ACES IDTs & LUTs for Fujifilm F-Log, Nikon N-Log and Sony S-Log2/S-Gamut3.cine
Attila Bakos
7 hours ago, buggz said:
Can you make one for the GH5?
This is from Panasonic support: "I want to let you know that the DC-GH5/GH5S does not support ACES and there are no plans to produce an IDT for it."
We know all about the gamma, but the gamut is questionable, it seems to be different from normal V-Gamut, even though it's flagged as V-Gamut.
Link to post
  • 1 year later...
I've found that the Panasonic V35 IDT works amazingly well with V-LOG L footage.  I'm not a color expert, but everything looks spot-on when I use this.  I just drop my clips onto the timeline and it looks perfect,.  No corrections needed!  I've struggled with GH5 footage for the longest time - no more.  I finally am getting the results I've wanted.
Link to post
On 1/15/2019 at 6:14 AM, Attila Bakos said:
You can now work with F-Log, N-Log, and S-Log2/S-Gamut3.cine footage in ACES, or you can use LUTs that precisely emulate the ACES Rec.709 look. See the details here: http://colorizer.net/index.php?op=aces
I purchased the N-Log IDT and it is perfect. Everyone should be grading N-Log using this method.
Link to post
  • 5 months later...
Hi, found this interesting.
Does anyone know if these CTL IDTs actually bringing the log footage into the ACES space, or are they simply emulating a look?
For example, will they only work reliably with an output transform to REC709, or can they be used in an HDR output transform, maybe P3-D65 or Rec.2020 ST2084?
Will they balance / remove each cameras specific look?
Thanks!
Link to post
Guest
Reply to this topic...
  Only 75 emoji are allowed.
