Geoff CB
GFILM: An easily graded Flat Profile for Sony Cameras
10 hours ago, Gregormannschaft said:
Just wanted to add a 'thanks' in here. Just got back from a holiday in Sri Lanka using the GFILM settings (except with S-Gamut3.cine instead of Pro) and I'm loving the result. Examples below are graded, but they were still the easiest to grade I've ever had with the camera and the original footage looks lovely straight out of the camera. It reminds me A LOT of what I was getting color-wise, from the 5D Mark III and the Technicolour Cinestyle profile.
I'm very glad I had even a small part in the creation of these images. Incredible work Gregormannschaft and I hope it continues to work well for you!
On ‎12‎/‎14‎/‎2016 at 3:14 PM, Mason said:
I would like to point out that the FS7 needs to stop being included with these profiles. The paint menu is totally different than the FS5. The menu on the FS7 is more like the F5, so there is no setting color mode. Try to get your hands on one to see what I'm talking about. I would love to see if there is a way to set up a profile like this on the FS7 to get quick turn around for simpler videos. Has anyone else had this problem?
I'll remove it from the main page, I made the assumption it was similar to the FS5.
Share this post
Link to post
7 hours ago, Nrubloc said:
@Gregormannschaft
Was just wondering which Sony camera you used for the India footage. Also curious if you did a custom WB for each scene or just used a predetermined WB for daylight conditions which was possibly already stored as one of your saved custom WB settings. I haven't had a chance to try out the GFILM profile yet, but plan to do so over the holidays.
I'm using Sony A7SII and for white balance 99% of the time I used the Daylight option in the WB menu. Annoyingly though, I found that even in direct sunlight, dropping the WB by -11 in Premiere's lumetri panel normally resulted in a better balanced picture, so maybe take that into account when filming.
Share this post
Link to post
Oh, I should also add what I've done in post. I actually processed the footage with FilmConvert first, using the Arri camera profiles and then making finer adjustments with Lumetri. Geoff's original approach of playing around with curves also works sometimes, but when the white balance was off it resulted in some whacky colours - purely my fault.
Share this post
Link to post
Yeah Gregor these look great. I used sgamut3cine color with my tests of the 6500 yesterday... I think this and GFilm is a winning combo!
Share this post
Link to post
9 hours ago, mercer said:
@Geoff CB Do you change the knee settings based upon location or lighting conditions, or have you found that this is a good average for both interior and exterior?
I tend to leave it the same for both indoor and outdoor.
Share this post
Link to post
Good to know, thanks. I will be testing your profile sometime this week. Have you, or anyone else you know of, attempted to find a good knee setting to use with slog3 to try and elimate some of the banding issues? I'm unsure if a tweak would even fix it, but I am hoping it will because slog3 looks great with scenes that require that little bit of extra DR... as long as there's not a lot of sky in the frame.
Share this post
Link to post
Not sure about knee settings, but a few folks were talking a while back about how boosting the saturation to around +20/25 helps - not sure if that was just a little wishful thinking or if it really has an effect, I haven't tested it.
Share this post
Link to post
Thanks Gregor, I'll give that a try.
Share this post
Link to post
Even try lowering the black gamma. Helps to make better use of the codec as well by not loosing any of the nice highlight rolloff!
Share this post
Link to post
Thanks but stupid question to clarify... if I remember correctly, - Black Gamma increases contrast and + Black Gamma decreases it? I read the Sony papers in their settings but I decided to go default with my first test.
Share this post
Link to post
3 minutes ago, Ki Rin said:
I'm not seeing this option on my camera.. Was this added as a firmware update?
I don't think so. Did you go into the slog3 settings and then look under color?
Share this post
Link to post
Where can you do that?
Under picture profile>gamma> there is slog2 but no slog3.
Under color mode> is S-Gamut.
I can't find slog3 anywhere.
On A7RII firmware 3.20
Share this post
Link to post
Oh I don't know if A7Rii has it, I have an a6500. Sorry.
Share this post
Link to post
Only the A7SII has the Slog3.cine gamut. I'd go with Pro instead.
Share this post
Link to post
My profile is for S-Log 2. NOT S-Log 3. The A7r II does not have S-log 3 or the cine gamuts. The Cine gamuts other people are experimenting with. I just use the Color Mode: PRO.
Share this post
Link to post
Some test shots of a slightly modified GFilm with the RX10ii. I tested with some high contrast shots to see how it would hold up. I see a little banding, but it isn't too bad.
Does anyone know if Sony tweaks the basic SLog2 depending upon the sensor?
Share this post
Link to post
Guest
Reply to this topic...
  Only 75 emoji are allowed.
