MrSMW Posted November 19, 2025 Share Posted November 19, 2025 I might be going mad, but I cannot find a way to do the following… So with stills, whether the material is from 2 or 3 cameras, I can sort footage by date AND time, down to the second at least so as long as the cameras have been synced for time, all good. With the video footage, I only seem to be able to do it by date, so in the folder I am going to cherrypick clips from to add to my timeline, I might have: 200 clips from Cam A followed by 150 clips from Cam B followed by 100 clips from Cam C all shot across say a 12 hour time period. Having to trawl backwards and forwards is an utter pain but all I can find are links to organisation by date only. Premiere user if that makes a difference. Any help appreciated and it’s probably one of those stupid things where once I have the answer I will slap my own head! Link to comment Share on other sites More sharing options...
Roger Posted November 19, 2025 Share Posted November 19, 2025 Inside of Premeire Pro you can sort on Creation Date if you add that from the Metadata Display. Link to comment Share on other sites More sharing options...
fuzzynormal Posted November 19, 2025 Share Posted November 19, 2025 1 hour ago, MrSMW said: I only seem to be able to do it by date Add "Creation Date" to your project's MetaData Display Tabs. Now, if you're wanting your video clips to be icons and also sorted this way, you can toggle to list view, sort 'em, then toggle back to icon view. They should then be in your desired order at that point. FWIW, it's not a bad idea to dig into the meta stuff in premier's metadata window; pretty granular. You can set 'dynamic' values on clips for all sorts of useful organization. Link to comment Share on other sites More sharing options...
MrSMW Posted November 20, 2025 Author Share Posted November 20, 2025 Thanks fellas. I think I have worked out why I cannot get this to work and that is because I cloned the settings from Cam A to Cam B so they are identical...including file numbers...so the software is only allowing the footage to be shown as 'everything' from Camera A and THEN everything from Camera B. I went into my photo sorting software, PhotoMechanical and changed the file names and then managed to reorder everything once the material from each camera had a unique name. I will only know for sure if I reset each camera to start with say A and the other B and then C etc which is what I had previously and never had this issue before. So almost certainly me as expected 🤪 Link to comment Share on other sites More sharing options...
John Matthews Posted November 23, 2025 Share Posted November 23, 2025 This is how I name all my footage: 2025-11-23_16-49-13_S5M2.MOV I do this with a free app called XNviewMP. This has served me well for finding date, time of day, and camera. Here's the renaming template: {Creation Date[Y-m-d_H-M-S]}_S5M2 On each import, I can select the last template used for a particular camera. I just use the Finder for finding files. For photos, it's a little more complicated: {EXIF:Date Taken [Y-m-d_H-M-S]}_City_Country_{EXIF:Model}_{EXIF:Focal Length}mm_F{EXIF:F-Number}_ISO{EXIF:ISO Value}_{EXIF:Exposure Time} Link to comment Share on other sites More sharing options...
MrSMW Posted November 23, 2025 Author Share Posted November 23, 2025 Thanks John for the app suggestion. I use PhotoMechanic for pics and have done for probably at least a decade and it’s my culling software. I do think it was having identical named files 🫣 in both S1RII’s that was causing me the issues because at first I thought it was the latest stoopid Premiere update, but seems the stoopid one was the user… John Matthews 1 Link to comment Share on other sites More sharing options...
