kye Posted May 16 Share Posted May 16 I like film and retro filmic looks, but shooting Super-16 (or even Super-8) is still an expensive PITA. After some testing of my equipment, I've realised that my GX85 has image quality equalling or surpassing a Super-16 film camera (with some categories surpassing a Super-35 film camera) so in my pursuit of a pocketable, portable, fun, simple, and fast setup that looks like film, this project is born. The criteria is to work out how to get great images from the tiny setup that are enough like film that most people would believe it if you said it was shot on film. My approach is simply to compare the two and find the biggest differences and then work on bringing them closer together, 80-20 rule and all that. The first point of comparison is already known, the crop factor is similar (2.2x vs 2.88x) so making sure I don't go too hard into shallow DOF then this should be comparable. Second consideration is camera movement, shake, and how they'll be used. S16 film cameras can be hand-held, but they've got some weight so are relatively steady in use. 8mm cameras were designed to be hand-held and are much lighter, so will move more. The GX85 is far smaller than either, but has IBIS (and OIS with some lenses) so that should make it feel larger, but I'll have to watch out for parallax, which will give away the cameras lack of heft. Third is the DR. Film has a huge DR and I wasn't sure how this would go - harsh clipping of highlights and blacks will be a dead giveaway. Without knowing anything about its rec709 profiles, I shot an exposure test where I took shots one stop apart. Film negatives have a lot of DR, but print film has far less, with stocks like Kodak 2383 only having about 5-6 stops in the linear range of their exposure (between about 10% luma and 90% luma, before the rolloffs kick in). Bringing in my test shots and matching the contrast within my standard colour pipeline (based around the Film Look Creator tool in Resolve) I realised the GX85 has enough DR to push its highlights well up into the highlight rolloff curve of the FLC, and same with the shadows, so this is fine too. DR, check! Fourth is resolution and texture. The images should be soft and noisy, but how much? After reviewing a number of sources, I realise that there are all kinds of factors, such as the speed of the negative, how it was exposed (0... or -1 and pushed in post, etc), but often the biggest factor in softness was the lenses used, and the biggest factor on the grain is the processing that the streaming service does when you upload it! In this sense, I have a lot of freedom in these aspects, but I'll have to do further tests on uploading to YT. I have seen videos that have really nice grain in 4K, so I know it can be done, but my previous tests showed the YT compression really changes things, so I'll have to do more tests. Then we're into testing with real images and just seeing what we see. My first test was some random shots in the garden, just to have a starting position. The feedback I got (including one friend who practically lives to talk about film!) was that it looked good but needed more saturation. My thoughts were that I exposed too high (I'd forgotten that the LCD is deceiving and the GX85 has a lot of shadow info) and as such the highlights in the first image were clipped in the file and still show in the graded image. After this test I happened to watch a YouTuber go through their grading process and they said they exposed by putting the image in the middle of the histogram, which made sense to me and I realised this is what I should do with the GX85. Second test was just a few images while out and about. It's the GX85 and 14mm F2.5 pancake lens. I'd previously forgotten this lens is both a 31mm and also a 62mm (with the 2x zoom) and so is much more flexible than I was remembering, so I made sure to include some 2x shots to see how useful that was with this level of image degradation. I also decided to push the images to get more of the kind of look I'm chasing. The 2x seems completely fine too, having quality far more than this level of softening will show. I also re-graded them in B&W, pushing the contrast much further. I may even want to go harder on these. Much more work to do, but I'm really liking the process so far. In these days of digital perfection, the attraction of film is in the colours and the texture. If you want the colours and not the texture, wanting to keep a much more modern level of sharpness and noise, emulating some of the properties of film is so ubiquitous that I think it's just called "colour grading". The phrase "film emulation" then is for the texture of film and deliberately wanting the imperfections and aesthetics of it. You don't have to go hard like I have with Super-16 film + Super-16 lenses levels of softening, but if you did this is easily possible too and FLC has 35mm presets which soften, but do so far more subtly than this. I'll continue to iterate on the colours and textures, but moving into moving images is probably next, with all the testing of the YT processing and compression that comes with that. But seriously, imagine telling someone in the 80s that you could fit an interchangeable lens camera capable of shooting feature-film level images in your pocket... Feedback welcome. mercer, eatstoomuchjam, Andrew - EOSHD and 1 other 4 Link to comment Share on other sites More sharing options...
eatstoomuchjam Posted May 16 Share Posted May 16 It's a good start! Are you targeting a specific film stock to emulate? It seems like you're aiming for negative film now since you're talking about wide DR. Positive film actually has a lot more limited DR, generally speaking. The color images, while nice, don't really "feel" like any film stocks that I know which seems a little more digital. The black and white images, for me, feel like something shot on a modern t-grain film (T-Max, in particular). I think that's a combination of the sharpness of the image, the contrast applied, and the very fine grain. I probably wouldn't think of it if not paying close attention, though! kye 1 Link to comment Share on other sites More sharing options...
Clark Nikolai Posted May 16 Share Posted May 16 Nice stuff. I like this project. Discovering what the elements are that you like about film and training your eye to notice the tiny things that give it away that it's not film. These are all good but I like the second batch here the most. The grain is high in a still but might be okay when moving. The shot of the button on the pole is the one that to me shows that it's not film. I can see that there's more resolution there than the grain would be giving, making the grain look like an overlay. (Maybe add a tad blur to the image, or use a smaller grain effect?) I find using vintage zoom lenses meant for 16mm cameras to just naturally give that look. When you zoom in it's a lever that you move, which looks different than turning a lens ring or a motor turning a lens. How a camera's shape and weight affects your camera work is important for the look. Some Super16 cameras were shoulder mount so maybe get something that replicates that type of movement. I now have a shoulder rig for my D16 and it gives a different feel to the footage's movement than pistol grip type of shooting. I prefer it really. I don't use the pistol grip ever. (Too bad because the grip looks cool.) Another thing, which probably doesn't apply for your project, is what someone in the past would have shot and what they would have concentrated on and framed. That's another thing altogether. Are you thinking of also shooting so that it looks like it was shot in the past or is it replicating someone in the present day shooting film? kye 1 Link to comment Share on other sites More sharing options...
kye Posted May 17 Author Share Posted May 17 My film friend said that the edges were too sharp for S16, and gave me some examples of things printed on 2383 that look SUPER soft to me. It makes me think that the look of film is really two looks: 1) the look of a neg scan (which is digital from then on) 2) the look of a negative printed to a print stock I wonder how much "film emulation" is actually emulating the first one. I also wonder what look I'm going for. It occurs to me that back in the day what we'd see on analog TV would be low-resolution film scans (having maybe 480 lines) but would have had semi-infinite horizontal resolution (bandwidth limited and all that I know) and would have had zero digital compression, so the grain would have been fully in-tact (and therefore loud and proud). I suspect the aesthetics I absorbed (and are unconsciously referencing) would have been from music videos, sports videos, etc in the era of MTV (80s and 90s). In this early time anyone with a low budget would be shooting on 16mm (or 8mm!) and often not the highest quality lenses or cleanest stocks etc. I'm guessing I probably watched thousands of hours of pure-analog uncompressed 16mm or 8mm footage scanned and broadcast in SD, and those would have been quite DIY / experimental / creative etc, rather than the much more produced and formulaic outputs that came later on. 17 hours ago, eatstoomuchjam said: It's a good start! Are you targeting a specific film stock to emulate? It seems like you're aiming for negative film now since you're talking about wide DR. Positive film actually has a lot more limited DR, generally speaking. The color images, while nice, don't really "feel" like any film stocks that I know which seems a little more digital. The black and white images, for me, feel like something shot on a modern t-grain film (T-Max, in particular). I think that's a combination of the sharpness of the image, the contrast applied, and the very fine grain. I probably wouldn't think of it if not paying close attention, though! Thanks! Like I said above, not targeting and specific pipeline, but I did calibrate the contrast on the first set of images from the GX85 to the DR of 2383, which was 5-6 stops in the linear range. The goal is to get something that looks like it could have been shot on some unknown stock. Realistically, this is a proxy for the images just not looking digital, and apart from trying to emulate VHS or Betamax, there aren't any other analog looks to draw from. Plus, film did a ton of things that research says that are aesthetically pleasing, and I'm sure I also have some baked-in nostalgia or just acclimation to this look. Interesting you think of T-max, and think this is fine grain. The grain on this is based on the 16mm preset in FLC, but modified to be softer. More on this later. I looked around and found a few 8mm examples with high contrast, but most were much more faded-looking, even stuff that seems like it was shot recently. There's this video which has shots like this: or this one with shots like this: 15 hours ago, Clark Nikolai said: Nice stuff. I like this project. Discovering what the elements are that you like about film and training your eye to notice the tiny things that give it away that it's not film. Thanks! It's definitely more about training my eye to learn what I like rather than any sense of accuracy, however film has so many things that are desirable that there's so much overlap I couldn't do either one to any degree without also making huge progress in the other! 15 hours ago, Clark Nikolai said: These are all good but I like the second batch here the most. The grain is high in a still but might be okay when moving. The shot of the button on the pole is the one that to me shows that it's not film. I can see that there's more resolution there than the grain would be giving, making the grain look like an overlay. (Maybe add a tad blur to the image, or use a smaller grain effect?) The technique I'm using is to add the grain first, then soften the image. This ensures that they have the same amount of softness and we're not dealing with these horrific combinations of sharp footage + soft grain, or the other way around. The people I spoke with suggested that this tends to look a bit soft and so they either sharpen afterwards, or add a touch more grain on top. These shots had a touch more grain on top. What I didn't do is match the grain to the image. I added 16mm-sized grain to a sharp image, then softened that. Maybe I should just add 65mm-sized grain so it matches the resolution of the image, and then adjust the amount and softening to match the stock. I definitely have more to test. You're also right about moving grain vs frame grabs. I'm reluctant to post video samples until I've worked out how much grain to force-feed into YT to get the right amount of it out again. 15 hours ago, Clark Nikolai said: I find using vintage zoom lenses meant for 16mm cameras to just naturally give that look. When you zoom in it's a lever that you move, which looks different than turning a lens ring or a motor turning a lens. How a camera's shape and weight affects your camera work is important for the look. Some Super16 cameras were shoulder mount so maybe get something that replicates that type of movement. I now have a shoulder rig for my D16 and it gives a different feel to the footage's movement than pistol grip type of shooting. I prefer it really. I don't use the pistol grip ever. (Too bad because the grip looks cool.) Another thing, which probably doesn't apply for your project, is what someone in the past would have shot and what they would have concentrated on and framed. That's another thing altogether. Are you thinking of also shooting so that it looks like it was shot in the past or is it replicating someone in the present day shooting film? Definitely all considerations for a full-historic-emulation. I'm not really chasing historical accuracy in the sense that you're talking about, although I might be chasing some specific something I saw once and loved, which is possible (or quite likely) considering I watched a ton of very creative and edgy films growing up, including a lot of early music videos and skateboarding videos, which are much more likely to have been hand-held and with the camera being used to express attitude rather than the restrained professionalism of documentary or narrative cinematographers. I'm still figuring this out, but I suspect that what I have in mind is a feeling that I'm chasing, or perhaps an attitude, and I'm trying to get closer to that on every level at once. The colour and tone, the texture, the movement (motion cadence?), the compositions and camera movement, the choice of subjects, then in the edit the pacing and rhythm, the structure of shot combinations and overall arc, as well as the music which I plan to write as well. It's the whole vertical stack from tech specs to final feeling and emotional aftertaste of the edit. I have always liked street photography, and for this project (which is sort of a subset of my Night Cinema project) it's really shooting high-attitude moving street images. The gold standard for this is Illkoncept, who shoots travel videos on digital but has also shot some videos on his 16mm Bolex: From what I understand the Bolex doesn't have that many lenses and the ones available are often very soft, so this 16mm footage is a lot softer than other examples. This is in contrast to a setup like this, where they have used Vision3 50D and shot on the Laowa Nanomorphs and scanned at 6.5K, so this is sort-of an example of an image pipeline where the negative itself is the limiting factor: The other thing I've heard is that over the decades they improved the film itself, and what I was lead to believe was that it doubled (or more) in sharpness, so late 8mm film matched early 16mm, late 16mm matched early 35mm, and late 35mm matched 65/70mm. Great discussion.. it's forcing me to think about all kinds of things I hadn't really considered, which is the whole point, plus the result I'm getting are improving with each iteration. PannySVHS 1 Link to comment Share on other sites More sharing options...
Clark Nikolai Posted May 17 Share Posted May 17 10 hours ago, kye said: The other thing I've heard is that over the decades they improved the film itself, and what I was lead to believe was that it doubled (or more) in sharpness, so late 8mm film matched early 16mm, late 16mm matched early 35mm, and late 35mm matched 65/70mm. Right. Recently I did some transfers from films for someone. Most were from the 1950s but some were 1960s and '70s. It's noticeable how the film stock improved. When they switched to Super 8 it was very much better having the larger area used for the image but it was more than that. Even the Regular 8 from the 1960s was better than earlier stocks. The collection came with the original boxes that were returned in the mail from the lab and it's the same stock and ASA, but manufactured 10 years later. Quote Great discussion.. it's forcing me to think about all kinds of things I hadn't really considered, which is the whole point, plus the result I'm getting are improving with each iteration. Hope you're having fun figuring this out. I love this kind of thing. kye 1 Link to comment Share on other sites More sharing options...
PannySVHS Posted May 20 Share Posted May 20 The GX85 with the 14mm is such a nice and pretty combo. Best bang for the buck for wide angle rangefinder style photography. I still got my GM5 but I'm thinking about selling it as its cuteness factor wears off quickly and the GX is just so much better in every regard. I would have loved a Leica branded version with rock solid build and perfect button feedback and layout. I think this little Lumix is still well build and to me it is a classic indeed. It's my favourite small camera in regards of small form factor, great image and bang for the buck. If it had Pannys great 10bit codec and HLG I would have called it a digital S16 camera. I do call it a personal cinema verité camera nontheless. Anyway, awesome thread and interested to see your findings, kye! I've been using my two GX85 cameras for photography over the last couple of months, with a 14, 28 and 50, even a 75mm in use. Different 50s btw, C-mounts from Schneider and Zeiss. That Zeiss is astonishing, the Xenon painterly with its uneven focal plane and it other attributes. Would love to put em to usage for video. I guess this thread is a good starter for some GX85 motion picture love!:) @kye I have not experimented with the 2x digital crop. Is it without artefacts? That would make it a usuable 2/3" camera, though with one bayer sensor instead of three sensor blocks of course. Kind of like an LX10, which in 4K has about 2/3" sensor size. Could the 2x digital crop be downsampled from a 2.3K image? I could test it myself, couldn't I? Shouldn't I?:) @Clark Nikolai I would love to see a picture of your shoulder mounted D16. Awesome! Do you use it for personal occasions or for projects and what kind of projects? Cheers and thanks for this fun thread! kye 1 Link to comment Share on other sites More sharing options...
Framed_By_Dan Posted May 20 Share Posted May 20 Following this! I have the GX9 and have often wondered about trying come C Mount S16 lenses on it. After all, some should cover the 2.2/2.3x crop in 4K. I'm not going to go as deep as the OP here but if I can get a decent look with FilmConvert I'd be happy. kye 1 Link to comment Share on other sites More sharing options...
kye Posted May 21 Author Share Posted May 21 4 hours ago, PannySVHS said: If it had Pannys great 10bit codec and HLG I would have called it a digital S16 camera. I do call it a personal cinema verité camera nontheless. In a sense it's much better than people give it credit for. In terms of bit depth, what matters is how close (or not) the bits are to each other in terms of what hues / luma they describe. We all know that 8-bit LOG is worse than 10-bit LOG. In general, the below are roughly equivalent: - 8-bit 709 == 10-bit LOG == 12-bit Linear - 10-bit 709 == 12-bit LOG == 14-bit Linear and the killer... - 6-bit 709 == 8-bit LOG == 10-bit Linear The challenge with 8-bit 709 is that the 709 from consumer cameras is essentially a creative picture profile, and so when you try to grade it there will be all sorts of tints or knees and elbows in the gamma etc. If you try and convert from 709 back to some sort of LOG space for grading it makes the image much more flexible, as I outlined in my 8-bit REC709 is more flexible in post than you think thread, which showed that with some care you can turn this: into this: However, this is a "naked" transform without any look applied, so once you add in a transform with some flavour (like the 2383 LUT) then you can get an even more consistent output, turning this: into this: @Framed_By_Dan the above thread is worth checking out as it has a lot more detail, but the crux of it is to make sure you're using the right colour spaces etc, which FilmConvert should be capable of doing I would imagine.. Adding a film look will help obscure any shot-to-shot differences, and would probably give a decent set of tools for making small changes that are normally needed between shots when working with footage not shot on a closed soundstage. I think the reason people are so dismissive on 8-bit 709 is because when it was out, the colour grading tools people had access to were primitive and the colour grading knowledge was minimal, however when 10-bit LOG came in everyone needed to convert and people with specialist knowledge built LUTs that looked really good, and then after that the tools got a lot better and people started learning how to grade. I think had those tools and knowledge been around when 8-bit was the norm then people would have gotten a lot more out of it. The examples above show absolutely unforgivable exposure and WB errors and the results are good enough to be amateur-level. Had these been the variations that someone even semi-competent would have in their footage, the results are likely to be basically flawless. 5 hours ago, PannySVHS said: @kye I have not experimented with the 2x digital crop. Is it without artefacts? That would make it a usuable 2/3" camera, though with one bayer sensor instead of three sensor blocks of course. Kind of like an LX10, which in 4K has about 2/3" sensor size. Could the 2x digital crop be downsampled from a 2.3K image? I could test it myself, couldn't I? Shouldn't I?:) Indeed you should!!! 😆😆😆 Seriously, everyone has their own standards and looks for different things, so me saying it's good enough won't carry any weight for you using it on your projects (and it shouldn't) because we shoot differently. The sensor is 4592px wide, which with its 10% crop in UHD, means the normal mode is reading 4174px across (which seems an odd number actually). If we assume the 2x is half that width (and not half the full sensor) then that gives us 2087px wide for the 2x crop. I always shoot 4K so I get the 100Mbps bitrate, but edit on a 1080p timeline, so any artefacts will probably be obscured in post for me. Depending on what you're shooting, how sharp your lenses are, and your timeline resolution you may get quite different results I'd imagine. 2 hours ago, Framed_By_Dan said: Following this! I have the GX9 and have often wondered about trying come C Mount S16 lenses on it. After all, some should cover the 2.2/2.3x crop in 4K. I'm not going to go as deep as the OP here but if I can get a decent look with FilmConvert I'd be happy. I've got a few S16 c-mount lenses and some have wider image circles than others, with my Risespray 35mm F1.6 c-mount even covering the full MFT sensor on my GH7! Definitely worth testing and they can add some great character to the image without taking up a lot of space and making the rig really big (unlike using adapters and vintage S35 or FF glass). Also, definitely recommend using FilmConvert for this, as not only is it likely to be a more accurate film emulation (it's film emulation, whereas the Film Look Creator is just that, a Look Creator that creates Film LOOKS), but also it should have settings for input and output colour spaces, so if you set these correctly then you should be able to adjust exposure and WB in a pretty neutral way. I've been using the Standard colour profile, with Contrast / Sharpness / NR all turned down to -5, and Saturation left at zero. If you're using different profiles then I suggest shooting some test shots in both Standard and your normal profile, then pulling them into FilmConvert and playing around and seeing which you prefer. All the profiles on the GX85 do quite significant things to the colour, rotating hues, lightening and darkening different hues, changing the saturation of different hues, etc, so there is no neutral profile and it's just a matter of taste. If you get some good results I'd be keen to see them so please feel free to share them! PannySVHS 1 Link to comment Share on other sites More sharing options...
Clark Nikolai Posted May 21 Share Posted May 21 20 hours ago, PannySVHS said: @Clark Nikolai I would love to see a picture of your shoulder mounted D16. Awesome! Do you use it for personal occasions or for projects and what kind of projects? Here's a pic from a shoot I did last December. I don't know the brand of the shoulder rig (as I got it used on Craigslist), the EVF is the (sadly discontinued) Kinotehnik LCDVFE. The camera attaches to the rig with a Niceyrig quick-release plate (that has feet). The lens is a vintage Angenieux 17-68mm zoom with a screw on wide angle adapter, on top is a Niceyrig top handle holding an Audio-Technica stereo mic and a monitor mount. A bit hard to see is an attachment that goes below the rails between the shoulder pad and the grips for two wireless mic receivers. kye, eatstoomuchjam and PannySVHS 3 Link to comment Share on other sites More sharing options...
Clark Nikolai Posted May 21 Share Posted May 21 20 hours ago, PannySVHS said: @Clark Nikolai I would love to see a picture of your shoulder mounted D16. Awesome! Do you use it for personal occasions or for projects and what kind of projects? I use it both for my own films as well as I get hired to do music videos and events. I just finished a feature length experimental film shot entirely with it called Shapes, Colours, Patterns. (There's a trailer for it on my Tumblr. https://clarknikolai.tumblr.com ) I'm very happy with it, and of course the image from that camera is gorgeous. Something I've discovered with the Digital Bolex's footage, is that it looks the best projected rather than shown on an LCD screen. I'm now working on a new project. It's a narrative, collectively written, performed and crewed by myself and three other artists. It's set in the present day in east Vancouver where three artists are working on their art projects. The characters are based on the people involved and their real lives (but fictionalized so we have more freedom.) We're using French New Wave and Availablism methods. Quick half-day shoots. It's self funded, using what we have around us, the equipment we already own, locations we already have, etc. (I think so far all we've spent on it was some coffees.) I plan to enter it in to film festivals when it's done. Here's a picture with the camera mounted backwards on the shoulder rig. This is so the camera operator can walk forward while the talent is behind them and they don't need a spotter. It's tricky to learn how to move but it's going okay. It works fine with a wide lens but not easy when zoomed in (as you'd expect.) We have to flip the image in the monitor or it's disorienting. kye, maxJ4380, eatstoomuchjam and 1 other 4 Link to comment Share on other sites More sharing options...
eatstoomuchjam Posted May 21 Share Posted May 21 4 hours ago, Clark Nikolai said: I use it both for my own films as well as I get hired to do music videos and events. I just finished a feature length experimental film shot entirely with it called Shapes, Colours, Patterns. (There's a trailer for it on my Tumblr. https://clarknikolai.tumblr.com ) I'm very happy with it, and of course the image from that camera is gorgeous. Something I've discovered with the Digital Bolex's footage, is that it looks the best projected rather than shown on an LCD screen. The trailer is gorgeous. Great job! PannySVHS 1 Link to comment Share on other sites More sharing options...
kye Posted May 22 Author Share Posted May 22 12 hours ago, Clark Nikolai said: I just finished a feature length experimental film shot entirely with it called Shapes, Colours, Patterns. (There's a trailer for it on my Tumblr. https://clarknikolai.tumblr.com ) I'm very happy with it, and of course the image from that camera is gorgeous. Wonderful! Great eye and great images. Definitely in the direction of Koyaanisqatsi etc, not only with the images themselves but the shifts in theme too. Everyone should do themselves a favour and watch it! PannySVHS 1 Link to comment Share on other sites More sharing options...
Clark Nikolai Posted May 22 Share Posted May 22 18 hours ago, eatstoomuchjam said: The trailer is gorgeous. Great job! 10 hours ago, kye said: Wonderful! Great eye and great images. Definitely in the direction of Koyaanisqatsi etc, not only with the images themselves but the shifts in theme too. Everyone should do themselves a favour and watch it! Thank you. I'm glad people are liking it. It was a lot of work and took two years to make. Most of the time by myself, out in the city with a tripod and camera. I met a lot of people doing it since the camera looks unusual. (It's common in Vancouver to see someone filming as it's a big film production town and has six film schools but people out shooting usually have more modern squarish looking cameras.) The themes and aesthetic came out of the photography I had been doing for several years already. I had been framing buildings to make geometric shapes. This was basically adding motion to that series. The music was from a friend who had I got to know when he acted in a short I did a few years earlier. https://testcardmusic.bandcamp.com It hasn't had a festival screen it yet but it did get an award in Sevilla, Spain. https://www.instagram.com/seviff.spain/p/DUTcVcGDLq7/?img_index=16 kye, eatstoomuchjam and PannySVHS 3 Link to comment Share on other sites More sharing options...
kye Posted May 24 Author Share Posted May 24 Round 3. Changes include: More softening I'm currently aiming for a neg + print look, so that will be far softer than just a neg scan only. This is obviously adjustable to taste depending on what look I want. Grain is more saturated and with more blue and less red Grain engine completely rebuilt from scratch based on a grain-blur-grain-blur architecture More halation and bloom I think my previous versions were based on a 35mm preset where I adjusted the grain to 16mm but the halation and bloom were still at 35mm amounts - oops! I've applied it to some old images and some new ones. I have built a little set of S16 reference images from YT and also from PNGs people have sent me of S16 film scans, and in comparing these new grades I feel like these are closer but are in that strange space where they are too sharp and also too soft, where there's too much grain but not enough, etc. I suspect that either means these things are still missing the mark, or that there is so much variation in my references that I'm somewhere in the middle and therefore not close to the examples at the extremes. Feedback welcome... Link to comment Share on other sites More sharing options...
Clark Nikolai Posted May 26 Share Posted May 26 Much better than the previous batch. I like where you're going with this. I think the grain is a bit too extreme now but it's not unrealistic. It would depend on the film stock as some film pictures are this grainy. The ones where I think don't work for me are the 5th ( the trees) and the 8th (city shot). Both of these I think the grain is too much. The one of the trees as well looks like there's more detail in the leaves than that amount of grain would show. kye 1 Link to comment Share on other sites More sharing options...
kye Posted May 26 Author Share Posted May 26 31 minutes ago, Clark Nikolai said: Much better than the previous batch. I like where you're going with this. I think the grain is a bit too extreme now but it's not unrealistic. It would depend on the film stock as some film pictures are this grainy. The ones where I think don't work for me are the 5th ( the trees) and the 8th (city shot). Both of these I think the grain is too much. The one of the trees as well looks like there's more detail in the leaves than that amount of grain would show. Thanks for the feedback! I'm also happier with the images, but I think there is still more juice we can squeeze. My attitude is to assume the aesthetic impressions people have are correct and to try and reconcile those with the technical process, especially when the two are at odds with each other. The new texture approach to emulate a neg stock and then a print stock: Grain added at timeline resolution (full sharpness) with Resolve Film Grain OFX Gaussian Blur added to image+grain so that the sharpness of the image and grain match Grain (same as above) Blur (same as above) I think this more accurately mimics the architecture as with film the grain IS the image, so applying a softening to the grain or incoming image before they are combined would risk creating a mismatch. Then it's done a second time, which makes sense as if you print an image from a film stock onto another one, the image coming out of the print stock will be the print stocks representation of the neg stocks representation of the scene. The Resolve Film Grain plugin is a bit odd, with expanded/different controls than the ones in the FLC, but it lacks the presets I wanted so I had to roll my own. I think the grain was pixel-sharp, but there's a chance some softness is coming from there. Also not sure if Gaussian is the right flavour of blur. Let me know if there are better options.. Thinking about your impression that the image was sharper than the grain brings me to think about what might be making the image too sharp. The first potential culprit might be internal sharpening in the GX85, but I don't think this is the case. I expected that it would have sharpening, and some time ago I sat down to test how much it had and then design a blur that would counter it, but when I compared RAW and JPG stills (4592px wide) vs the 4K h264 on a 1080p timeline, I found no discernible difference, so concluded that the downscale from 4K to 1080p was enough to eliminate the (inevitable) sharpening that will be in the h264 stream if viewed at full resolution. The second potential culprit is that this image pipeline still lacks all the softness of anything in-front of the film-stock, specifically lenses and filtration. The 14mm F2.5 on the GX85 is pretty sharp, even when shot wide open, so might not be typical to the look of S16 from back in the day where the images might not have been so sharp, or they might have been sharp in the middle but not so much towards the corners? I have done a bunch of lens emulation stuff before so could easily reach for some of that, and I should add it anyway, just because it's more in-line with the overall goal of the project which is to evoke a more gritty retro mood, rather than to realistically emulate S16 film as if it was shot on modern lenses. Their vintage ND filters probably weren't quite optically perfect either. I should also do some tests to work out YT compression so I can start sharing moving images, as grain etc is completely different when moving to when not. Is there anything else I should be looking at for Round 4? Link to comment Share on other sites More sharing options...
kye Posted May 27 Author Share Posted May 27 Round 4. Changes: Included lens emulation Stabilised shots Lowered grain I completely rebuilt the grain nodes in a different OFX trying to refine it, then realised it didn't animate. FML. The lens emulation includes adding a vignette, softening the edges, and adding a slight barrel distortion. The grain seems a lot on certain things (like the sky) but doesn't appear at all on other things. I see no pattern for it, but this is how real S16 films also appear on YT so I'll leave it to the judgement of those with a better eye than me. These are my settings for Film Grain OFX - it appears there's quite some adjustments, so let me know if I should play with anything... eatstoomuchjam 1 Link to comment Share on other sites More sharing options...
Clark Nikolai Posted May 27 Share Posted May 27 It's really good. I'll have to watch a few times again to analyze more but my first impression is that this type amount of grain I associate with the 1970s and the cameras used back then for 16mm had some gate weave. Maybe try a touch of that and see. kye 1 Link to comment Share on other sites More sharing options...
kye Posted May 27 Author Share Posted May 27 8 hours ago, Clark Nikolai said: It's really good. I'll have to watch a few times again to analyze more but my first impression is that this type amount of grain I associate with the 1970s and the cameras used back then for 16mm had some gate weave. Maybe try a touch of that and see. There's a touch of gate weave in there, but I can definitely increase it. I was surprised about the grain actually. The amount I had dialled in was about 0.16 and I uploaded a test sequence that had 0.1 / 0.2 / 0.3 / 0.4 and the 0.2 was clearly far too much, so the above was just 0.1 as I figured if it's too little then it would be similar to when people upload and YT compresses it a lot and removes most of the grain. I guess there's two approaches.. The first is to make it look like film in the NLE and then upload it and YT will remove lots of grain but it will look like real film uploaded and processed by YT. The second is to do whatever you have to do in the NLE to make the final YT stream look like film. The more I look at my references the more I realise there is incredibly variation between them and that I have tonnes of leeway. Link to comment Share on other sites More sharing options...
kye Posted June 1 Author Share Posted June 1 Gate Weave increased (and I rebuilt the gate weave engine using the Camera Shake OFX). I'm not sure I like the aesthetic, so might turn it down for my own projects. @Clark Nikolai @eatstoomuchjam @Framed_By_Dan would especially appreciate your assessments of how close this is and what might be any next steps. I feel like it's good enough for my (untrained) eye, but if there are any more specific things you can identify then I'd be keen to keep going and see how far we can go. I'm gradually disabling things in the FLC plugin and manually recreating them myself using other plugins or just manual methods. Link to comment Share on other sites More sharing options...
