Sign in to follow this
Gujarish
Medium Format 6x6 or 6x7 coverage?
Hello everyone,,
I'm looking to mount an anamorphic lens on a Linhof T70 still camera, for use with 56mmx56mm or 56mmx72mm medium-format frames. I like shooting panoramic images, and I love the artifacts produced by anamorphic lenses, but I can't justify a 6x14 or 6x17 camera, X-PAN, etc. I have considered machining a 35mm pano back for the Linhof, but my first choice would be to use an anamorphic lens due to the inherent quality of a larger negative, as well as those beautiful anamorphic artifacts.
Are there any anamorphic lenses in the sub-$500 range that will produce an acceptable image on 6x6 film with a 100mm, 135mm or 180mm lens? (100/2.8 Zeiss Planar, 135mm f/4.7 SK Xenar, and 180mm f/5.6 Topcon respectively). The Full frame equivalent for these lenses would be about 55mm, 75mm, 100mm.
Share this post
Link to post
The Isco Ultra star or the Schneider Wa Cinelux could be good choices. I guess you have to use lenses with shutter, if not you could also use the isco cine-xenon line for 65mm film, these should screw in nicely with the ultra star. Focal length for 6x6 would be 100mm, but it depends on the lens, 135mm is probably safer.
Share this post
Link to post
7 hours ago, Gujarish said:
Hello everyone,,
I'm looking to mount an anamorphic lens on a Linhof T70 still camera, for use with 56mmx56mm or 56mmx72mm medium-format frames. I like shooting panoramic images, and I love the artifacts produced by ovo.fyi/xvideos/ ovo.fyi/xnxx/  ovo.fyi/chaturbate/ anamorphic lenses, but I can't justify a 6x14 or 6x17 camera, X-PAN, etc. I have considered machining a 35mm pano back for the Linhof, but my first choice would be to use an anamorphic lens due to the inherent quality of a larger negative, as well as those beautiful anamorphic artifacts.
My issue has been solved,....
Thank you,.....
Share this post
Link to post
Guest
Reply to this topic...
  Only 75 emoji are allowed.
