John Matthews Posted July 28, 2025 Share Posted July 28, 2025 I'm putting this question out there to see if anyone else is doing something similar. I've been running Parsec over a modest 1Gbps home network, paired with BetterDisplay to ensure proper 4K+ 60fps signals are sent to my iMacs—while editing 6K video on very modest hardware. For those unfamiliar, Parsec is low-latency remote desktop software. With BetterDisplay, I can match the resolution to the native Retina display of my iMac, allowing me to work from two different locations in my home without needing multiple high-end machines—or a 10Gbps network. The end result? It feels like I'm using an Apple M2 Mac Mini directly on a 2019 4K iMac. Honestly, I can barely tell the difference. I’d estimate the latency is under 25ms with this setup. Now I’m curious—has anyone tried this off-site? I imagine cross-continent setups would suffer from latency, but within the same continent, it seems like remote editing could be entirely feasible. It sure beats lugging around terabytes of footage. For me, this setup has breathed new life into an older machine. I’m even considering picking up another iMac—maybe a 5K model from 2017 or later. With H.265 decoding not being too demanding and the M2 or M4 Mac Mini handling encoding with ease, it seems like a highly effective and budget-friendly workflow. eatstoomuchjam 1 Link to comment Share on other sites More sharing options...
eatstoomuchjam Posted July 28, 2025 Share Posted July 28, 2025 I never tried editing with Parsec, but it's a good idea! How does it handle color management? Or is that done by Better Display? John Matthews 1 Link to comment Share on other sites More sharing options...
John Matthews Posted July 28, 2025 Author Share Posted July 28, 2025 37 minutes ago, eatstoomuchjam said: I never tried editing with Parsec, but it's a good idea! How does it handle color management? Or is that done by Better Display? I’m not 100% focused on color accuracy here—I rely on scopes for that—since calibrating two machines in different environments is never going to yield perfect results. My main reason for using BetterDisplay is to match the exact 4096x2304 resolution of my 2019 4K iMac. Retina displays don’t play nicely with standard external monitors, like the one I currently have connected to the M2 Mac Mini. I’ve heard some users connect “dummy” displays to the encoding machine to force the proper resolution, but this setup with Parsec achieves the same effect. If I send a standard 4K signal to the iMac, it doesn’t look as clean—the image is upscaled and noticeably less sharp. With this setup, I just launch Parsec and connect to the M2 Mac Mini. What I see on the iMac looks almost indistinguishable from running natively on the 2019 i3 iMac with 8GB of RAM—except, of course, I get the performance of the M2 Mac Mini. In fact, I often forget I’m even using Parsec. I’ve accidentally shut down the Mac Mini thinking I was turning off the iMac! And the biggest surprise? I’m getting Thunderbolt 4-level performance on my media drives—despite using only a 1Gbps Ethernet connection. As long as latency stays below a certain threshold, the experience is virtually seamless. The iMac just becomes a glorified thin client- exactly what I want. eatstoomuchjam and Ninpo33 2 Link to comment Share on other sites More sharing options...
John Matthews Posted July 28, 2025 Author Share Posted July 28, 2025 If macOS ever supported multiple simultaneous users, I’d happily run just one Mac Mini and use 3–4 iMacs around the house as thin clients for the whole family. I’m confident the performance would be more than sufficient—as long as no one is editing video at the same time! Unfortunately, that’s not the case. But there’s nothing stopping me from setting up several iMacs as thin clients, each connected to its own Mac Mini. By placing the Mac Minis next to each other and linking them via Thunderbolt, I could enable ultra-fast access to shared resources—effectively building a small, high-speed local computing cluster with shared storage and plenty of power. eatstoomuchjam 1 Link to comment Share on other sites More sharing options...
Anaconda_ Posted July 28, 2025 Share Posted July 28, 2025 I often use Splashtop Remote Desktop when editing remote and its always been very reliable. My main use-case is making an edit on a windows machine hooked up to a bunch of media servers in one city and I'm in another city on a MacBook. It handles the keyboard mapping and display scaling extremely well. It also has support for multiple monitors, so I can plug the MacBook into 2 external displays and have all 3 screens mirror the 3 Windows screens. Or assign them to spaces if I'm using the MacBook without the externals. Another advantage, in my case, is it has the option to blank the screens on the remote computer, and runs through a secure network, so feels very safe if you need that. I'm curious about Parsec, but it seems to be a similar price for similar feature set. Since Splashtop is doing the job just fine, I'm debating if its worth the time to research and switch over. For colour depth, both say they're 4:4:4 so I don't think that's much of an issue. John Matthews 1 Link to comment Share on other sites More sharing options...
John Matthews Posted July 28, 2025 Author Share Posted July 28, 2025 8 minutes ago, Anaconda_ said: I'm curious about Parsec, but it seems to be a similar price for similar feature set. I've been using the free version only. However, I did pay for BetterDisplay ($20)- for me, it's worth it and they did a hell of job that needs to be rewarded. 10 minutes ago, Anaconda_ said: Splashtop Remote Desktop I'll definitely have a look at this too. Thanks for that. Link to comment Share on other sites More sharing options...
eatstoomuchjam Posted July 28, 2025 Share Posted July 28, 2025 4 hours ago, John Matthews said: The iMac just becomes a glorified thin client- exactly what I want. You might be talking me into reinstalling Parsec and trying this out, but for different reasons. Usually I edit on my Macbook (The lower-end M2 Max) and it's totally fine, but when I'm at home, I prefer to edit off my basement NAS instead of from external drives and I use a postgres database on a server next to it. But if I don't plug into the network (which means sitting at my desk where the dock with 10ge is), editing video is not great (and editing photos in Lightroom ain't great either). But I have a windows gaming PC also set up near the desk which has a pretty decent setup with a nice GPU. I suppose I could just parsec to that while on the couch or in bed and do my editing, with the main catch being that I need to use Windows shortcut keys. That or I wait until there's a decent deal on an M4 Mini with 10ge (there have been some solid deals, but they're always for the base model with only 1ge) John Matthews 1 Link to comment Share on other sites More sharing options...
John Matthews Posted July 28, 2025 Author Share Posted July 28, 2025 1 hour ago, eatstoomuchjam said: You might be talking me into reinstalling Parsec and trying this out, but for different reasons. Usually I edit on my Macbook (The lower-end M2 Max) and it's totally fine, but when I'm at home, I prefer to edit off my basement NAS instead of from external drives and I use a postgres database on a server next to it. But if I don't plug into the network (which means sitting at my desk where the dock with 10ge is), editing video is not great (and editing photos in Lightroom ain't great either). But I have a windows gaming PC also set up near the desk which has a pretty decent setup with a nice GPU. I suppose I could just parsec to that while on the couch or in bed and do my editing, with the main catch being that I need to use Windows shortcut keys. That or I wait until there's a decent deal on an M4 Mini with 10ge (there have been some solid deals, but they're always for the base model with only 1ge) With Parsec, the key is efficient H.265 (HEVC) encoding and decoding. On my 2020 Intel MacBook Air, I’m seeing decode times around 9ms at its native resolution. On the other end, the M2 Mac Mini encodes the HEVC stream in about 8.5ms. Over Wi-Fi (on the Air), network latency hovers around 4ms. Altogether, that gives me a total latency just under 25ms—well below the 42ms frame time of 24fps video. In practice, it’s totally usable and, to my eyes, indistinguishable from working directly on an M2 MacBook Air. Most Intel Macs from 2017 onward support QuickSync, which provides solid hardware-accelerated decoding. The real game-changer, though, is the vastly improved encoding performance on Apple Silicon, which makes setups like this feel snappy and responsive. When using Ethernet—even at modest speeds—latency drops further (often below 1ms). Parsec can stream H.265 video with variable bitrates up to 50 Mbps, which is trivial for gigabit Ethernet. It also supports 10-bit 4:2:2 streams, though honestly, I can’t see a difference on my aging eyes—especially when using high-DPI iMac displays. For me, Parsec solves three major problems: Reviving modest hardware — especially for tasks like video editing. Enabling near-instant resource sharing — with Thunderbolt providing a pseudo-network connection up to 40Gbps between Mac Minis. Letting me work remotely — from the kitchen table, for instance, while the main setup runs in the basement. When you pair Parsec with BetterDisplay, the experience is nearly identical to working on the host machine—if not better. In my case, the iMac’s high-DPI Retina display actually gives me a superior viewing experience compared to using the M2 Mac Mini with a standard external monitor. Unless you're using an Apple Studio or Cinema Display, it’s hard to beat the visual quality of 4K, 4.5K, or 5K iMacs. Interestingly, the 2017 iMac Pro isn’t the best choice as a Parsec thin client. It lacks both QuickSync and the T2 chip, which hurts performance. If you're going this route, a standard 5K iMac (2017 or later) is a much better option. eatstoomuchjam 1 Link to comment Share on other sites More sharing options...
eatstoomuchjam Posted July 28, 2025 Share Posted July 28, 2025 Oh yeah, most definitely true! When I used Parsec in the past, it was when I was playing around with game streaming and that's often more latency-sensitive than something like using my video editor, though I'll also need to see how it is for frame-perfect transitions/effects that I want to align to audio. But for me, the use case isn't to reuse underpowered machines to backhaul to another machine - my M2 Max is powerful enough for anything I want to do (though I'm likely to buy an M5 something after they're released since my warranty on the M2 will probably be up around then) and I can just pick it up and carry it with me. For me, it's more about putting the editor on something with fast access to the underlying storage. Even though wifi has come a long way, it still sucks, in my experience, for editing high-bitrate footage from a nas (proxies would help, I'm sure). I'd be likely to still do color (and maybe fine tune audio/video sync edits) with the laptop on a wired connection through the dock, but as a silly example, I did a 48 hour film project a few weeks ago and at some point, one of the people is hallucinating some burnt toast talking to him. We ripped a little mouth in the bread. For the 48, I just warped the image for the hallucination, but now that I'm working on the extended cut, I'm animating the little mouth to move with the words. I suck at vfx since I barely ever do them and don't like them much so it took me a bit over an hour to get the first 3-4 words done. The next clip has about 10-12 words. They should go a bit faster now that I figured out what I'm doing, but... still probably a couple more hours. I'd rather do that lounging on the couch while watching a movie at night vs hunched over my desk. Maybe Parsec is my shortcut for that. That and there's another part with a transition that I can't nail down to where I like it, would rather play with that while comfy on the couch too. John Matthews 1 Link to comment Share on other sites More sharing options...
Robert Patts Posted August 4, 2025 Share Posted August 4, 2025 Jump Desktop Connect is my app of choice for remote editing. John Matthews 1 Link to comment Share on other sites More sharing options...
