dia3olik
FS Paralinx ACE 3G-SDI Wireless TX RX LEMO Kit + Accessories
Selling a nice wireless system.
It's the premium 3G-SDI version with Lemo 2 pin power inputs and connectors plus accessories.
All in very good conditions!
Asking price is 1150€
Included:
- Paralinx ACE 3G-SDI Transmitter
- Paralinx ACE 3G-SDI Receiver
- Paralinx AC Power Adapter 2pin Lemo version
- Paralinx Sony L-Series Battery Plate for ACE with Lemo 2pin
- Paralinx Custom Mounting Bracket for ACE
- Hawk Woods UK Lemo 2pin P-Tap Power Cable
Preferably selling within EU but I can ship WW with UPS.
Payment would be with IBAN transfer or PayPal (adding the fees).
Local pickup in Bologna, ITALY is of course possible.
56201158_10218763144650098_9007815483763720192_o.jpg.96e7b631af9e010e273a9c3c1d58d58e.jpg
56410032_10218763145450118_5912472088710479872_o.jpg.e7b954938e43b377fa1ab1b653920b7e.jpg
56523221_10218763144850103_6688649881134825472_o.jpg.7a1e203bde3d50c3ef6748b841a4de52.jpg
56447487_10218763144930105_7667668997445255168_o.jpg.5d84dc2f234b8573753d269eab950d54.jpg
55892397_10218763145370116_6268640480888619008_o.jpg.d14cab9c1325b9d03808ddd7f6775bfa.jpg
Share this post
Link to post
Guest
Reply to this topic...
  Only 75 emoji are allowed.
  • Similar Content
    • By EwanD
      We are selling our Paralinx Tomahawk SDI kit. Please see list of inclusions below + pictures.
      This downlink solution has been undefeated for over 12 months, and performed flawlessly on countless TVCs and feature films. Even when in and around extremely active and harsh RF environments, this has been one of our most reliable pieces of technology – connecting rapidly and maintaining link, up to amazing distances.
      Ask any VTR or DIT professional – they will attest to the remarkable performance of the Paralinx Tomahawk!
      The kit is in GOOD condition – aesthetically there are the odd blemishes, but internally, this system performs as well as the day we purchased it new.
      Please see images for condition.
      The Tomahawk SDI TX, RX, Array panel, power cables, case and accessories totals over US$8,300, so we will consider any reasonable offers around US$6,000.
      Please get in touch with any questions you may have.
      Thanks!
      Ewan Donnachie
      [email protected]
      +61 424 076 511
      Included:
      1 x  Tomahawk SDI transmitter w/stock antennas
      1 x  Tomahawk receiver w/stock antennas (dual-SDI outputs)
      2 x  D-Tap to 2-pin connector power cable
      1 x  Male JST to 2-pin connector power cable
      1 x  AC power adapter with 2-pin connector
      1 x  BNC cable (right-angle to right-angle)
      1 x  mini-USB to USB cable (for firmware updates only)
      1 x  Paralinx Array 5-input MIMO panel antenna
      5 x  N (right-angle) to RP-SMA cables
      1 x  Speed-Rail mounting bracket
      1 x  V-Mount battery plate (female) for easy mounting
      1 x  Tomahawk hard case w/custom foam
      1 x  Remote
      1 x  IR cable
      Product description, as per Paralinx website:
      The Paralinx Tomahawk has a range of up to 2000 feet (600m) with default antennas and still maintains an incredible sub 1ms latency glass-to-glass. Both the transmitter and receiver feature a 2-Pin power connector capable of a wide 7-17V unregulated input voltage. The Tomahawk SDI system features 3G-SDI input (with loop-out) on the transmitter and dual 3G-SDI outputs on the receiver.
      The Tomahawk transmits Full HD video (up to 1080p/60 4:2:2) with less than 1 millisecond delay and is capable of handling up to 4 simultaneous receivers. The transmitter weighs approximately 6.6oz/187g (without antennas) and the receiver weighs 12 oz/340g (without antennas).
      Tomahawk SDI features:
      Lightweight Minimalist design for Handheld, Steadicam, Gimbal, and UAV Payload
      Transmitter features 3G-SDI input and loop-out. Receiver features dual 3G-SDI outputs.
      Rugged machined-aluminum enclosure for the transmitter and ABS enclosure for receiver
      Ultra long-range transmission - Up to 2,000 feet (600 meters) *
      REAL-TIME viewing - Less than 1 millisecond latency
      Uncompressed full-HD video signal allow critically accurate monitoring
      Multicast capable (up to 4 receivers per transmitter)
      128 bit AES Encryption - Secure transmission
      Operates on 5gHz frequency band
      Conforms to major technical and environmental standards including FCC, CE, MIC (TELEC) and RoHS Specifications
      * Range may vary depending on environment and interference
      Dimensions (Tx): 4" x 2.5" x 0.8" (not including antennas)
      Dimensions (Tx): 108mm x 67mm x 21mm
      Weight (Tx): 6.6oz / 187g (without antennas)
      Dimensions (Rx): 5" x 5.6" x 1.3" (not including antennas)
      Dimensions (Rx): 143mm x 128mm x 33mm
      Weight (Rx):  12oz / 340g (without antennas)
      The Paralinx Array is a custom 5-input MIMO panel antenna designed for use with your Tomahawk Receiver to increase signal robustness (19dbi max boost). The Array works within the 5GHz spectrum (5.1-5.8GHz), and is small and lightweight with the ability to clip onto your Tomahawk receiver using the V-Mount battery plate (female) and a V-Mount male battery plate.
      Dimensions:
      13.78 x 13.78 x 1.25 in (35 x 35 x 3.18 cm)
    • By CoryB Photo
      BUY AS A SET- Like you Should-  FOR ONLY $510, shipping included.
      Sennheiser BodyPack Transmitter SK 100 G3, 516-558MHz.
      Price: $220.00
      Payment method: PayPal
      Item condition: 9+ Shows little or no signs of wear
      Shipping instructions: USPS or UPS only, my choice. Lower 48 only.
      Outstanding condition, used once. Wireless lav mic great for interviews and great for use with a digital recorder for better sound on your DSLR videos. So put that new DSLR that's under the Christmas tree to work making some great videos with the best sound possible!
      No paperwork or instructions or box or such included. Manuals available online Wireless lav mic included.
      Link to B&H description of product: http://bhpho.to/1bUo8pZ $297 new, here only $220 for a LIKE NEW unit! Photos on request
      Shipping included to lower 48 only, my choice of carrier and method
      Sennheiser BodyPack Wireless Receiver EK 100 G3, 516-558MHz.
      Price: $340.00
      Sennheiser BodyPack Wireless Receiver EK 100 G3, 516-558MHz. Outstanding condition, used once. Great for use with a digital recorder for better sound on your DSLR videos. So put that new DSLR that's under the Christmas tree to work making some great videos with the best sound possible!
      No paperwork or instructions or box or such included. Manuals available online.
      Link to B&H description of product: http://bhpho.to/1fqNbVQ $429 new, here only $340 for a LIKE NEW unit! Photos on request
      Shipping included to lower 48 only, my choice of carrier and method.
      Message me and includ email adress for photos, had trouble loading them here,
    • By Omar Abushaikha
      Hey guys,
      Check out this kickstarter of the Lenzhound Wireless Follow Focus by Motion Dogs. They just released their newest update and are desperately trying to reach their stretch goals in order to supply us indie filmmakers with the best possible gear!
      I think this is a fantastic product and I can see myself using it non-stop on sets, especially since I am still in film school and every bit of speed and perfection on set really goes a long way.
      Anyway what do you guys think about it, and if you like it try and spread the word so that these amazing stretch goals can be fulfilled!
      Thanks guys!
      LENZHOUND LINK: http://www.kickstarter.com/projects/...control-system
      UPDATE #4 LINK: http://www.kickstarter.com/projects/...8?ref=activity
    • By pdanford
      Hello,
      I am in search of a camera that I can use to capture live HD video at 24 fps.  I will not record the video onto the camera itself, but need to output it live from an onboard video connector (HDMI or SDI) then capture it downstream.    Most pro-sumer camcorders can record any common SMPTE size and rate to the onboard storage, but I can't seem to find one that will output true 24 fps video live from the onboard video output - usually the onboard can only do 1080i or 1080p @ 30/60.
      Is there a DSLR on the market yet that can do this?
      Thanks,
      pd
