ArashM Posted February 6 Share Posted February 6 On 2/5/2026 at 2:37 PM, Django said: true! speaking of which: ..would you mind expanding on these quality of life issues, CFB extraction aside? I apologize for the delay, before I expand, I have to say Kye in a note above said it best. In general I don't find -For me and what I shoot- the ZR get's out of the way and just works, I'm not brand new to Nikon yet find the menu diving a bit of a pain, I also can't understand why I can't assign some common used settings to the first quick menu. Getting a card out once you rigged your camera is a nightmare, have to move the whole thing off and pull off anything on the base to access the card. See below on set's like this it's a bit of a mess and you then have to spend time and make sure your camera is back to the right place! Another challenge is the tragic H265, I shot a small table top for Sephora the other day and couple of mini clips ended up at 293 GIGs, would have shot it on H265 if it was fine, absolutely no need for red code in a perfectly lit set. I normally shoot on cameras that just do what they need to do and that's all there is to it, we don't even really think much about the camera during the shoot, for my experience so far the ZR isn't that camera! Again this is just me, I'm sure there are people who love using the ZR and that's excellent 🙂 Edit: spelling! kye 1 Link to comment Share on other sites More sharing options...
Django Posted February 7 Author Share Posted February 7 15 hours ago, ArashM said: I apologize for the delay, before I expand, I have to say Kye in a note above said it best. In general I don't find -For me and what I shoot- the ZR get's out of the way and just works, I'm not brand new to Nikon yet find the menu diving a bit of a pain, I also can't understand why I can't assign some common used settings to the first quick menu. Getting a card out once you rigged your camera is a nightmare, have to move the whole thing off and pull off anything on the base to access the card. See below on set's like this it's a bit of a mess and you then have to spend time and make sure your camera is back to the right place! Another challenge is the tragic H265, I shot a small table top for Sephora the other day and couple of mini clips ended up at 293 GIGs, would have shot it on H265 if it was fine, absolutely no need for red code in a perfectly lit set. I normally shoot on cameras that just do what they need to do and that's all there is to it, we don't even really think much about the camera during the shoot, for my experience so far the ZR isn't at all that camera! Again this is just me, I'm sure there are people who love using the ZR and that's excellent for them 🙂 Thanks for the honest take and rig photo. I can see how ZR probably isn’t ideal once you build it out like that. I’m also a bit skeptical about the cinema positioning. Nikon pushes R3D hard, which is great for high-end grading, but H.265 should be solid and dependable at this level, not an afterthought. Hopefully some of this improves via firmware. Better bitrates, cleaner encoding, more mature UI. The FX3 launched pretty bare and evolved a lot over time, so there’s precedent. For me, the appeal of the ZR is the ultra-compact body with that big screen. I wouldn’t want to over-rig it. On bigger sets with serious monitoring needs, I'd say something more modular like the C50 makes more sense. I've decided to rent the C50 to see if it really meets my needs in client situations. Wish I could do the same with ZR but it isn't available for rental around here. Really appreciate you sharing the unfiltered experience. It helps a lot. zerocool22 1 Link to comment Share on other sites More sharing options...
ArashM Posted February 7 Share Posted February 7 My pleasure and I hope there is something helpful in there. If I was in your shoes I would go C50 as well. I also agree and hope Nikon can address some of the short coming via firmware, they have been good about this in the past. Please keep us up to date with your thoughts and findings. Link to comment Share on other sites More sharing options...
mtol Posted February 10 Share Posted February 10 Personally I'm waiting for the FX3ii and S1Hii which hopefully will both be announced in April. Many good options if you need something now, but certainly more good options in a few months time. Link to comment Share on other sites More sharing options...
MrSMW Posted February 10 Share Posted February 10 2 hours ago, mtol said: Personally I'm waiting for the FX3ii and S1Hii which hopefully will both be announced in April. Many good options if you need something now, but certainly more good options in a few months time. The rumour mill suggests both of these might indeed be coming this April. There have been smoke signals over the Dolomite mountains… eatstoomuchjam 1 Link to comment Share on other sites More sharing options...
mtol Posted February 11 Share Posted February 11 17 hours ago, MrSMW said: The rumour mill suggests both of these might indeed be coming this April. There have been smoke signals over the Dolomite mountains… Every other camera has some nominal compromise for my workflow, but I'm hoping either of these cameras will check all the boxes for a long time to come. Really my S1H does 90% of what I want it to do to begin with, but readout speed improvements and reduced size would be welcome. Link to comment Share on other sites More sharing options...
MrSMW Posted February 11 Share Posted February 11 11 hours ago, mtol said: Every other camera has some nominal compromise for my workflow, but I'm hoping either of these cameras will check all the boxes for a long time to come. Really my S1H does 90% of what I want it to do to begin with, but readout speed improvements and reduced size would be welcome. I would have loved to have stuck either the S1H for both my video and stills work but re. the former, if only they had upgraded it with firmware to the new in camera LUT options, otherwise it was 'peak camera' for me. OK, maybe PDAF also, but obvs not available as a firmware option...which is why for me, the S1RII is my 'S1H'!! Please though can we have an FX3 style body with fully articulated Nikon ZR sized screen. I have no actual 'need' for this but do 'want' it and would buy it. eatstoomuchjam 1 Link to comment Share on other sites More sharing options...
Django Posted February 11 Author Share Posted February 11 The ZR with its ultra thin smart adapter is making more and more Sony users switch including a major YT camera bro.. the FX2 got horrible press and A7V has not outperformed the competition so I think its in Sony's best interest to announce the FX3 II sooner than later but the big question is will it finally give Sony users things like +4K, Open gate or even internal RAW? The recent releases make me very doubtful they'll include all of that... Speaking of ZR, I got to do some more testing as I await my C50 rental. I really like the camera. R3D RAW is phenomenal. But the file sizes are absolutely insane. I did notice that shooting in SDR compressed doesn't ruin the footage the way N-log does. My theory is that to keep such a compact camera from overheating, they baked in heavy NR and made the bitrate light to not heat up the card. If so, I'm not sure an update will fix the h265 log mush. Also the fact that shooting in R3D RAW changes the color science is a little jarring. Like Casey from camera conspiracies noted, the ZR feels like multiple cameras in one. The image quality and color science is all over the place depending on settings. I value consistency so not sure this appeals to me. Link to comment Share on other sites More sharing options...
mtol Posted February 11 Share Posted February 11 2 hours ago, Django said: its in Sony's best interest to announce the FX3 II sooner than later but the big question is will it finally give Sony users things like +4K, Open gate or even internal RAW? I have a hunch they will announce something with a higher resolution and open gate. Unsure about RAW. But they have to adapt with the market and surely they're noticing the discourse around the age and limitations of the FX3. Link to comment Share on other sites More sharing options...
Django Posted February 11 Author Share Posted February 11 25 minutes ago, mtol said: I have a hunch they will announce something with a higher resolution and open gate. Unsure about RAW. But they have to adapt with the market and surely they're noticing the discourse around the age and limitations of the FX3. I dunno this is the same company that released an FX2 couple months ago with a 4 year old A7IV sensor. The A7V hasn't caught up to the competition either. Sony are in their own bubble, too comfortable being in leadership position. Don't forget they also have a cine line to protect, so unless they're planning an entire FX refresh, I wouldn't expect too much from them at this point. In any case I can't wait any longer so it looks like I will be headed back to Canon, closed lens system but it checks all the boxes. Link to comment Share on other sites More sharing options...
mtol Posted February 11 Share Posted February 11 11 minutes ago, Django said: I dunno this is the same company that released an FX2 couple months ago with a 4 year old A7IV sensor. The A7V hasn't caught up to the competition either. Sony are in their own bubble, too comfortable being in leadership position. Don't forget they also have a cine line to protect, so unless they're planning an entire FX refresh, I wouldn't expect too much from them at this point. In any case I can't wait any longer so it looks like I will be headed back to Canon, closed lens system but it checks all the boxes. As long as it checks all the boxes for you. You really can't go wrong. For me both the C50 and R6III are close to checking all the boxes, but if the C50 had IBIS or the R6III had the XLR handle, they would be perfect. I know canon has some great stabilized zooms, but I don't want to get married to a system for a feature that most systems are putting in-body. I'm currently invested in L mount, but just barely - which means I own some adapters and one lens in that system. The rest is EF glass or adapted to EF glass. So switching systems would not be too costly if any one camera hits it all out of the park. At the end of the day, they're all good machines. I'm not in a huge rush. But I look at the price of used FX3s and kind of think it may make sense to invest in something that will hold its value as the kind of go-to camera for the next 5 years. Then again, I prefer the image out of my S1H to the FX3 any day, and had I gone that route I'd have a more valuable black box and five years of inferior images. Link to comment Share on other sites More sharing options...
Django Posted February 11 Author Share Posted February 11 12 minutes ago, mtol said: As long as it checks all the boxes for you. You really can't go wrong. For me both the C50 and R6III are close to checking all the boxes, but if the C50 had IBIS or the R6III had the XLR handle, they would be perfect. I know canon has some great stabilized zooms, but I don't want to get married to a system for a feature that most systems are putting in-body. I'm currently invested in L mount, but just barely - which means I own some adapters and one lens in that system. The rest is EF glass or adapted to EF glass. So switching systems would not be too costly if any one camera hits it all out of the park. At the end of the day, they're all good machines. I'm not in a huge rush. But I look at the price of used FX3s and kind of think it may make sense to invest in something that will hold its value as the kind of go-to camera for the next 5 years. Then again, I prefer the image out of my S1H to the FX3 any day, and had I gone that route I'd have a more valuable black box and five years of inferior images. Yeah, I'm still torn between the C50 and R6 Mark III (ZR is lingering but fading). C50 wins big on the XLR handle for clean audio, tally lights, active cooling, and all the cine extras. The real killer is the zoom rocker up to 4x digital zoom via the levers, turning any prime into a smooth parafocal telephoto. That's massive for run&gun when you can't swap lenses; Sony/Nikon hybrids top out around 1.5x in 4K. But no IBIS is a legit worry: digital + gyro + lens IS might work, but I need to rent and test further to see if it's a deal-breaker. R6 Mark III gives me IBIS, open gate for post cropping/vertical, hybrid stills/video balance, and an EVF. FX3 is still solid (clean 4K up to 120p, great high-ISO, gyro stab) but buying one this late feels off when open gate is high on my list. Short version: C50 for XLR, cine tools and that crazy digital zoom reach, R6 III for IBIS + open gate + reliability. Renting the C50 soon to settle the stab question. Oh, and the ZR is likely getting the axe.. too many quirks for my needs. Link to comment Share on other sites More sharing options...
mtol Posted February 11 Share Posted February 11 2 hours ago, Django said: C50 wins big on the XLR handle for clean audio, tally lights, active cooling, and all the cine extras. The real killer is the zoom rocker up to 4x digital zoom via the levers, turning any prime into a smooth parafocal telephoto. That's massive for run&gun when you can't swap lenses; Sony/Nikon hybrids top out around 1.5x in 4K. But no IBIS is a legit worry: digital + gyro + lens IS might work, but I need to rent and test further to see if it's a deal-breaker. I didn't know that the c50 had digital zoom like that. Neat! Canon stabilized lenses were my go to shooting tool for such a long time and I'm sure the new ones are better than the Ef generation. What I can't stomach is the price of new glass and being locked into a particular lens aesthetic when I want to shoot handheld. But all things considered, as a tool, good lens stabilization can be more organic and less artifact prone than ibis. I've seen some stabilization tests with the digital is and I am not impressed. I also expect Nikon will come out with more professionally oriented cameras soon. Renting a c50 is a good call. If it feels right in hand and you like the images you'll cut through the noise. Link to comment Share on other sites More sharing options...
Django Posted February 11 Author Share Posted February 11 31 minutes ago, mtol said: I didn't know that the c50 had digital zoom like that. Neat! Canon stabilized lenses were my go to shooting tool for such a long time and I'm sure the new ones are better than the Ef generation. What I can't stomach is the price of new glass and being locked into a particular lens aesthetic when I want to shoot handheld. But all things considered, as a tool, good lens stabilization can be more organic and less artifact prone than ibis. I've seen some stabilization tests with the digital is and I am not impressed. I also expect Nikon will come out with more professionally oriented cameras soon. Renting a c50 is a good call. If it feels right in hand and you like the images you'll cut through the noise. Yeah I haven't seen any C50 reviews really mention let alone showcase the digi zoom feature. I kinda stumbled upon it when menu diving and was shocked how effective it was, especially the range! The RF lens system actually isn't that expensive when you look at the STM range. The new 45mm f1.2 being priced under $500 is especially enticing and will be the first one I cop. The L primes are pricey AF and don't have lens IS so I'll probably stick with STM's and maybe even venture back into EF as they're so cheap these days and work like native RF. Some interesting third party cine RF lenses have also appeared (Canon is ok with licensing RF mount to manual glass manufacturers).. But as far as adaptability Nikon Z mount is killer and one of the main reasons I was so tempted to join that system. R3D RAW is also a great image pipeline, if only Nikon would offer lighter version. I mean REDs RAW compression is the whole purpose of their patent and ironically them suing Nikon. It feels such a waste to not offer it here but ok gotta remember it is a first gen product! Link to comment Share on other sites More sharing options...
mtol Posted February 11 Share Posted February 11 40 minutes ago, Django said: But as far as adaptability Nikon Z mount is killer and one of the main reasons I was so tempted to join that system. R3D RAW is also a great image pipeline, if only Nikon would offer lighter version. I mean REDs RAW compression is the whole purpose of their patent and ironically them suing Nikon. It feels such a waste to not offer it here but ok gotta remember it is a first gen product! I wonder if there's a thermal management reason keeping it from shipping with compressed raw formats. All in all a very tempting camera, but in no context do I ever want to produce files that large. Link to comment Share on other sites More sharing options...
Django Posted February 24 Author Share Posted February 24 Hey all, quick follow-up after having purchased the C50 and using it couple days. The customization is seriously one of the best parts. I have EIS toggle, S&F, teleconverter, display brightness boost, view assist, WFM, false color all on physical buttons so they're instant. Then the touch quick cine menu overlay lets me flip through frame rates, codec, resolution and recording settings super fast without leaving shooting view. It just feels like one of the quickest cameras I've used in real life. Open gate 3:2 is still my absolute favorite thing. The aspect ratio looks fresh and having that extra vertical headroom for reframing or pulling stills is addictive. Being able to shoot 7K open gate in 10-bit h265 at only 486Mbps in the lowest bitrate is a great data rate to resolution ratio. The digital zoom via the rocker switches is the other standout. Light press for slow creep, hard press for fast punch, with separate speed curves for each. It's so tactile and controllable, and it makes punch-ins on primes feel intentional instead of a crop hack. The top handle is really cool too. It gives better balance and a two-handed grip so handheld shake is noticeably reduced, especially low angles or longer takes. But what's even cooler is how modular it is. Snap it off and the camera becomes super compact for travel, storage or quick discreet shots. Having the choice is great. Still working on stabilization. EIS helps when it's on, but you get that slight crop and occasional motion blur artifacts unless I crank shutter angle to 90° or 45° (which I do now). EIS is disabled in open gate 3:2 so those shots are raw shaky until post. Gyroflow should handle it but I'm still having trouble getting it to recognise the camera or lens. Anyone knows how to manually set it up? Any tricks for getting the gyro data to load properly? Still in early testing phase but overall the camera feels fast, intentional and pro in a way that keeps me shooting. Cheers! eatstoomuchjam 1 Link to comment Share on other sites More sharing options...
Ilkka Nissila Posted February 24 Share Posted February 24 On 2/6/2026 at 8:53 PM, ArashM said: I apologize for the delay, before I expand, I have to say Kye in a note above said it best. In general I don't find -For me and what I shoot- the ZR get's out of the way and just works, I'm not brand new to Nikon yet find the menu diving a bit of a pain, I also can't understand why I can't assign some common used settings to the first quick menu. Getting a card out once you rigged your camera is a nightmare, have to move the whole thing off and pull off anything on the base to access the card. See below on set's like this it's a bit of a mess and you then have to spend time and make sure your camera is back to the right place! Another challenge is the tragic H265, I shot a small table top for Sephora the other day and couple of mini clips ended up at 293 GIGs, would have shot it on H265 if it was fine, absolutely no need for red code in a perfectly lit set. I normally shoot on cameras that just do what they need to do and that's all there is to it, we don't even really think much about the camera during the shoot, for my experience so far the ZR isn't that camera! Again this is just me, I'm sure there are people who love using the ZR and that's excellent 🙂 Edit: spelling! When setting up the ZR with the camera-specific Smallrig cage, there is space at the bottom of the cage to pull the battery and cards out, if needed. I think the ZR's main applications are not in large rigs but where the small form factor is advantageous. Hopefully Prores 422 LT will be suitable as a compromise format to make the camera more useful for those who cannot use the RAW formats. I personally like to shoot Prores 422 HQ 4K on the Z8 and although the files are huge they are not quite as huge as (with that camera) the N-RAW 8.2K, and I like having built-in lens corrections applied to the video file. Link to comment Share on other sites More sharing options...
