maxJ4380 Posted June 5, 2025 Author Share Posted June 5, 2025 Took the gimbal and e-m1 to a local lookout today. didn't get to the lookout part, as there's some huge rocks and a cave atmosphere thing happening at the base. The camera gimbal combination gets heavy pretty quick. Not surprising considering my fitness level. I have grabbed some stills from todays foray Its a couple hours later now and my shoulders feel like falling off. I may have to start doing bicep curls with gimbal and camera. I had the 17mm takumar fish eye on the e-m1. Also set it f8 out in the sun and set the focus to 4m or so in front of me. Bit annoying there are no filter threads, as i would have put a vari nd on it however back then it would have been a fish eye on full frame and its understandable that filter threads probably weren't considered, although with the m43 crop, the look is not nearly so wide however. Its quite narrow in places not much wider than shoulder width but opens up about 15 meters in. Its also a trip hazard trying to go though with a gimbal in hand. Rocks and tree roots all over the place. I did do a vortex shot looking upward. Actually i tried a few things, learnt a few things. I will go back with the 24mm sirui to see what sort of difference it makes and i'm kinda looking forward to seeing the comparison. I do notice a bit of side to side movement when walking but it doesn't bother me overly much as i figure some movement is natural when walking along a trail. Sure pans and tilts should be smooth however i am curious as to other peoples expectations are? I also think i need to change the motor speeds as it pans and tilts much quicker than i would like Link to comment Share on other sites More sharing options...
maxJ4380 Posted July 6, 2025 Author Share Posted July 6, 2025 Looking after my brothers place for a week, while he goes on holidays with his wife. I decided I'd do some unscientific observations with my assortment of cameras. I did take the e-m1 yesterday however it didn't quite go to plan. So i'll redo that before the end of the week. There's quite a few different animals to "shoot" hopefully you all get a bit of a different perspective for a bit. A frame grab from the iphone 13 pro max. i shot 4k then resized it to hd for convenience. I thought it turned out ok. Frosts tend to kill off the grasses, there's a bit of green around but not much. Link to comment Share on other sites More sharing options...
maxJ4380 Posted July 14, 2025 Author Share Posted July 14, 2025 Been on the look out for a yellow lens for awhile now. Some one said something down in the lens thread a while ago about a yellow lens , that got me thinking... Also i know there's two trains of thought with with photography / videography either do it in camera or do it in post. In most ways i like the in camera theory. Seems more authentic to me to do it in camera or more personal / intentional perhaps. In post seems more like an after thought to my way of thinking. Not wanting to rock any ones boat and if you like to do things in post that's great, please continue. Anyway finally decided on a lens, a super takumar 35mm f2. Should be a thorium lens from what i have read. So probably best, not to sleep with it under the pillow. I purchased this lens mostly with the intent of adding some warmness to an image / video. Not sure if the result will be a yellow or more sepia effect. There's a couple of images for your perusal. Should arrive before my birthday i hope. eatstoomuchjam and kye 2 Link to comment Share on other sites More sharing options...
maxJ4380 Posted July 21, 2025 Author Share Posted July 21, 2025 More blogging My lens has arrived, i think. Well before my birthday. Haven't opened it yet will do that later today. I would open it except its a pretty ordinary day here, overcast and a few drops of rain. I'd be more excited if it were sunny... The postie has done her normal thing and left it out behind the rose bush, apparently no one will notice it there. I guess she also assumes someone will pick it up before it rains... I got an andoer 50cm camera slider, it moves quite smoothly. I'm impressed with how solid / rigid it is, i wouldn't try standing on it, but for every camera and mount i have subjected it too, its been awesome . In hindsight i should have bought the 60cm slider as it would still fit between a doorway and i'd have an extra 100mm of travel. I tend to lose 45mm of travel from each side of center which is a bit annoying. The only issue i have had is when i mount it to a tripod within a minute of use the 3/8 bolt loosens and the whole slider can then swing in the breeze. Not exactly inspiring. To fix that issue i inserted a 10mm end mill into the drill press and cautiously milled some material away. There are two holes in both the mount and camera slider, neither match up. One is 3/6 and the other is 1/4 inch. The 1/4 inch hole got slotted as well which allows the holes to align. I previously have had to machine the front away as it was catching on the tripod somehow. If this doesn't hold it steady i'm not sure what else i can do. One of the first things i did, was to cut 100mm of a 600mm steel ruler, it fits snugly between the rails there's double sided tape holding the ruler in place. I dabble with animation and i figure it would help with consistency. Link to comment Share on other sites More sharing options...
maxJ4380 Posted July 25, 2025 Author Share Posted July 25, 2025 Never thought i had particularly large hands, however one gripe i have found (its a personal one) is when i grip the e-m1 my little finger tends to wrap underneath as the camera isn't tall enough. Not that i want to call the e-m1 vertically challenged. Its more of a me thing than a camera design issue. One of the reasons to get it was the mft form factor. Its just a little uncomfortable to hold after a little while. At the moment it lives with the ziyhun space plate on the manfrotto base plate and that seems to work ok. I don't seem to have any issues with the plates on the bottom, i don't seem to accidently hit at all and i can put pretty much any lens on it without fear of it falling over. I suspect one of those optional HLD-9 Power Battery Grips is in the near future for this camera and the gimbal should accommodate the extra weight. At the moment its about 50 % tripod time and then 50% hand hold. Its nice the space plate and base plate are out of the way of the battery door and its easy to change the battery without having to take something off. I did get a few photos with the super takumar 35mm f2 today and i'm quietly confident that i met or exceeded the mission brief of finding a yellow lens. i should also point out it was nearly 4pm and winter here, so the sun is low in the sky. From the left, straight out of the camera. For the middle shot, and to get back to a less artistic image, i took a grey point off the lavender as thats kinda grey, perhaps a little too blue ? I do like the colour of the dirt in the middle photo but i suspect the rest of the photo is a bit too cool ? which might come back on using the lavender as a grey point also the gerbera isn't as orange as in real life. I can of course massage things in post but that kind of defeats the purpose of the exercise. Plus its all subjective anyway lol. Third is from the iphone 13 for a bit of a comparison, the flower certainly is more orange, maybe it pops a little too much. I guess the iphone is doing some " magic " although i am sure the profile is set to normal. I think its kinda interesting how cameras / lenses interpret an image and then how humans interpret that result as pleasing or not. I'll also add i don't like to overthink it, more of a conceptual thought rather than a whole process. Next shot is taken at the same time and i threw it in as i thought there was abit of fine detail in it with the spider webs. After that the battery died. I was hoping to get it charged for sunset however i was a bit late and it was abit of a bland sunset as well. So far i am liking this lens, from the very limited time i have played with it, it behaves like i thought it would. I have a bunch more things to try with this lens yet. I doubt anyone else will buy this lens for the same reason i bought it. Most would buy it and stick out under the sun or uv light to clear away the colour cast. To me thats what makes it unique. I do have other takumars super taks and smc's and the 17mm smc on the desktop beside me is clear or almost clear of a colour cast. I'll have to check the others now ... The 17mm smc also has a filter wheel built in with a red, yellow, and clear, i remembered that only a couple of days ago... I should get some comparisons to satisfy my curiosity. Also its very much a mint looking lens and the focus works smoothly and aperture work nicely, i also bought one that had front and rear lens caps. After my first couple of takumars it began to annoy me that people will sell these lenses and ship them round the world without a front or back lens cap. I am confident i have always paid good prices for the lenses i have bought and honesty i think its just lame, that people cheapen out and won't put a cheap cap on it. I have a birthday next week, kind of ironic and depressing to think that i am as old or older than these lenses. These lenses keep working just fine, however my shoulder is starting to pack it in... 🙄 eatstoomuchjam 1 Link to comment Share on other sites More sharing options...
maxJ4380 Posted July 27, 2025 Author Share Posted July 27, 2025 Put the 17mm takumar smc back on the e-m1, as it has inbuilt filters. Thought i'd try those filters and apply some black and white effects. First is the clear filter / uv or your normal look. yellow filter changes things by about a stop of light and adds abit of yellow. last but not least is the red filter, loses three stops i think and delivers a full on Armageddon effect. These are photos from the em1. Grabbing stills from within resolve and doing b+w conversions on the image, they fell apart so quick. It was really quite disappointing. Next image is the original then a desaturated image which is kinda bland. Third is done through ps/ image / calculations and messing around with some of the options Finally is the finished photo which i think is visually a more interesting image compared to a desaturated image or plain greyscale. I think some of this comes from being inspired by mercer's lovely images and a little is lifted from the the lighthouse youtube break downs and some b+w youtubes i have watched. I was aiming for a darker moody look, i think its ok. Next is to replicate this process over in resolve with some moving images. Also my shuttle xpress has arrived and has been installed. You do have to go off to their website and download the drivers for it, however its not a large file. Once you restart your pc, you run a setup program thats also been installed and you can select from a menu which program/ programs you want to use it with. Resolve is listed, just have to scroll down abit. Not much weight difference between a mouse and the xpress, similar sizes as well. It seems like a tight little unit. No looseness in use. First button isn't programmed to do anything, 2nd button is reverse play, third is stop, fourth is forward or play, fifth is .., i forget it does something 🙄. The inner dial/ circle has a detent for your finger and makes rolling forward and backwards through footage, a rather lovely experience. It also makes stopping on the exact frame you want a breeze. The outer ring does jog through footage at increasing rates depending on how hard you twist it. I have to confess, i giggled like a five year old when i first fired up resolve and run some footage backwards and forwards. I suspect editing isn't supposed to be fun and the effect will probably wear of pretty quick. I also presume after using the contour express that all other controllers available from various sources add a measure of efficiency. Whether you can justify the cost vs the efficiency, that's the thing. Btm_pix recommended this down in one of the threads and i have to agree with him its a good improvement over a mouse, keyboard arrangement for editing. I have yet to try it with any other programs to see what other improvements can be realized. I got it on an amazon prime day, delivered for $125 Australian. Not cheap like a mouse, but then probably cheaper than some of the name brand items associated with video editing. Also i'd like to point out no affiliate links. nor are there ever likely too be... Now i'm off to bed, been an exciting day 🙂 mercer 1 Link to comment Share on other sites More sharing options...
maxJ4380 Posted September 6, 2025 Author Share Posted September 6, 2025 took the e-m1 and the sirui 24mm anamorphic to a car show today. here's a couple of images that i found interesting. I label the first, Oh the irony.. Clearly i wasn't the only one in a frivolous mood today... I wanted to get some car shots as my dad used to work on cars and race them. he's got Alzheimer's now, 94 and not out. He still remembers stuff. I'll make the photos up as a slide show, make the day a bit more interesting for a change, . It was a bit cramped inside not much room between cars, which is why i took the sirui anamorphic 24mm. Still a bit tight but thats ok its for me and my dad. Had to bump up the iso even then sometimes it was down a fifth of a sec which seem really slow. I presume the ibis must have done its job as most photos turned out ok. Wasn't till i hit a blurry photo that i thought about it much then when i did have a look, i came away quite impressed with the camera. i Did take a few panning video shots however my held held skills are very limited lol. One thing i will have to do is buy an extra battery as its fairly easy to flatten a battery in a couple of hours or less. Also been continuing with some Black and white. This would have been the takumar 17mm. I now have a orange filter that will fit the front of the 24mm sirui, so i want to give that a try next. Link to comment Share on other sites More sharing options...
ac6000cw Posted September 6, 2025 Share Posted September 6, 2025 8 hours ago, maxJ4380 said: One thing i will have to do is buy an extra battery as its fairly easy to flatten a battery in a couple of hours or less. My experience with E-M1 iii is that the battery life is pretty good (certainly compared to some Panasonic M43 cameras I've owned), but I would always take a spare battery with me if I was planning to shoot a reasonable amount of video. (That's a nicely kept red Citroën Ami on the left of the 2nd photo - brings back memories of the later Citroën Visa that my wife owned years ago, powered by a 650cc air-cooled 2-cylinder engine. At only 35bhp It was rather underpowered but that made it great fun to drive - just to make reasonable progress you had to thrash it hard and overtaking needed serious forward planning 😀) Link to comment Share on other sites More sharing options...
maxJ4380 Posted September 7, 2025 Author Share Posted September 7, 2025 8 hours ago, ac6000cw said: My experience with E-M1 iii is that the battery life is pretty good (certainly compared to some Panasonic M43 cameras I've owned), but I would always take a spare battery with me if I was planning to shoot a reasonable amount of video. (That's a nicely kept red Citroën Ami on the left of the 2nd photo - brings back memories of the later Citroën Visa that my wife owned years ago, powered by a 650cc air-cooled 2-cylinder engine. At only 35bhp It was rather underpowered but that made it great fun to drive - just to make reasonable progress you had to thrash it hard and overtaking needed serious forward planning 😀) Yes lots of nice cars on show. Made for a nice day, to get out and do something. i did think the camera did ok with battery life. As i would turn it on and off between shots. although i did lose time when people would wander through the frame and i'd have wait for them to wander out of frame. I noticed that increasing the iso made it harder for the peaking to work. Well thats my conclusion anyway. Luckily cars have lots of bright shiny parts to focus on. I'll get a second battery, probably have a look at a usb charger, if i can can find such a beast. My current car has a dual battery set up for when i go away camping, it would be nice to able to charge batteries off the grid. My drone can be charged from 12v and a few other things, i'm sure it can be done but i haven't looked into yet. Used to own a charade that had 990 cc engine, that thing could rev ... and you needed to rev it to get it moving. Not sure i ever passed anyone in that car. 1. I lived in suburbia at the time and 2. It felt like you really were taking life and limb into consideration when doing anything "courageous" Link to comment Share on other sites More sharing options...
ac6000cw Posted September 7, 2025 Share Posted September 7, 2025 6 hours ago, maxJ4380 said: I'll get a second battery, probably have a look at a usb charger, if i can can find such a beast 'Slow' USB chargers definitely exist (I use them myself) e.g. https://www.amazon.co.uk/JJC-Battery-Charger-Olympus-Cameras/dp/B08DR6BY2Z and https://www.amazon.co.uk/Ayex-Charger-Olympus-BLH-1-Batteries/dp/B07BSWH8QN Link to comment Share on other sites More sharing options...
MrSMW Posted September 18, 2025 Share Posted September 18, 2025 On 9/6/2025 at 5:51 PM, ac6000cw said: That's a nicely kept red Citroën Ami on the left of the 2nd photo I was going to say the same thing! My neighbour has a pale blue one but he won't sell it to me... Link to comment Share on other sites More sharing options...
maxJ4380 Posted November 9, 2025 Author Share Posted November 9, 2025 More blogging... So i bought an ipad 13 inch m3, i know there's a 4 out and the 5 is coming. Couldn't really justify the cost of the ipad 4 and couldn't be bothered waiting for the 5 and the cost of that little beastie. However i wanted something that had the " extra chip / processing on board for video" and the m3 has it i believe. Curious has anyone else got an ipad and what do they use it for ? Apart from a couple of pictures of some roses i haven't done much with it. Waiting for a cage to arrive to give it some protection before i let it out into the wild... Hard to believe this thing is only 5-6 mm thick. So far i'm pretty happy with it, but you'd expect that with any new toy.. Apparently it doesn't have the best screen apple make, but i reckon its still a very nice screen. Sooc er... Ipad i mean. I'm no pixel peeper apart from wanting to know what to expect. Thats about as far as i take it. Colours seem ok to me and there's some out of focus happening but that might be from the close focus i reckon but still pleasing i think. I can't watch much on the iphone 13 apart from some youtube occasionally or if i have just used the iphone to capture some video as its always in my pocket and convenient, sad but true. The Ipad 13 inch is much more watchable from my perspective, others may disagree. I got the 13 inch just for the extra screen real estate and so far I'm not disappointed. I initially bought it to help with reading sheet music as my music station has outgrown the desktop and is now 6 meters removed from where it used to live. I did consider adding a second screen run from the desktop. however its a beast of a computer and its overkill to run it just for music practice and i figure there's other options available that i can use the ipad for as well. May need to purchase one of those microfiber cloths, a cotton rag seems to struggle and leave lint or fibers. I also bought an extra small rig 17mm threaded adapter plate, i'm hopeful that i can mount to the cage i bought and attach some lenses for additional fun.. the neewer probe lens does an ok job for a camera phone, i mostly use it with the iphone 13 in a cage. Not impressed with the flaring but its manageable and it does suck up alot of light, but it is one third or less the price of a real "probe" lens. Link to comment Share on other sites More sharing options...
maxJ4380 Posted January 9 Author Share Posted January 9 Happy new year everyone, been a bit chaotic here. My mum fell over and broke a leg, Thats thrown a spanner in the works for the last 9 weeks. Things are slowly getting back to normal. Theres now 16 bits of metal holding here leg together, 17 if you count the drill bit that broke off inside... Had a bit of brain fade with the e-m1 iii battery. Somehow i ordered a bln-1 battery and dummy battery which is in the middle of the photo. e-m1 on the left and em10 on the right. which doesn't fit anything i have and i'm a bit disappointed with my self for messing that up. My second attempt at a battery was cancelled and refunded, however the stars aligned for the third attempt and i now have an extra e-m1 battery. Yay Another almost fail was buying a metabones speedbooster. It was an ex rental although it looks immaculate. My issue is there is no glass. Going back through the order it seems like i miss read the description. I can only presume i bought this late at night ... Still its well engineered great tolerances and rock solid on the camera. If i'm honest its a better mount than the other no name ef to mft adapter i have. So the hunt for a speed booster continues. Not sure if this counts as a xmas present, however a Zhiyun focus motor turned up yesterday I'm excited to get this installed onto the zhiyun gimbal, but that will have to wait till later as i have some fencing to do before it gets too hot. Link to comment Share on other sites More sharing options...
