Sign in to follow this
Liszon
Manfrotto 510 Fluid Head for sale!
Manfrotto 510 fluid head: 8.8-19lb load capacity (3.9kg-8.6kg) well made, solid construction, blows most of the entry level crap out of the water.
3 step tilt drag, variable balance spring, 100mm bowl.
Full specs here: https://bit.ly/2ty2vPH
Perfect mechanical condition, haven't seen much action, barely any paint loss.
Comes with two pan handles, one is missing the R190.20 locking lever, fortunately Manfrotto stills sells the 116.124 lever itself and you can get the bolt/washer/spring in a hardware store. The other handle is complete.
Rosettes show almost no wear, nothing broken.
The plastic cover on the tilt adjustment knob is a little tattered, it's a removable sticker anyway so I never bothered to replace it. If you ever need one Manfrotto sells that as a part of the R510.20 replacement kit.
No leaks, no creaks, smooth movements, everything works as should.
Price: £220+shipping or local pick-up in Southgate, London.
Share this post
Link to post
Guest
Reply to this topic...
  Only 75 emoji are allowed.
