ita149 Posted July 9, 2025 Share Posted July 9, 2025 On 7/6/2025 at 5:19 PM, mtol said: Has anyone been able to assess how the fine details are processed here? I'm wondering how the footage looks compared to the original S1 or S5? I have the S1RII and the S1II. I also still have the old S1 and S5. The S1II is the same than the S5II about video details, even if some youtubers said the details rendering has improved, it's not true at all. Same bad rendering as the S5II. I understand some people are not bothered or can't see the difference and it's nothing wrong about that, but the difference is clear by example if you zoom inside your videos on people faces. Like the S5II, there is a sort of rough detail sharpening and in the same time a lack of very fine details. As always V-log looks better than the 709 profiles but it's still not great in my opinion. The S1RII also has the same detail rendering and I was very disappointed by the 6,4K Open Gate, it was not better than the 6K of the S5II, maybe even worse, like if this mode used a tiny bit of binning like the 5,9K 16:9. The new 7,2K is ok and looks better than the 6,4K. The 8,1K Open Gate is even better but limited to 24fps. Even if the video engine is the same between the S1II, S5II and S1RII, the later has much more resolution in 8K, hence the fine details looks finer even with the bad processing. it's only when the footage is a bit underexposed or overexposed that the S1 6K looks better. I read somewhere something interesting about Real Time Lut, using a burned in lut with a good amount of contrast helps to recover fine details. When recording V-log without Real Time Lut and grading in post, some fine details can't be recovered. I can confirm it's true. So using Real Time Lut V-log on the S1RII in 8,1K Open Gate is the best for details rendering. I'm glad Panasonic has fixed the colored pixels issue in Prores Raw on the S1RII and now the footage looks great, same details rendering than on the S1 or S5. But it's really crazy we must use Prores Raw to get the same good details rendering than on the S1 or S5 H264/265. And the crop is a shame, 1,45x ! When cameras like the Z8 or Z6III offer 6K or 8K 60fps raw video without crop ... About the S1II, Prores Raw only has a minimal crop (about 1,05/1,1x I think) and it was the main reason I bought this camera. Like on the S1RII, Prores Raw is excellent and like it has much less crop, fine details looks even sharper (in a good way). Finally we have a Panasonic camera with not only excellent IBIS but also excellent detail rendering and good AF without using external recorder (even if Prores raw is a pain for the workflow). The only issue I found is the 240fps 1080p mode, it is clearly not finalised because some horizontal lines appear randomly. I also found the photo raw files of the S1II and S1RII to be slightly less contrasty than the S5 and S1, they have less that punchy looks and I still prefer the rendering of the S5 and S1 with my best lenses like the 50mm S or 24-70mm Pro. it can be because of ACR but the JPEGs out of the cameras also looks slightly less contrasty than on the S5 and S1. Other than that, IBIS is stellar but sometimes more digital than on the G9II or GH7, color science is good but not as good as the GH6 to my eyes. The S1II also has better AF than the S1RII and I can feel the difference. Compared to Nikon, Lumix has several advantages like the IBIS and Open Gate. L-mount also has great "practical" lenses but I think they lack really great lenses with very nice rendering and more pancakes. After using most of the L-mount lenses, only a few looks really fantastic, like the 50mm S Pro (if it has not the coating issue), 24-70mm S Pro, 28-45mm Sigma and the APO Summicron SL. While absolutely great, the APO SL are really too much expensive for most people and it will be hard to attract a lot of people in the system, it is why Lumix try to attract people with smaller lenses and never released again new S Pro lenses since 2019/2020. Nikon has better AF most of the time but also more great lenses. The 50mm f1.8 is much better than the Lumix, the Nikon 35mm/50mm/85mm f1.2 and 135mm f1.8 are some of the best lenses you can buy. You can also adapt Sony FE lenses and there are more interesting "cheap" lenses available from third party manufacturers like Viltrox (mainly the 35mm f1.2 and 135mm f1.8). ArashM, j_one, stroszek and 2 others 5 Link to comment Share on other sites More sharing options...
ArashM Posted July 9, 2025 Share Posted July 9, 2025 4 hours ago, ita149 said: Compared to Nikon, Lumix has several advantages like the IBIS and Open Gate. L-mount also has great "practical" lenses but I think they lack really great lenses with very nice rendering and more pancakes. After using most of the L-mount lenses, only a few looks really fantastic, like the 50mm S Pro (if it has not the coating issue), 24-70mm S Pro, 28-45mm Sigma and the APO Summicron SL. While absolutely great, the APO SL are really too much expensive for most people and it will be hard to attract a lot of people in the system, it is why Lumix try to attract people with smaller lenses and never released again new S Pro lenses since 2019/2020. Nikon has better AF most of the time but also more great lenses. The 50mm f1.8 is much better than the Lumix, the Nikon 35mm/50mm/85mm f1.2 and 135mm f1.8 are some of the best lenses you can buy. You can also adapt Sony FE lenses and there are more interesting "cheap" lenses available from third party manufacturers like Viltrox (mainly the 35mm f1.2 and 35mm f1.8). Thank you for your thoughts, Wondering Hypothetically if you were to start from scratch right now, would you still go Lumix or Nikon? stroszek 1 Link to comment Share on other sites More sharing options...
MrSMW Posted July 9, 2025 Share Posted July 9, 2025 10 hours ago, ita149 said: The new 7,2K is ok and looks better than the 6,4K. The 8,1K Open Gate is even better but limited to 24fps The 7.2 will be my new go to over my current slightly less than 6k from the S5ii. At least I think it is… 5.9 or something? Anyway… The 8.1 limited to 24p is a bit of a bummer but hey ho. 10 hours ago, ita149 said: I read somewhere something interesting about Real Time Lut, using a burned in lut with a good amount of contrast helps to recover fine details I have not done any ‘scientific’ testing, but switched to that approach 1.5 years ago for other reasons, but I felt my work looked better immediately. Also using a 1/8th mist VND I am sure is responsible for zero moire. Ever. 10 hours ago, ita149 said: Compared to Nikon, Lumix has several advantages like the IBIS and Open Gate Plus ability to bake in the LUT plus twin card recording caused 4 winning points over Nikon, but Nikon does counter with superior lens options, especially with adapter E Mount as part of the equation. Super-tight call for me but the 4 winning points narrowly beat out the glass for me. 10 hours ago, ita149 said: L-mount also has great "practical" lenses but I think they lack really great lenses They have 2 holes in the lineup for me: An equivalent of the Tamron 70-180mm f2.8 which is MUCH smaller and lighter than the Lumix or Sigma 70-200’s and there is NOTHING in L Mount even close. An equivalent to Sony’s 50-150mm f2. Grail lens right there for me. I now do not care about the weight because is just the PERFECT lens for me but in order to have it, I’d need to build a Nikon or Sony based system around it and Sony doesn’t even have 6k (yet, but less than great 8k in the A7RV and then you have to go AII or whatever it’s called) and with Nikon, a ton of stuff I’d need to give up. 6 hours ago, ArashM said: Wondering Hypothetically if you were to start from scratch right now, would you still go Lumix or Nikon? For pure stills, Nikon. For pure video, Lumix. For hybrid, I could make a case either way and have done based on capabilities for my specific needs sacrificing my perfect lens to do it with Lumix. ita149 1 Link to comment Share on other sites More sharing options...
mtol Posted July 9, 2025 Share Posted July 9, 2025 13 hours ago, ita149 said: I have the S1RII and the S1II. I also still have the old S1 and S5. The S1II is the same than the S5II about video details, even if some youtubers said the details rendering has improved, it's not true at all. Same bad rendering as the S5II. I understand some people are not bothered or can't see the difference and it's nothing wrong about that, but the difference is clear by example if you zoom inside your videos on people faces. Like the S5II, there is a sort of rough detail sharpening and in the same time a lack of very fine details. As always V-log looks better than the 709 profiles but it's still not great in my opinion. This is extremely helpful, and also a bit disappointing. Thank you so much for your detailed response. It seems like there is ample reason to hold out for the S1HII, still. ita149 1 Link to comment Share on other sites More sharing options...
ita149 Posted July 10, 2025 Share Posted July 10, 2025 17 hours ago, ArashM said: Thank you for your thoughts, Wondering Hypothetically if you were to start from scratch right now, would you still go Lumix or Nikon? It depends if you are doing a lot of run and gun, can't live without Open Gate (because I think this feature is not just usefull but also give a real full frame look to the image) and appreciate some tricks like DR BOOST (at the cost of high rolling shutter). If yes, the S1II and even the S1RII are really a good choice, even if you like photography and if you can afford the Leica APO Summicron SL and the 24-70mm/50mm S Pro. If you don't have the need for the best IBIS or don't need to record while walking, Nikon is maybe a better alternative. AF is generally better even if the S1II is really not bad and more accurate than the S5II and S1RII. If you shoot wildlife, Nikon is also a much better choice, especially with the Z8, because Nikon has more tele lenses , better RS, unlimited burst and no blackout. The S1 and S1RII, while they have very fast burst (70fps for the S1II), you can only shoot for about 2 seconds, which is ridiculous. The Nikon S f1.2 lenses are excellent, they are more affordable, faster and have deeper bokeh than the APO SL. However they are heavier, bigger, and maybe less suited for video. If you are on Windows and use Resolve, Nikon with N-raw is much easier to edit than Prores Raw, both the S1II and S1RII only have Prores Raw. N-Raw is supported by Resolve and you have the lenses corrections backed in the files, you can even choose to record N-Raw directly in 709. Prores Raw is supported by Premiere Pro but there is no WB/ISO option. You also have the option to record 6K60fps (Z6III) or 8K60fps (Z8), on the S1II you only have a slightly cropped 6k30fps, it's worse on the S1RII because of the big crop. Outisde of Raw I think I also prefer the output of the H265 codecs compared to Lumix, Nikon is sharper but retains more fine details. So to resume : -IBIS is much better on Lumix. -DR is slightly better on Lumix (with DR BOOST or DRE ON). -Lumix has more nice features than Nikon (Open Gate, Real Time Lut etc). -Color is subjective but I really like the output of the S1RII. -AF is slighter better with Nikon even if the S1II is now closer than ever. -Video quality (fine details) is slightly better on Nikon (in RAW they are the same but N-Raw allows 60fps raw no crop). -For wildlife, Nikon is better, but keep in mind the Z8 is heavier than both the S1II and S1RII. -Nikon has more great lenses, Leica ones are as good but much more expensive. For me, as I like to do a lot of run and gun, Lumix is still the better choice for video but I need more editing time to get what I want because of Prores Raw. For stills, I don't shoot a lot of wildlife but I really like the Nikon S 1.2 lenses rendering. Leica lenses are also stellar, but you trade fast aperture and bokeh for more POP and significantly less weight. I think the S1RII is maybe the better choice if you don't need to shot fast scenes because the 8K H265 quality is pretty good, the IBIS is excellent, the AF is enough for most things and you can record Open Gate. The S1II can be the best choice if you need low rolling shutter and want the best detail rendering (Prores Raw) IBIS and DR. Like the S1RII you have Open Gate, but the big issue for me is the detail rendering with non raw video. The Open Gate 7,2K and especially 8K just looks much better on the S1RII. The Z8 is probably the best choice for stills in most cases, especially for wildlife. The video is outstanding too. But the camera is not lightweight, the IBIS is also much worse. The Z6III is a very good compromise, not as big as the Z8, 6K60fps is more than enough because the detail rendering is great. Maybe there is some bad shadows noise at some ISO but I think the issue is overrated since the last firmware update, like the DR slightly worse below ISO 800 compared to the Z8, it's really hard to notice a difference. But it's maybe because I don't shoot at very high ISO. For now, I decided to keep only the S1RII,S1II and Z6III. I will wait only a few months, if the next Nikon Z (with RED) has better IBIS, the choice will be obvious for me. But if Panasonic releases some new S Pro lenses very soon, it will be much harder to choose which system to keep. ArashM 1 Link to comment Share on other sites More sharing options...
ArashM Posted July 10, 2025 Share Posted July 10, 2025 10 hours ago, ita149 said: For now, I decided to keep only the S1RII,S1II and Z6III. I will wait only a few months, if the next Nikon Z (with RED) has better IBIS, the choice will be obvious for me. But if Panasonic releases some new S Pro lenses very soon, it will be much harder to choose which system to keep. Hi Thank you so much for taking the time to write this out, I appreciate it. Been pretty happy with the S1R2 mostly for stills so far, S52x's still do most of the video work for me (along with a Fuji X-H2S) Link to comment Share on other sites More sharing options...
MrSMW Posted July 11, 2025 Share Posted July 11, 2025 On 4/2/2025 at 2:07 PM, ita149 said: Stills are great with very good resolution, the Dpreview studio test is odd because the camera is very sharp even when using not so sharp lenses like the 28-200mm I’ve just picked up this lens. Or at least it’s arriving Monday. There are still some big black holes for me within L Mount glass but I came to the conclusion yesterday that this lens could have a place in my kit. I have been back and forth on the 28-105 and the 28-45 and would 100% have gone for the 28-105 had it been internal zoom which for anything 1kg or over, is a 99% must have. But it isn’t and I’m not going to say never to this lens, but right now, it doesn’t suit me even though the focal range and aperture are great. The 28-45 is probably happening, but going to shoot a few weddings on the new all L Mount set up first because it could work in isolation, but really I would like to pair it with a lens that does not, )but I hope will soon) exist; the 45-90mm f1.8 internal zoom. But in the meantime, I have the 70-200mm f4 (internal zoom!) for indoor work and will now have the 28-200 for outdoor, more stills than video I think, but we’ll see… I hate the external zoom but on a lens that weighs sub 500g, I can live with it. Also, by limiting myself to these smaller primes and zooms, I can skip the battery grip which for something like the 28-105, becomes essential to me for handling purposes, but I would rather keep everything as compact and light as possible without sacrificing too much performance. 4 bodies + 3 primes + 3 zooms gives a lot of options/combinations and as things stand is not only 1 less body than I have been using to date, but 3 rather than 2 less lenses so an even bigger bonus. Link to comment Share on other sites More sharing options...
ntblowz Posted July 11, 2025 Author Share Posted July 11, 2025 That 28-45mm is a very nice lens.. This guy was using the S1II but using the sigma 28-45mm 1.8 lens Link to comment Share on other sites More sharing options...
ita149 Posted July 11, 2025 Share Posted July 11, 2025 11 minutes ago, MrSMW said: I’ve just picked up this lens. Or at least it’s arriving Monday. There are still some big black holes for me within L Mount glass but I came to the conclusion yesterday that this lens could have a place in my kit. I have been back and forth on the 28-105 and the 28-45 and would 100% have gone for the 28-105 had it been internal zoom which for anything 1kg or over, is a 99% must have. But it isn’t and I’m not going to say never to this lens, but right now, it doesn’t suit me even though the focal range and aperture are great. The 28-45 is probably happening, but going to shoot a few weddings on the new all L Mount set up first because it could work in isolation, but really I would like to pair it with a lens that does not, )but I hope will soon) exist; the 45-90mm f1.8 internal zoom. But in the meantime, I have the 70-200mm f4 (internal zoom!) for indoor work and will now have the 28-200 for outdoor, more stills than video I think, but we’ll see… I hate the external zoom but on a lens that weighs sub 500g, I can live with it. Also, by limiting myself to these smaller primes and zooms, I can skip the battery grip which for something like the 28-105, becomes essential to me for handling purposes, but I would rather keep everything as compact and light as possible without sacrificing too much performance. 4 bodies + 3 primes + 3 zooms gives a lot of options/combinations and as things stand is not only 1 less body than I have been using to date, but 3 rather than 2 less lenses so an even bigger bonus. The 28-200mm is a good lens. I tried two samples, both performed the same. Acceptably sharp wide open between 28mm and 40mm. A bit soft wide open between 50mm and 150mm and very soft wide open at 200mm. But increasing the aperture just by one stop make the lens much sharper and the lens is very good at 200mm f8. It's a very good compromis because when you look at by example the 12-60mm PL I also own, the 28-200mm is a 14-100 f2-f3.5 equivalent in M43. Even when stopped down to be as sharp at a good copy of the 12-60mm PL, the 28-200mm can do the equivalent of 14mm F2, 25mm f2.8, 50mm f3.5 and 100mm f4 while being sharp. You loose the 24mm wide angle but I think it's a good trade for most use. My only issue with this lens is it makes sometimes a short but loud motor noise and vibration (about 2s) when using it in video with the S1 and S5. No issue with the S5II, S1II and S1RII. If you like lenses with high contrast and good color rendering, the 28-45mm is really excellent. Mine is very sharp at 28mm and extremely sharp at 35mm and 45mm even wide open. The focal range can feel somewhat limited but there is no better 28mm on L mount except the overpriced 28mm APO Summicron. The 70-200mm S Pro f4 looks good to pair with the 28-200mm indeed, I have the 70-200mm S Pro f2.8 and while it's a sharp lens with pretty good rendering, the size is an issue, at least for me. Yes and I think you will appreciate the S1RII. Like I don't record a lot of fast motion, I begin to think I could sell my S1II as the S1RII is easier for me to work, I can get good detail rendering from the H265 8K files whereas I need to shoot almost exclusively in Prores Raw on the S1II because I don't like the weird detail processing on the H265 or Prores files out of this camera. Link to comment Share on other sites More sharing options...
MrSMW Posted July 11, 2025 Share Posted July 11, 2025 5 hours ago, ita149 said: But increasing the aperture just by one stop make the lens much sharper and the lens is very good at 200mm f8 Good to know. This is not going to be a ‘workhorse’ lens for me, but rather something to ‘fill in holes’ if you know what I mean and much more for photo than video and especially as a walk around one stop shop landscape lens. Yes I think it will work very well. I considered the 70-300 but decided I wasn’t really gaining anything over the 70-200 I already have except a less good lens. Also the Samyang 35-150 but I’d need (want) the battery grip for that and were back into big boy territory and no thanks. 5 hours ago, ita149 said: If you like lenses with high contrast and good color rendering, the 28-45mm is really excellent. Mine is very sharp at 28mm and extremely sharp at 35mm and 45mm even wide open. The focal range can feel somewhat limited but there is no better 28mm on L mount except the overpriced 28mm APO Summicron 28 and 40 are my to ‘go to’ focal lengths below 50 that I prefer to work with. They have a certain kind of look and especially with 28, it’s about as wide as you can go before any distortion begins to appear. So yes, ultimately and as soon as possible, I do want this lens because it ticks every single box I have below 50mm. 5 hours ago, ita149 said: The 70-200mm S Pro f4 looks good to pair with the 28-200mm indeed, I have the 70-200mm S Pro f2.8 and while it's a sharp lens with pretty good rendering, the size is an issue, at least for me. Exactly why I chose it over the f2.8. Optically it’s very good and it’s actually OK in low light. And I think it’s slightly lighter even than the 28-45 Sigma?! Real world about the same but about as big and heavy as I prefer to go. 5 hours ago, ita149 said: Yes and I think you will appreciate the S1RII I think so. Pretty confident that it will comfortably replace the A7RV and Zf, both cameras I love. The combo of glass, slightly less but I am going from 3 different mounts/brands to 1 single and that is a big deal plus 1 less body and 3 less lenses. It’s a good decision. I’ll find out next week when I am using it, but today (I’m on a job) back to the Sonykon’s! Link to comment Share on other sites More sharing options...
ac6000cw Posted July 12, 2025 Share Posted July 12, 2025 On 7/9/2025 at 11:08 AM, ita149 said: I read somewhere something interesting about Real Time Lut, using a burned in lut with a good amount of contrast helps to recover fine details. When recording V-log without Real Time Lut and grading in post, some fine details can't be recovered. I can confirm it's true. So using Real Time Lut V-log on the S1RII in 8,1K Open Gate is the best for details rendering. I suspect that's because the in-camera LUT is processing the video before it's compressed, but in post you are working video after compression (which is likely to have reduced or smoothed over some detail, depending on picture content and bitrates). ita149 1 Link to comment Share on other sites More sharing options...
mtol Posted July 12, 2025 Share Posted July 12, 2025 I can't imagine having to shoot raw for a feature documentary as opposed to h264/h265. I can't be filling up 4 terabytes a day for weeks or months or years of shooting. I guess when these codecs were the best internal codecs on offer (GH5, S1, S1H, S5) Panasonic put more effort into perfecting them. Link to comment Share on other sites More sharing options...
Administrators Andrew - EOSHD Posted July 13, 2025 Administrators Share Posted July 13, 2025 On 7/11/2025 at 12:19 PM, ita149 said: The 28-200mm is a good lens. I tried two samples, both performed the same. Acceptably sharp wide open between 28mm and 40mm. A bit soft wide open between 50mm and 150mm and very soft wide open at 200mm. But increasing the aperture just by one stop make the lens much sharper and the lens is very good at 200mm f8. It's a very good compromis because when you look at by example the 12-60mm PL I also own, the 28-200mm is a 14-100 f2-f3.5 equivalent in M43. Even when stopped down to be as sharp at a good copy of the 12-60mm PL, the 28-200mm can do the equivalent of 14mm F2, 25mm f2.8, 50mm f3.5 and 100mm f4 while being sharp. You loose the 24mm wide angle but I think it's a good trade for most use. My only issue with this lens is it makes sometimes a short but loud motor noise and vibration (about 2s) when using it in video with the S1 and S5. No issue with the S5II, S1II and S1RII. If you like lenses with high contrast and good color rendering, the 28-45mm is really excellent. Mine is very sharp at 28mm and extremely sharp at 35mm and 45mm even wide open. The focal range can feel somewhat limited but there is no better 28mm on L mount except the overpriced 28mm APO Summicron. The 70-200mm S Pro f4 looks good to pair with the 28-200mm indeed, I have the 70-200mm S Pro f2.8 and while it's a sharp lens with pretty good rendering, the size is an issue, at least for me. Yes and I think you will appreciate the S1RII. Like I don't record a lot of fast motion, I begin to think I could sell my S1II as the S1RII is easier for me to work, I can get good detail rendering from the H265 8K files whereas I need to shoot almost exclusively in Prores Raw on the S1II because I don't like the weird detail processing on the H265 or Prores files out of this camera. The 28-200mm has quite a wide sample variation in terms of sharpness and uniformity. I had to buy two before I had a good one. What I like about it is the size and weight, for such a nice range in full frame it's tiny. The optical stabilisation is also very good, especially in video mode - which is super-useful for cameras like the Sigma Fp that lack IBIS. An alternative (although I haven't tried it personally) on Sony/Nikon is the Tamron 28-200mm F2.8-5.6. Faster, but heavier and longer. No OIS, but cheaper. Link to comment Share on other sites More sharing options...
MrSMW Posted July 14, 2025 Share Posted July 14, 2025 19 hours ago, Andrew Reid said: The 28-200mm has quite a wide sample variation in terms of sharpness and uniformity. I had to buy two before I had a good one. What I like about it is the size and weight, for such a nice range in full frame it's tiny. Eek. Well mine is coming used from MPB so maybe it's one that you sent back 🤪 I'll see how it goes but for me it's really intended as a 'secondary/occasional' use lens, almost exclusively outdoors in good light. I'm still not 100% I even need it but as I transition over to fully L Mount, it fills a gap. For now... On 7/11/2025 at 1:19 PM, ita149 said: Yes and I think you will appreciate the S1RII What cards are you running? I have an older Prograde 256GB 1700 MB/s CF Express and a Prograde 256GB 250 MB/s card that I was using in the old S1R. For my next 2 jobs, (5 days in a row from this Friday), I will only have these for the S1Rii on it's first two outings and will ONLY be shooting stills, so these should be fine.\ But beyond that, from mid Aug, I will start shooting hybrid and as I have to invest in some new cards, it would be a good idea to get something 'approved' just to help minimise any potential overheating. I'm also trying to do the math on what size cards as it's generally cheaper to buy more smaller cards than less big (capacity) cards... Link to comment Share on other sites More sharing options...
MrSMW Posted July 14, 2025 Share Posted July 14, 2025 I should add that I will NOT be shooting raw but 7.2k 30p open gate Vlog when I do get to using for video. Raw I think is just a step too far for me and as my other 3 cameras do not support it, no point. Link to comment Share on other sites More sharing options...
ita149 Posted July 14, 2025 Share Posted July 14, 2025 12 minutes ago, MrSMW said: What cards are you running? Only Lexar cards, those approved by Panasonic. MrSMW 1 Link to comment Share on other sites More sharing options...
ita149 Posted July 14, 2025 Share Posted July 14, 2025 19 hours ago, Andrew Reid said: The 28-200mm has quite a wide sample variation in terms of sharpness and uniformity. I had to buy two before I had a good one. What I like about it is the size and weight, for such a nice range in full frame it's tiny. The optical stabilisation is also very good, especially in video mode - which is super-useful for cameras like the Sigma Fp that lack IBIS. An alternative (although I haven't tried it personally) on Sony/Nikon is the Tamron 28-200mm F2.8-5.6. Faster, but heavier and longer. No OIS, but cheaper. Does your last 28-200mm is sharp wide open at 200mm or a bit soft ? It doesn't bother me so much because my sample is pretty good at 200mm f8 (at least for a small zoom lens like this). Link to comment Share on other sites More sharing options...
MrSMW Posted July 14, 2025 Share Posted July 14, 2025 Does anyone know where I can find the Mpbs numbers for the S1Rii? They have an extensive data sheet here: https://av.jpn.support.panasonic.com/support/global/cs/dsc/connect/sd/dc_s1rm2.html And they go on about not exceeding 600 Mpbs, but where exactly is that data?! I'm pretty sure the 7.2k 30p is below that (300 maybe, but guessing) for Vlog, but I ought to check before splashing the cash... Link to comment Share on other sites More sharing options...
MrSMW Posted July 14, 2025 Share Posted July 14, 2025 5 hours ago, ita149 said: Only Lexar cards, those approved by Panasonic Sorry, another Q re. cards... So for stills, pretty sure I'm OK as I was using these cards for S1R previously but it's 7.2k 30p video I am thinking about more. I'd rather avoid dropping a ton of cash on this, unless I absolutely have to, but I have: 3x Prograde 256GB 250/MB/s (V60) cards and I 'presume' 7.2k (and what I suspect is 300 Mpbs?), will write to these OK (as back up) with the primary files being written to my single Prograde 256GB 1700 MB/s CF Express card? Or is this CF Express not good enough for 7.2k footage?? The other option...and especially because CF Express is soooooo much cheaper than SD, is to pick up a Prograde 3400 MB/s CF Express card at €226 for a 512GB or €392 for a 1TB and switch out the SD's if they become full. But you can get, what 4 hours of 8k Vlog on a 256GB card and shooting purely clips, even over a full weekend, I can't see that ever happening...so a 1TB CF Express is probably massive overkill? My other 3 cameras are quite happy writing 4k or 6k to 128GB 'silver' cards and I have plenty of storage in that regard so it's only the new big boy I need to do something with. Link to comment Share on other sites More sharing options...
MrSMW Posted July 14, 2025 Share Posted July 14, 2025 7.1k even. I was getting a bit carried away there referring to 7.2k… Link to comment Share on other sites More sharing options...
