Gujarish
Zooms & Anamorphic
Hello everyone,,
In the past, I've found the two usually don't go together. But if you search hard enough, a sharp zoom can cut it. First test I shot using the Anamorphic Shop's Focus Module with a Schneider Cinelux MC and a Nikon 35-70 f3.5 on the a7s. ClearImage zoom was set to 1.3 to avoid vignetting across the full focal range (full coverage on MTF it seems). Most of this was shot wide open on the lens. Just sharp enough for my tastes. Hopefully in the coming days I'll get a test out using the 80-200 f2.8.
Share this post
Link to post
19 hours ago, Gujarish said:
Hello everyone,,
In the past, I've found the two usually don't go together. But if you search hard enough, a sharp zoom can cut it. First test I shot using the Anamorphic Shop's Focus Module with a Schneider Cinelux MC and ovo.fyi/xvideos/ ovo.fyi/xnxx/  ovo.fyi/chaturbate/ a Nikon 35-70 f3.5 on the a7s. ClearImage zoom was set to 1.3 to avoid vignetting across the full focal range (full coverage on MTF it seems). Most of this was shot wide open on the lens. Just sharp enough for my tastes. Hopefully in the coming days I'll get a test out using the 80-200 f2.8.
Thank you my isuue has been solved,.....
Share this post
Link to post
On 1/24/2019 at 10:13 PM, Gujarish said:
Hello everyone,,
Looking forward to the test 😍
Share this post
Link to post
Guest
Reply to this topic...
  Only 75 emoji are allowed.
