ARRI released the Alexa 35, and now there's a 4K ARRI camera that absolutely smashes the 8K / 12K / 17K flagship cameras. It's a complete myth that cameras aren't getting better. They're getting better by leaps and bounds, but almost all those gains have been "spent" on smaller pixels / higher resolution. If that hadn't been the case, you'd probably have had every other feature you've ever wanted by now. FHDcrew 1 Link to comment Share on other sites More sharing options...
FHDcrew Posted February 6 Share Posted February 6 2 hours ago, kye said: They're getting better by leaps and bounds, but almost all those gains have been "spent" on smaller pixels / higher resolution. If that hadn't been the case, you'd probably have had every other feature you've ever wanted by now. Fair points for sure. kye 1 Link to comment Share on other sites More sharing options...
