FS: BMMCC + Extras, Sankor 16c + Extras, Metabones Speed Booster, Canon FD
Matt Kieley
I'm clearing out a bunch of gear to make way for more gear, because I have a problem.
BMMCC + SmallRig Cage/HDMI Clamp + Sandisk Extreme Pro 64GB card (this is an older one that is compatible) + Wasabi LP-E6 battery + Lanparte LP-E6 DC Coupler (dummy battery), Tilta NP-F Battery Sled, DC cable. Everything is in great condition with a bit of cosmetic wear.
$600
Metabones BMPCC .58x Speed Booster Canon EF Mount (compatible with BMMCC and BMPCC Original/Super 16 sensors only) - Glass is clean and clear
$350
Canon nFD Lenses Converted to EF Mount (Declicked Aperture) - All fairly clean optically except a little dust. All fully functional with declicked apertures and smooth focus
Canon nFD 20mm f/2.8 with chipped metal EF Mount (Declicked Aperture) + Caps - $300
Canon nFD 35mm F2 with 3D Printed Nylon Mount from Shapeways (Declicked Aperture) + Caps
$200
Canon nFD 50mm f1.4 with 3D Printed Nylon Mount from Shapeways (Declicked aperture) + Caps
$100
Sankor 16c Anamorphic Lens + VidAtlantic Clamp w/ 52mm Ring + Metal Real Cap + Tiffen 52mm Diopters (+1, +2, +4) + Anamorphic Shop Custom Pressure Fit Clamp w/ 52mm Thread
Sankor has some sort of mark in the real glass. I;m not sure what it is (pictured), but I haven't noticed any issues in the test videos I shot with it. The focus ring is also very tight. It's still a usable lens with great optics, but be aware of the issues.
$250
Here's a test video I shot with the Sankor and BMMCC (with some Tiffen Diopter shots)
VidAtlantic Cinemorph Filter with Neutral Flare filament + Case + Cleaning Cloth + 52-58mm Step Ring)
$50
I'm getting the GH5. I just want something less fussy that I can use with minimal-to-no rigging/grading. And I like the idea of the Open Gate mode and the 4k Tele Crop that gives you a s16 image area so I can still use my c-mount lenses. Plus the high frame rate options. Although I'm keeping my FD lenses (I'm also getting the Mitakon focal reducer) and converting my 85mm f/1.8 and 24mm f/2.8 to EF mount to finish off the set.
  • 1 month later...
Guest
Reply to this topic...
  Only 75 emoji are allowed.
