Nikon Zr is coming
ND64
38 minutes ago, Jahleh said:
According to CineD S1ii seems to have quite heavy NR baked in, unless you shoot Prores Raw and edit in Final Cut.
I think that NR was a unavoidable side effect of the algorithm they used to combine the two images.
40 minutes ago, Jahleh said:
As seen from those same charts, from ISO 800 to 6400, where NLog is shot, S1ii has DR of 12.6 to 10 with NR, and Z6iii DR of 12.3 to 9.6, without NR
Right, after ISO 800 (6400 in log profile), there is practically no difference, because both are at their High Gain territory. DR boost only works at Low Gain ISO.
1 hour ago, ND64 said:
Its in DR boost mode that for whatever reason Nikon didn't use. Slop based DR is irrelevant as it doesn't represent the "engineering dynamic range" of the sensor, which is at 1:1 signal ratio.
The engineering DR range in the DR boost mode is well above 12 on the S1 II, nearly 16-bit, even.  And when you say "Nikon didn't use," you mean on the Z6 III, right?  And not on this upcoming camera that nobody has seen yet and which may use sensor modes that weren't used on the Z6 III?
I'm not going to argue any more about a camera that nobody's seen, but outside of "has Redcode," or "uses a Red sensor," it's kind of hard to imagine what Nikon would claim makes the camera a hybrid with Red.  Nikon's colors are already very nice so "has Red colors" would be basically garbage for advertising.
25 minutes ago, MrSMW said:
I am in that camp and very happy with the current offerings and the lens line up...so hope the ZR is awful so I won't *need* to flip to Nikon.
Being happy in whatever camp is important. With Nikon and it’s lens options it can get expensive and out of hands quickly😆
Got 135 f1.8 Plena in the Spring, to prevent any ideas of changing back to Panny or Canon.
The Z6iii firmware was also updated at the same time, and need of NR in low light was gone, as was the flickering.
Not sure Panny has something like the Plena. Shooting with that is a pleasure always, and it takes good photos too.
Found also a used 400mm f4.5 before the price hike, and now I am quite firmly in the Nikon camp. Been shooting all year mostly N-Raw, to see how much space it takes. Editing N-Raw is quite easy now with M3 max 128GB and 3x4TB Nvme’s. No complaints about the DR and just happy about the results IQ wise.
Hope the ZR is not too big step up from Z6iii, as this shift to Nikon has cost some already😂
No they don’t as such…but Sigma do and Leica have a 135 f2 APO in the works, but the price of that will make the Plena seem ‘cheap’.
Just a couple of years ago, I thought the weak link in L Mount was the lenses and whilst I think there are a couple of holes still, I’ve gone round in a big circle and ended up with a set of f1.8 primes, the; 18,35,50 and 85 and with the addition of a 28-70 and a 70-200, over 4 bodies, I’ve got all bases covered for my needs, video and stills.
For sure. I wrestled with all kinds of combos of brands, bodies, lenses and each time I thought I’d found my best set up, I found flaws if not outright issues.
In the end, I decided to just go back to basics and creativity has shot up as a result. As has logistics, workflow and a load of other basics.
I have no further needs and instead, only wishes and intentions and none of those are kit related.
1 hour ago, Simon Young said:
As someone who bought the Z6iii twice and returned it twice I really hope the Zr has a strong OLPF. I loved almost everything about the z6iii but the excessive moiré killed it for me.
You never tried to use some soft mist filter that might blur the image, just that little bit that it would remove those moirer.
As seen from those same charts, from ISO 800 to 6400, where NLog is shot, S1ii has DR of 12.6 to 10 with NR, and Z6iii DR of 12.3 to 9.6, without NR and with faster read out speeds, and with 6k60p Raw.
I would like to be back in Panny camp too, but with current offerings and lens line up no thanks.
 I have personally stopped looking at the DR test from imatest and charts in general including CineD, but only at the Latitude test. Since some companies starting with Canon, started baking Noise reduction in their RAW, it just tricked the system. I prefer by far the latitude test, as it is just real life one. You can clearly see, how much you can get back from over exposure and underexposure.
Unfortunately CineD doesn't have a full test of the z6iii, but I have seen other test online and it was like 3 above and 4 below. So you are getting around 7-7.5 at best stops of latitude, which within a lot of FF cameras which mostly were between 7 and 8 stops of exposure latitude. But looking at the S1ii, the exposure latitude is at 5 above and 4 below in the normal mode!!! Already 9 stops of Exp Lat, which puts it very high, at a Red Raptor level of Latitude!!! And when you go in the DR boost mode, you reach a solid 10 stop of latitude, which is as good as the Arri Alexa LF !!!! https://www.cined.com/panasonic-lumix-s1ii-lab-test-part-2-dynamic-range-and-latitude-using-prores-raw-5-8k-with-dr-boost-on/ but now the rolling shutter is at 27ms. One important thing to take into consideration is that in normal mode the S1ii sensor is at 12 Ms, and the z6iii at 9Ms. It seems Nikon went for speed, which tends to create more heat and noise.
Now, for me, I hope Nikon give us choices. I prefer two additional stops of DR and a sensor read speed of 12 ms with 10 stops, than 9 ms and 7 stops. If they can give me both, great. If they can even give the 27ms 10 stops of latitude mode, even better. I prefer choice, where I can make my own decisions. I don't know if it is me, it is as if Nikon didn't get out the full potential from this chip, and Pana got more time and did their own teaks. Sincerely, if they only did the normal mode at 12 ms and got 9 stop of latitude in the z6iii, rather than all the criticism they got from z6iii DR, the camera would have got a ton of praise.
To me CineD’s latitude tests seem a bit over the top, as the last 4 and 5 stops under with heavy NR look many times quite bad already.
With Z6iii ETTR is the key, it’s IQ and highlight roll off looks way better than with S5ii when you pull down exposure in post.
Sure S1ii DR looks a bit better than Z6iii in paper, but for that you need to use always Prores Raw, which is more Gbps than N-Raw High and over double than N-Raw Normal.
Just funny, to get S5 and S1H IQ without baked in NR and sharpening out of newest Pannys the data rate is 13-20x more than what it used to be with old H.265. At least you have options.
Hope this ZR fixes Z6iii’s view assist, or adds option to load own view LUTs into camera.
Of course I tried filtration, but as we know filters have no impact on wave interference.
I mean the aim is not to use those 4-5 last stops and put them back at the base exposure, but it tells you that a 3 stop underexposure is still good, meaning your noise floor would still be much better than a camera that would be stuck at 2. Somebody else who likes to do technical test on Nikon cameras has an interesting test between the two, because he was intrigued how could the z6iii that was so criticized for the DR, while the S1ii got so much praise while using the same sensor. For me without the DR boost, the S1ii is still reaching 9 vs about 7 stops of latitude in the case of the Z6iii. The only difference for me is the 9 vs 12 ms for the sensor readout. And I hope Nikon give us, at least the S1ii DR. I already se a z9 which has 14ms sensor readout, so 12 ms is good for me.
https://www.dpreview.com/forums/thread/4812023 link to the comparison
Ok, I thought that softer images, tend to decrease moire because it lowers frequencies.
Well I don’t know about the science of wave frequencies or anything at that macro tech level, but can confirm with 100% integrity that using a 1/8th mist reduces or eliminates moire.
Because I use them on every lens all the time, for both photo and video and never have moire in either and I mean never.
That’s hours and hours of capture plus thousands of exposures, every job, for 2+ years.
There are possibly certain material types under certain lighting conditions where it might be forced, but I have not come across it in years.
All my VND’s are Freewell 2-5 stop with built in 1/8th mist and for very low light when an ND is not needed, 1/8th mist Firecrest Bloom Gold.
There is a trade off of course and that is a lowering of contrast, but I can not only live with that, but prefer it because it all adds up to part of my SOOC ‘filmic’ (less digital) look for video and the base of my ‘filmic’ (more real film-like) look for photo (which being raw requires a lot more editing than my video work).
But otherwise moire has not existed in my world since the OG Lumix S5, so 2022.
With the new firmware update released today, view assist now uses RED Technical lut.
Sure, over exposing works much better on Z6iii than it did on S5ii. If S1ii’s praise is partly due to baked in NR and over sharpening, then it has the same IQ problems than S5ii has.
Thanks! With FW 2.0 view assist exposure looks now the same with NLog than in photo mode, and not over exposed any more😀
6 hours ago, Simon Young said:
That’s down to pure luck
How can it be luck?
That's approx 100,000 frames of photography and approx 15,000 5-15 second clips of video (plus another 60 hours of static capture).
For the photo side, that has been with; Sony A7RV, Nikon Zf, Lumix S1H and Lumix S1RII.
Video, Lumix S5II, S1H, S9 shooting Vlog with LUT baked in. (Except S1H which has OLPF but no facility to bake in LUT).
It's just my experience, - what can I say? You have experienced something else, but that doesn't make my experience invalid.
What are these cameras of yours that are moire prone?
34 minutes ago, MrSMW said:
How can it be luck?
The Z6 III likely has a similar optical low-pass filter as the other models of the Z6 series which is reported as one axis only, so if there are high spatial frequencies on the other axis, these can cause moire or other forms of aliasing. Stopping down the lens to smaller apertures (such as f/11, f/16 etc. or using other means to soften the lens, such as a front filter) should eliminate the aliasing (including moire) if it does occur. The cause of this phenomenon is that the adjacent color filter array pixels can get different light (including different color of light), causing an interference pattern to form. Attenuating the high spatial frequencies optically should resolve the issue (and is the normal way to solve the issue). A thicker (two layers) optical low-pass filter on the sensor has the issue that the blurring is always there even though for some subjects (that are random enough not to cause problems) you might prefer the higher sharpness of the weaker, one-axis OLPF that the camera probably has at the moment.
In video, moire can (in some cameras) be caused by line-skipping, e.g., when going for a high frame rate mode, this is common with some cameras to achieve 4K120, but on the Z6III 4K120 is achieved by cropping to DX so there is no line-skipping and there should not be any additional aliasing or moire happening due to the use of that mode.
The only Lumix camera that has an OLPF as far as I am aware, is the S1H I don’t have anymore.
It’s just not something I have any concerns about as I just don’t ever see it.
There has been the odd time I think I have and a quick zoom in or out shows it  is only at a specific size in editing software vs I suppose, my specific screen size, but otherwise does not exist and certainly not in the end result.
Are you sure?
Well I am not going to stake my life on it, but as far as I am aware, the S5II definitely does not and neither do the S1II, S1RII and that other one, the E?
Pretty confident though…
There is a company called Kolari (or something like that) that make some kind of clip in filter though.
