kye Posted June 30, 2025 Share Posted June 30, 2025 This seems like a simple question, but the more I think about it, the less simple it gets. Let's start out with the seemingly obvious answer - it looks like Super-16 because the sensor is literally a S16 sized sensor. End of thread, thanks for coming, byeeeee! Here are some thoughts suggesting it looks more like S35, or at least more than S16. Some are good arguments, some aren't, but summed up I think they're hard to dismiss. It appears sharper than S16, a lot sharper. Without getting overly technical, S35 has around 4K resolution, but the level of contrast on the fine details is quite low, and it's well known that by the time you print and distribute a 35mm film it really only looks like about 2K once it's projected in cinemas. This is perhaps the biggest argument for me - the P2K just looks like cinema did in the 90s. I know this isn't comparing a 35mm neg scan with the P2K files, but virtually all the memories of 35mm film that most people would have are from movies shot and distributed on film, not from viewing modern film scans. Lenses are much sharper now too, adding to it. S16 lenses were often very vintage! We have speed boosters, much faster lenses, and much wider lenses now. One of the looks of S16 was longer focal lengths and deep DOF, but if we were to use the P2K like we would use any other camera, it would be with speed boosters and faster lenses which would have much shallower DOF. The wider lenses we have now would be much sharper and faster too. So the lens FOV, lens DOF, and sharpness combinations would all be much more like S35 was, and perhaps even exceed it. How it's used would be much more modern. The framing, movement, lighting, locations and subjects also play a role in 'placing' a medium. This has probably changed less than the above arguments, and the things that any of us might shoot are more likely to still resemble things that I would associate with S16 (like FNW and TV and low-budget projects). I'm curious to hear thoughts from others. I've been reviewing my equipment and got to the P2K and thought "oh, it's a pocketable S16 camera" but my brain immediately added "that looks like 90s movies" and then I realised that these two things don't align! FHDcrew 1 Link to comment Share on other sites More sharing options...
Emanuel Posted June 30, 2025 Share Posted June 30, 2025 33 minutes ago, kye said: (...) Without getting overly technical, S35 has around 4K resolution (...) Equivalent to 3.2K to be more precise :- ) FHDcrew 1 Link to comment Share on other sites More sharing options...
