kye Posted May 3 Share Posted May 3 3 hours ago, eatstoomuchjam said: That, and also to set the aperture down to like f/16 or f/22 and shoot something - or even to put a pinhole lens on and shoot something. If you ever want to know how many pieces of dust have landed on your sensor, a pinhole lens is the quickest way to see them all. 🙂 I did think of that, but took it out of my reply because I was thinking that anything on the sensor would be in-focus regardless of what the lens was doing. Maybe I'm wrong though, not sure.. Link to comment Share on other sites More sharing options...
eatstoomuchjam Posted May 3 Share Posted May 3 3 hours ago, kye said: I did think of that, but took it out of my reply because I was thinking that anything on the sensor would be in-focus regardless of what the lens was doing. Maybe I'm wrong though, not sure.. You'd think so, but no! If you're using like an f/1.2 lens, you can have surprisingly big dust spots on your sensor and never be any the wiser. The more stopped down, the more they appear. From what I remember, and I might be wrong about this, it's bascally the same effect as using a large diffuse light source vs a small point source - put your hand next to a white card near the large diffuse source and you'll get a blurry, indistinct shadow. Do the same with a small point source and you'll get a well-defined crisp shadow. It's the same on a smaller scale with sensor dust. kye 1 Link to comment Share on other sites More sharing options...
eatstoomuchjam Posted May 7 Share Posted May 7 The camera is here. As far as I can see, there is a single decent-sized piece of dust on one of the internal ND filters and that's it. I cannot see any other marks on the camera's sensor assembly. The speck is big enough that I could imagine it being a little bit visible on a big blue sky, but in a way that'd be not hard to clone out. I'm also going to have to experiment with shaking the camera a little bit and/or blasting a rocket blower into the vent holes/fans. It's hard to imagine how that little sucker got in there. Worst case, if I decided to send it to CPS, I have to assume it'd be a pretty cheap repair. Overall, I'll gladly trade that for the $1,500 price reduction vs new. 😅 kye 1 Link to comment Share on other sites More sharing options...
kye Posted May 8 Share Posted May 8 On 5/7/2026 at 1:26 PM, eatstoomuchjam said: The camera is here. As far as I can see, there is a single decent-sized piece of dust on one of the internal ND filters and that's it. I cannot see any other marks on the camera's sensor assembly. The speck is big enough that I could imagine it being a little bit visible on a big blue sky, but in a way that'd be not hard to clone out. I'm also going to have to experiment with shaking the camera a little bit and/or blasting a rocket blower into the vent holes/fans. It's hard to imagine how that little sucker got in there. Worst case, if I decided to send it to CPS, I have to assume it'd be a pretty cheap repair. Overall, I'll gladly trade that for the $1,500 price reduction vs new. 😅 Nice. Good idea about giving it a solid clean out with rocket blower etc. Mine tends to leak air quite a bit from the one-way valve, but if you put a thumb over it then it turbo boosts the air to give a much more solid blast. It'd be good to know if there's dust all through it, and if you end up dislodging a bunch, at least you can include that in any cleaning service you arrange. I have also found that fan brushes for painting are really nice for dislodging the dust that is just attached enough to not move from air alone, but they tend to be gentle enough that they're not picking up dust and then pressing it onto the surface as you move it around. I don't know how far I'd go if something was on my sensor - I'm mostly blowing dust off my lenses or off the outside of the gear after a trip. Speaking of brushes, the makeup section in most shops will often have very soft brushes with a short handle that fit really well into the case/container you're keeping your lenses. In terms of how it got there, I've noticed a minority of people seem to be perfectly happy taking their time and doing other things while the camera has no lens or body-cap attached. Personally when I'm changing lenses I do it in a sheltered area, taking the rear lens cap off the next lens, then swapping the lenses as quickly as possible (while still being calm and controlled) and then putting the cap onto the previous lens. If I'm at home and feeling fastidious I blow the rear element of the next lens (and rear lens cap) before fitting it, then blow the rear of the previous one before putting the rear cap on, in an effort to not let dust hitchhike its way into the camera. Link to comment Share on other sites More sharing options...
eatstoomuchjam Posted May 8 Share Posted May 8 2 hours ago, kye said: I have also found that fan brushes for painting are really nice for dislodging the dust that is just attached enough to not move from air alone, but they tend to be gentle enough that they're not picking up dust and then pressing it onto the surface as you move it around. I don't know how far I'd go if something was on my sensor - I'm mostly blowing dust off my lenses or off the outside of the gear after a trip. I should clarify - the dust is under the outside layer of protective glass in front of the sensor/ND assembly. It's on one of the internal ND filters. Without some disassembly, it can't be reached with a brush. I'm more hoping that one of the air intakes for the camera's fan has some path that goes there and that blasting in air from the rocket blower will dislodge it. 😄 2 hours ago, kye said: I've noticed a minority of people seem to be perfectly happy taking their time and doing other things while the camera has no lens or body-cap attached. Personally when I'm changing lenses I do it in a sheltered area, taking the rear lens cap off the next lens, then swapping the lenses as quickly as possible (while still being calm and controlled) and then putting the cap onto the previous lens. I am somewhere between those people and fastidious. While on set, it's not usually a reasonable investment of time to move to a sheltered area to swap lenses. I don't walk around doing other things while the lens is off, but it often takes 15-60 seconds. Usually the rocket blower is plenty to handle any dust that sneaks in, no biggie. But the fact that it's under the external protective glass is why I can't figure out how someone got it in there. Worst case, I need to decide whether to send it to CPS for what should be a pretty easy fix for them - or I just sent it back to MPB within the returns window. Link to comment Share on other sites More sharing options...
kye Posted May 8 Share Posted May 8 1 hour ago, eatstoomuchjam said: I should clarify - the dust is under the outside layer of protective glass in front of the sensor/ND assembly. It's on one of the internal ND filters. Without some disassembly, it can't be reached with a brush. I'm more hoping that one of the air intakes for the camera's fan has some path that goes there and that blasting in air from the rocket blower will dislodge it. 😄 I am somewhere between those people and fastidious. While on set, it's not usually a reasonable investment of time to move to a sheltered area to swap lenses. I don't walk around doing other things while the lens is off, but it often takes 15-60 seconds. Usually the rocket blower is plenty to handle any dust that sneaks in, no biggie. But the fact that it's under the external protective glass is why I can't figure out how someone got it in there. Worst case, I need to decide whether to send it to CPS for what should be a pretty easy fix for them - or I just sent it back to MPB within the returns window. Ah, I didn't realise it was behind a layer of glass... I'm assuming the ND moves in and out of position, so maybe it got it on there when it was out of position? I'm assuming that whole volume isn't completely sealed. It still begs the question of how the dust got into there, and how much dust it's been exposed to in its life... the probability the camera has only ever gotten one bit of dust in it, and that dust happened to get to that spot is pretty slim by my estimation! Can you call CPS to get an estimate for how much it would cost? Maybe that would help inform if it's a return or if you'll keep it and send it off for the service. Link to comment Share on other sites More sharing options...
eatstoomuchjam Posted May 8 Share Posted May 8 1 hour ago, kye said: It still begs the question of how the dust got into there, and how much dust it's been exposed to in its life... the probability the camera has only ever gotten one bit of dust in it, and that dust happened to get to that spot is pretty slim by my estimation! It does! Though from what I read when googling it, some Canons have been notorious for it in the past - they even had an upgrade for the C300 to install a better filter to prevent it. The camera looks really clean otherwise, though. It also included the power adapter which MPB said it didn't - I think they just didn't realize that the same power adapter works for both the battery charger and camera. 1 hour ago, kye said: Can you call CPS to get an estimate for how much it would cost? Maybe that would help inform if it's a return or if you'll keep it and send it off for the service. I could call or I can just register it on the website and fill out the maintenance form. Also nice that I'd get 30% off. But it is really small - I'm not completely certain I'll even bother yet. I'm not usually shooting stopped down, it's only on the strongest ND filter, and it's also thankfully near the top of the sensor which means it's where the ground will be if I'm shooting (I'd be more likely to notice it against a blue sky or other patch of solid color vs in the details that tend to come with whatever is on teh ground). Of course, CPS also just recently gave me an estimate that my 85/1.2L that I sent in for cleaning/maintenance needed a new motor because the manual focus ring wasn't working and that it'd be a $700 repair. I asked them to just clean it and send it back because for that price, I could just buy another on the used market. Got it back and both autofocus and manual focus are working exactly as expected. I suspect the technician didn't realize it's focus-by-wire? Link to comment Share on other sites More sharing options...
kye Posted May 8 Share Posted May 8 1 hour ago, eatstoomuchjam said: It does! Though from what I read when googling it, some Canons have been notorious for it in the past - they even had an upgrade for the C300 to install a better filter to prevent it. The camera looks really clean otherwise, though. It also included the power adapter which MPB said it didn't - I think they just didn't realize that the same power adapter works for both the battery charger and camera. I could call or I can just register it on the website and fill out the maintenance form. Also nice that I'd get 30% off. But it is really small - I'm not completely certain I'll even bother yet. I'm not usually shooting stopped down, it's only on the strongest ND filter, and it's also thankfully near the top of the sensor which means it's where the ground will be if I'm shooting (I'd be more likely to notice it against a blue sky or other patch of solid color vs in the details that tend to come with whatever is on teh ground). Of course, CPS also just recently gave me an estimate that my 85/1.2L that I sent in for cleaning/maintenance needed a new motor because the manual focus ring wasn't working and that it'd be a $700 repair. I asked them to just clean it and send it back because for that price, I could just buy another on the used market. Got it back and both autofocus and manual focus are working exactly as expected. I suspect the technician didn't realize it's focus-by-wire? Yeah, I guess you could just start using it and see if it bothers you, and like you say - there are various tools to fix it even if it shows up on a few shots where the ground doesn't obscure it. The C300 having a similar problem helps to give more confidence that your unit wasn't treated especially badly, but also gives less confidence in it happening again, or in the Canon design department! I've had a number of things repair themselves over the years. The power mirrors in an old car I bought just started working out of the blue, and on the same car I bought it from a different state and was taking it to be inspected so it could be registered and I realised I'd forgotten to fix the horn, which didn't work. The guy was running through a checklist and said "horn" and I remembered I never fixed it. I decided to press it, pretend to be surprised, then promise to fix it later, hoping they'd be lenient.. so I pressed it and it worked - scared the crap out of me! I've had electronics do similar things too. I was visiting a friend in the Windows 98 plug-n-play days and he had a new card in his computer that wouldn't work in Windows so we were chatting and just for amusement I tried over and over to install it, using the same process (open device manager, delete the entries with errors, restart, repeat) and I had gotten to the point where I remembered each mouse click in the process and then out of the blue it just installed correctly and worked fine. When something doesn't work now I just treat it as the first offer in a negotiation and switch it off and let it chill for a while and come back to me when it's ready to raise it's offer 😄 Link to comment Share on other sites More sharing options...
eatstoomuchjam Posted May 8 Share Posted May 8 1 hour ago, kye said: The C300 having a similar problem helps to give more confidence that your unit wasn't treated especially badly, but also gives less confidence in it happening again, or in the Canon design department! Or in their QA department - for all I know, the first owner received the camera with the dust already in place! Maybe they didn't care or notice - if I hadn't been told of its existence, I don't think I'd have sat here with a lens off clicking through the ND filters and I probably wouldn't have seen it until I filmed something with a solid that happens to be behind it, probably stopped down a little bit. Anyway, I registered it with CPS. The website didn't want to give me a price estimate since based on my purchase date, it's likely under warranty (maybe?). So I sent them a note explaining that I bought it used, asking if there is a way to know if it's still under warranty from the original purchase date, and if not, what the price would be for them to remove the dust. Sadly, a somewhat vigorous shaking doesn't seem to have dislodged it and it didn't budge when I blasted a little air in through the exhaust (the intake is not in a place to have a direct path) 1 hour ago, kye said: When something doesn't work now I just treat it as the first offer in a negotiation and switch it off and let it chill for a while and come back to me when it's ready to raise it's offer 😄 This is the way! kye 1 Link to comment Share on other sites More sharing options...
eatstoomuchjam Posted May 8 Share Posted May 8 From Canon's support people, someone has to examine the camera to determine the level of work, but a rough estimate of prices, based on the perceived difficulty is: Minor = $269 Standard = $359 Major = $499 That's before my CPS discount on repairs which is, I think, 30%. So I guess that'd be $180, $270, or $340, give or take. Added to the approx. $1,500 below new price (and about $1,100 below most used prices I've been seeing), that ain't bad at all. (Though I do really need to sell something now, my gear list is getting ridiculous - anybody want a used Z Cam E2-S6G in good shape with a bunch of accessories including the eND?) scramjet and kye 2 Link to comment Share on other sites More sharing options...
Ilkka Nissila Posted May 17 Share Posted May 17 On 5/3/2026 at 12:33 PM, kye said: I did think of that, but took it out of my reply because I was thinking that anything on the sensor would be in-focus regardless of what the lens was doing. Maybe I'm wrong though, not sure.. The sensor isn't all one flat plane, there are filters in front of the photosensors and the dust is on top of the outermost filter surface. It definitely shows up more clearly at small apertures than wide open. Link to comment Share on other sites More sharing options...
kye Posted May 17 Share Posted May 17 6 minutes ago, Ilkka Nissila said: The sensor isn't all one flat plane, there are filters in front of the photosensors and the dust is on top of the outermost filter surface. It definitely shows up more clearly at small apertures than wide open. I'm imagining that it will be lens-dependent too, as some lenses are built for sensors that are happy to detect light that hits the sensor at an angle, whereas others want the light to be coming from an angle more perpendicular to the sensor. My understanding was that this is why some lenses vignette heavily on some cameras but not others, whereas some other lenses work fine across a wide range of sensors. Link to comment Share on other sites More sharing options...
