Fotga DP500 III Follow Focus [90 gbp]
  • Brand: FOTGA
  • Model: DP500 Mark III Follow Focus
  • Material: Sturdy Metal CNC Machined.
  • The weight of DP500 Mark III Follow Focus has been reduced by nearly 16% (Compare to DP500IIS version) , leading to a lighter system and more portable.
  • Newly design on its inner structure to reach a high level in this field, while the damping gives virtually zero backlash(<0.5mm).
  • Long-life precision engineered gearbox enables accurate and reliable focusing.
  • The damping adjustment knob below can adjust the tension of the gearbox to reach 2 dampen levels.
  • Heat resistant engineering rubber handwheel, it touches comfortable, especially in cold weather
  • Drive gear can be mounted from both side. (Works for both right-handed and left handed)
  • Drive Gear Interface: Compatible with JTZ X Type Interface Standard.
  • Can use different size gears to meet your need with different lenses. This updated version is designed to fit for 5 size gears. (M0.8-38T/M0.8-43T/M0.8-65TM/0.5 78T/M0.6 64T ). We will default to ship the M0.8-43T if not specific.
  • Compatible with industry standard 15mm rods.
  • Rail distance: 60cm
  • Rail diameter: 15mm
  • Net weight: 340g
  • Suitable for: All DSLR cameras, Video cameras, Interchangeable-Lens cameras.
Package including:
  • Fotga DP500 Mark III follow focus
  • 1x 0.8mm matching gear belt x 1 (please note that it has been shortened for Sigma 30mm f1.4)
  • M0.8-43T gear x 1 (already installed on the follow focus)
Condition:
The follow focus is like new, used on one gig, so there is only one microscratch on the 15mm rod adapter, otherwise perfect condition. The follow focus turns smoothly, there is a knob for adjusting the wheel sensitivity as well. Please note that since I was not using the follow focus it's box got a bit ugly by the time so it might be not ideal as a gift.
Price fo EOSHD members: 90 GBP + shipping. Payment through TransferWise or PayPal (but then you'll pay the transfer fee).
Buy with confidence! Not happy the product? You can return the item in 7 days.
Shipped from EU, Slovakia to the countries of European Union.
Link to post
  • 4 weeks later...
  • 2 weeks later...
Guest
Reply to this topic...
  Only 75 emoji are allowed.
