Clark Nikolai Posted October 21, 2025 Share Posted October 21, 2025 34 minutes ago, kye said: Obviously the shape isn't ideal, as I should round it slightly and especially round the corners, but as a proof of concept, this looks promising. I really like this shape in the bokeh. It reminds me of 1950s graphic designs. kye 1 Link to comment Share on other sites More sharing options...
kye Posted October 22, 2025 Author Share Posted October 22, 2025 9 hours ago, eatstoomuchjam said: If that's the direction you're going, have you considered a Blazar Mantis? It's a 1.33x squeeze and has an internal oval aperture to give what they claim to be closer to a 2x bokeh look. I've looked at them a few times and I personally find their bokeh to be a turnoff, but a bunch of people seem to like them. Otherwise, it might be worth looking into whether any currently-shipping lenses allow a waterhouse aperture. I had a modern Petzval for a bit that did. If it's a waterhouse, you could put tape over the biggest and cut out any shape you want for the bokeh. I think lensbaby have one or more lenses which have both a standard round aperture and a hole for inserting bokeh-shaping cutouts. I might even have one around year somewhere from around 12 years ago that I've only used a few times - not for the bokeh cutout, but because the front element of it is on something like a ball head so it can be unlocked and moved freely around to get all Scheimpflug-gy(?). The Blazar Mantis is an interesting lens, and does reduce the weight from 1.3kg down to 800g but the SB+50/1.8 is only 350g, so pretty hard to beat. Plus the Mantis is probably 20-50x more expensive! The Lensbaby Double Glass has a replaceable aperture, but is 50mm F2.8 so on MFT equivalent to a 100mm F5.6 so pretty slow when compared to the Voigt+Sirui combo which is equivalent to a 68mm F1.5, or the SB+50/1.8 which is equivalent to a 71mm F2.6. I'm actually quite impressed at how much stretch and how consistent it was with the insert at the rear of the lens. I'm guessing this is where a 3D printer would come in perfectly, as I could rapid-prototype a completely custom insert for it. No matter, I'm sure I can do a reasonable job with some cardboard and a sharp knife. eatstoomuchjam 1 Link to comment Share on other sites More sharing options...
eatstoomuchjam Posted October 22, 2025 Share Posted October 22, 2025 1 hour ago, kye said: The Lensbaby Double Glass has a replaceable aperture, but is 50mm F2.8 so on MFT equivalent to a 100mm F5.6 so pretty slow when compared to the Voigt+Sirui combo which is equivalent to a 68mm F1.5, or the SB+50/1.8 which is equivalent to a 71mm F2.6. I'd have to dig mine out to see what it is - but it's EF mount so usable on a speed booster. 🙂 (But still more expensive than cutting some cardboard) kye 1 Link to comment Share on other sites More sharing options...
kye Posted October 22, 2025 Author Share Posted October 22, 2025 9 hours ago, eatstoomuchjam said: I'd have to dig mine out to see what it is - but it's EF mount so usable on a speed booster. 🙂 (But still more expensive than cutting some cardboard) It's funny, but I look at "what if" scenarios for lenses about once a fortnight and I've repeatedly considered getting an EF-MFT speed booster and I never found a reason for it. The EF lens options never met the parameters of whatever it was that I was contemplating doing, so I never bought one. On the other hand, my M42-MFT speed booster remains in use continually. Every time I 'tidy up' my lenses and put the ones I don't use into a box this always seems to stay out for one reason or another. I always seem to be learning something about images or shooting or something, and will look at my lens collection from a completely new perspective, and the MFT system and M42 system (for adapting FF lenses) always seems to be the winner. eatstoomuchjam 1 Link to comment Share on other sites More sharing options...
kye Posted November 24, 2025 Author Share Posted November 24, 2025 My Takumar 50mm F1.4 arrived and I took it out to compare it with the Voigt 42.5mm F0.95 with Sirui 1.25x adapter setup. The Voigt+Sirui is equivalent to 68mm F1.5 and the Takumar+Speedbooster is equivalent to 71mm F2.0, so a bit longer and a bit slower. In order to avoid changing lenses all the time, I did a little lap with the Voigt+Sirui, then did another lap with the Takumar and re-created the compositions from the first lap (as well as grabbing other shots too). These images have had a film-emulation applied, and have had exposures matched, but no other changes, so things like contrast and WB etc should be the same. My impressions: Voigtlander is softer at F0.95 than the Takumar at F1.4 I haven't compared them with the Voigt stopped down, but I'd probably rather get a bit more subject separation than sharper images. The extra sharpness of the Takumar makes the focus peaking a lot easier to use when using the screen (using the EVF you can see what is in focus but the monitor you need peaking on) The focus ring on the Takumar is a lot looser (not that damped but not too loose either), but of course it's backwards The extra width of the Voigt is apparent. It makes me wonder if the Speedbooster is a little less boosting than I claimed. The Sirui has a lot of coma on the edges (stretching light sources horizontally) so the bokeh seems more horizontal than vertical on lights, whereas the Tak seems to have a zoom-blur sort of effect which is a bit odd The Tak has slightly lower contrast (hard to see but I noticed it when trying to match exposures) In addition to those, I also grabbed these with the Takumar: Swirly bokeh! and it's not a Helios!! It has a nice halation/glow but the ghosts from the light sources are real. This is something I am thinking a lot about because I find them to be very distracting. Seems sharp at the edges at closest focus. The bokeh is confusing - sometimes with bubbles and sometimes not. I actually find that the response to light sources in this lens is very complicated - sometimes it stretches along the spokes of a wheel and other times along the rim of the wheel. Also something I noticed but isn't really visible in stills is that light sources pointed straight at the camera have a flare that's like a loop, like this, which can look pretty distracting too. My conclusions are: The focus being lighter and peaking being more obvious makes it a bit easier and faster to use, so much so that I changed my process to where I'd adjust the vND, then hit record and then focus in the 2s it takes the GH7 to begin recording The size and weight difference is significant and I found I was able to shoot people from a lot closer with it than the Sirui The small size and weight mean it's a no-brainer to pack on trips where I'm reluctant to pack the Voig/Sirui combo Next is to test it with an oval insert to get some stretched bokeh. As a proof of concept it certainly looks promising. mercer, Davide DB and MrSMW 3 Link to comment Share on other sites More sharing options...
kye Posted December 28, 2025 Author Share Posted December 28, 2025 I've been procrastinating and thinking about bokeh shapes, and have now realised that there are a range of bokeh shapes seen from time to time in various shows. Very bubble (not my favourite) Oval with top and bottom chopped off pretty severely Not sure if this is all the same lens, but all from the same episode - there's a variety of shapes.. Slightly chopped oval Very stretched and so little curvature they're almost rectangles and then whatever on earth this shape is Quite chopped off tops/bottoms but not quite vertical Thinking about it more, I went back to why I started being interested in anamorphic bokeh to begin with and I think it's the fact it doesn't match how our vision works, so it looks surreal. So while I don't like distracting bokeh, once the bokeh isn't round then it can be whatever shape you want it to be. Anamorphics just happened to have it stretched vertically, which I think is probably one of the most pleasing non-circular varieties, but it isn't the only option, and the more rectangular it is the more stretched it will appear, so I'm thinking I might aim for something that looks like a slightly rounded vertical rectangle. The other thing I have been contemplating is if I could make an insert that didn't have hard edges, but had graduated edges. The only way I could think of doing that is to get some sort of semi-translucent sheet material and cut it at an angle so the edges had a slightly translucent transition to being completely opaque, but I am not aware of such a material. Link to comment Share on other sites More sharing options...
eatstoomuchjam Posted December 28, 2025 Share Posted December 28, 2025 5 hours ago, kye said: The other thing I have been contemplating is if I could make an insert that didn't have hard edges, but had graduated edges. The only way I could think of doing that is to get some sort of semi-translucent sheet material and cut it at an angle so the edges had a slightly translucent transition to being completely opaque, but I am not aware of such a material. My first thought was "I bet Rosco or Lee have something like that, but maybe not in the right size" and after a few minutes of searching, I found something from Rosco that's like that, but not in the right size. https://www.adorama.com/ro1081102024.html So there's hope, maybe that or searching for "graduated center filter gel" or similar would get you closer! Another thought would be to make something like the soft focus disc for an some types of large format soft focus lens - some examples here: https://www.largeformatphotography.info/forum/showthread.php?49632-Recommendation-for-Soft-Focus-lenses-for-4x5/page2 It wouldn't be exactly the same as varying the opacity of the film like in a gradient, but you could make an aperture that has a hard edge in the center with the edges around it perforated, but with the density of perforation decreasing toward the edges. It'd almost certainly introduce some interesting aberrations. kye 1 Link to comment Share on other sites More sharing options...
kye Posted February 6 Author Share Posted February 6 For anyone interested in understanding a bit more about the relationship between technical measurements and aesthetic experiences, this video is very interesting. Perhaps the challenge is that many people believe there's a golden zone of sharpness where it's softer than clinical glass, but sharper than poor performance vintage glass, but as there's very little qualitative data it's hard to know how a lens performs. The video gives a non-technical primer on MTF charts, and discusses what potential uses there are for different levels of performance, culminating in this chart. I particularly like this approach because the thinking is well beyond "good vs bad" lenses and takes the much more mature approach of "the right tool for the job". This is an example of this kind of thinking from the video: Recommended viewing if you want to go beyond "I like this lens" and "I don't like that lens"! Link to comment Share on other sites More sharing options...
kye Posted March 20 Author Share Posted March 20 I'm back from Guangzhou China, and starting to evaluate the footage, especially my modified Takumar 50mm F1.4 with the custom "insert" made from post-it notes and sticky tape. I managed to get out and shoot with it on a couple of nights. One in Beijing Road and the other in Yong Qing Fang. Some images from Beijing Road... these are all wide open, and lightly graded with Resolve and Film Look Creator. Overall, I'm really liking the aesthetic, which reminds me of mid-budget Hong Kong cinema, which I have a soft spot for. I mostly exposed to protect the highlights and then adjusted exposure in post under the FLC, and the GH7 has just enough DR for this, despite the scenes being quite challenging. The lens has a shallow enough DOF to be able to direct the viewers attention by choosing what is in focus, and the FOV (equivalent to a 71mm F2.0 on FF) is great for these type of scenes where the scenes would mostly overwhelm a wide lens with pure chaos. Some images from Yong Qing Fang.. same as above but with a touch of sharpening. This was a lot darker and I needed to push the ISO to get more levels in some scenes. It was also a lot higher DR, so some shots will be limited in post for how I grade them and I'll probably reach for NR in places. The lens is actually quite sharp in the middle, but the sides are more distortion than I'd like with quite a bit of bokeh distortion and coma from bright sources. The experiment with this "insert" was how strong a look it would be and I think it's probably too strong because the bokeh shapes are too distracting due to the sharp corners. It's distracting on frames with a clear subject (where you want the background to get out of the way) and on other shots its pure chaos and completely negates the idea of directing where the viewer will look. Getting DOF this shallow on MFT isn't easy, so I'll have to think about it more for future trips. eatstoomuchjam, TrueIndigo and BTM_Pix 3 Link to comment Share on other sites More sharing options...
