Is Samsung shutting down their camera business?
I bought an A7rii as my primary still/video camera, however I'm going to trade my GH4 in for an NX1 I think! Use it as my backup/video camera. Seems to do everything the GH4 does but better, and it will fit on my beholder DS1 better than the GH4 with adapted lens ...I really like the look of those S lens - simply brilliant images and videos.
Link to post
  • Replies 1.1k
  • Created
  • Last Reply
Top Posters In This Topic
Popular Posts
There. I solved the ENTIRE problem.
You're funny. But... I think it all started when Andrew Reid put ZackGoodwin in a figure four leg lock over a Samsung 2/3 inch lens that Ed David thought was morally wrong to support. While Ebrahim ex
There's only selected markets left and the fact that even there accessories like the batteries are unavailable makes it quite likely that a global stop is imminent, just weird that they don't man up a
Posted Images
I am just doing Normal picture profile, sharpness down -5 but not all the way down, black levels all the way up in the main menu and 16-235 for the luma range. You can shoot 0-255 as well but on my Mac in Premiere it is clipped to 16-235 and you have to add the Fast Colour Corrector to fix the clipping, so easier just to change it to 16-235 in-cam and avoid the clipping issue.
Thanks for that ... will try these settings as well.
Been messing around with many setting looking for a close to SOOC nice natural look and found on these OK with a little adjustment after ... Standard (Normal Gamma)  ... Green = 95%, Saturation = -2, Sharpness = -10, Contrast = 0, MBL +10.
Not a bad OOC look I reckon. I just lowered the shadows a bit after to give it some pop. I love the colours this cam produces, but sometimes find the blacks look too inky and too black.
It's amazing the full size frame grabs you can get from this cam .. they look you were shooting stills :)
NX1.01.A.thumb.jpg.a70350539697bcb835d1cNX1.01.B.thumb.jpg.0f651b3c48529304ef5b1NX1.02.A.thumb.jpg.2ca4b531c26efc910f5b4NX1.02.B.thumb.jpg.c81214b379139aab6c637NX1.03.A.thumb.jpg.1188731439692cec49e66NX1.03.B.thumb.jpg.a8923490080ddb351e508
Link to post
Hey all, just wanted to ask really quickly which setting everyone uses in camera between 4K DCI and UHD. I have heard that you get more resolution (ironically) in the UHD setting. I even believe I might have read that posted by Andrew a while back. I didn't know if maybe that was a firmware issue that was later fixed or not, and wanted to get your guys' thoughts. Thanks.
Yes apparently, and it's not firmware, it's just that apparently the sensor 4K is actually 3840x2160 and it's just digital conversion somehow to produce 4096x2160.
I'm curious if the same is true for the NX500, which only offers 24p in 4096x2160. The native 3840x2160 is only offered in 30p on the NX500.
Link to post
OK now this is a real situation from a consumer that goes  to B&H at least once a month.. Every time I visit the samsung booth it's shoved in the back and only has a few cameras.. Theres also only 1 employee that acts like they dont want to be there..Everytime I speak to one of employees In the booth they new very little about the product and we're fiddling with there cell phone.. All the other camera booths had at least 4 employees that were very informative  and passionate about the products.. I have quit a few friends here in NY that are pro videographers and photographers and they all said if they showed up to a high end shoot with a samsung they'll be laughed out the door by there client..The only camera there interested in slightly is the sony a7s purely for its low light and that would be a b camera for certain situations.....just like beta was a better quality in video back in the day vhs won out...
Link to post
There is zero evidence for this, yet I see this stated everywhere, albeit with caveats like "apparently," "I read somewhere," and "someone told me." I've seen absolutely no difference in resolution between 4096 and 3840. Obviously shooting at 3840 at 23.976 is going to stress the codec a bit less than 4096 at 24, but the assertion that NX1 is shooting internally at 3840 and then converting to 4096 makes no sense as the sensor has a much bigger resolution than 4096 to begin with.
Link to post
Andrew,
Appeciate this info on firmware 1.4 settings. A question arises though. If you are using "Normal" picture profile, how do adjust sharpness? You can adjust it if in "Gamma DR" or "Gamma C, but not in "Normal". Also, on blacks are you referring to master black level at "0" or pushed higher? Lastly, are you still recommending backing off green to x0.95?
Link to post
The NX1 does shoot internally only to 3840 then up converts to 4096 horizontally and crops the aspect ratio vertically.
Samsung themselves told me this and all the resolutions tests verify this.
Can you point to these resolution tests? I wouldn't believe any word from any Samsung or other rep till we can actually see the evidence, they've been wrong too many times before. Doing a down-res to 3840 and then up-res to 4096 makes no sense to me.
Link to post
Well the photography thing is easy.  There is no system.  The lack of lenses has been mentioned multiple times in this thread.  Also it isn't full frame.  And of course the support network is lacking.  With Canon you can get it repaired in a lot of major cities and of course you can rent a Canon lens almost anywhere.
Actually it is the exact opposite of Beta.  Beta lived for years amongst pros long after it died amongst consumers.  And the NX1 could live years amongst amateurs long after pro photographers drive the final nail into its coffin.
Link to post
At the NX1 launch, DCI 4k mode was really soft in comparison with UHD mode. However, with the recents firmwares, it is sharper than before but possibly still upscaled.
DCI 4k :
5650aded0ed0a_SAM_8237.MP4_snapshot_00.0
UHD :
5650ae235bcad_SAM_8238.MP4_snapshot_00.0
Link to post
Thanks for that. Well, I just did a test to check it out for myself (firmware 1.40). Below are the original UHD and DCI frames, along with a comparison of the center of the frame, which I created by up-scaling UHD in Photoshop.
The DCI is in fact a tad sharper from the up-res version of UHD (meaning it's better than a simple in-camera crop/up-res from UHD). Still, I'm not claiming it is conclusive, and till we know for sure, people shouldn't be throwing around claims one way or another.
Link to post
NX1 is back on the market in Norway (JapanPhoto, didn't notice them leaving any other store) after their announcement of discontinuing sales (as mentioned earlier in the thread) - guess they sold well on discount (albeit still at a discount, lying at 7999 NOK (~870 eur))
Didn't really talk to any of the storeowners about the situation. Last time I did they implied samsung products were never sold, and that was the day before I picked up my NX1 from the same cashier. A PR-stunt perhaps? :p
Link to post
Nice deal!! 870 Euro for Body Only, Body + PowerZoom kit lens, or Body + S lens??
I'm a Samsung Engineer (computer, not camera!), curious how well they are selling now compared to our 'employee discount' price ;)
I can say that during the midst of all this rumor confusion the employee price has changed a few times -- adds to the confusion!
Link to post
Andrew,
If you choose "Normal" Gamma the camera will default to the "Picture Wizard" settings you have in the photo menu for the video settings. You can then adjust the standard settings the same way as you would the gamma settings.
Link to post
Then give us a custom software :)
Link to post
https://***URL not allowed***/lab-review-samsung-nx1-video-mode-frustrating/
http://translate.google.com/translate?u=www.slashcam.de%2Fartikel%2FTest%2FErste-Schaerfe-Charts-der-Samsung-NX1---Starker-4K-Konkurrent-.html&hl=de&ie=UTF-8&sl=de&tl=en
these two tests clearly show UHD is better, it's not just internet conjecture, it's been a known fact for awhile
Link to post
I have seen these tests, but both are quite old (December 2014). That was way back on firmware 1.10. Do we have any conclusive tests on 1.40? Many things have changed on the NX1 since these tests were conducted.
Link to post
Guest
Reply to this topic...
  Only 75 emoji are allowed.
