FS: 2 GTX 960 4GB, $130 Each
Geoff CB
Hello fellow editors. Selling my GTX 960 SSC 4GB cards that I had in SLI. Upgraded my GPU so I don't need them anymore, pricing them to move. These can handle 4K editing from Sony and Panasonic consumer cameras.
Shipping included for U.S. lower 48 states.
Buy both for $225
Guest
Reply to this topic...
  Only 75 emoji are allowed.
  • Similar Content
    • By Wit
      I'm working on a new project. It's for an organization who uses internet platforms for interaction around their product. So my promotional film for them will include some of this interaction on screen.
      - What is the best way to do it?
      - Using a Screen Recorder? If so which one is good on a Mac and using with MOV footage?
      - Anny useful tips around these kind of shots?
      Thank you so much!
    • By Matthew Marshall
      Ive been looking for a particular piece to customize my rig. I dont know if it exists so I figured i'd post here in case anyone has run across it.
      Basically it connects 2 15mm rods in parallel on the top and bottom. Except the second set of 15mm rods I need it to swivel. So probably two 15mm rod pieces with swivel action so it can be placed at different degrees of angle.
      Basically like this item.
      http://store.redrockmicro.com/Catalog/mountinggear/microMount
      Except with the right ring parallel to the left and able to rotate to a 45 degree angle.
      Im trying to mount my vmount battery plate at a 45 Degree angle from the back of the rig on 15mm rods.
      Any help would be appreciated thanks!
      Edit* found this as a better example.
      http://www.amazon.com/Lanparte-Battery-Internal-Splitter-External/dp/B00ARABA9I/ref=sr_1_1?s=photo&ie=UTF8&qid=1393126744&sr=1-1&keywords=lanparte
      Basically what this does but I already have the plate and I want an additional set of 15mm rods parallel to the plate itself.
    • By QuickHitRecord
      As of tonight, the new iMacs are finally officially available for ordering from the Apple store. The maximum configuration looks something like this:
      [list]
      [*]3.4GHz Quad-core Intel Core i7, Turbo Boost up to 3.9GHz
      [*]32GB 1600MHz DDR3 SDRAM - 4X8GB
      [*]768GB Flash Storage
      [*]NVIDIA GeForce GTX 680MX 2GB GDDR5
      [/list]All for about $4,500.
      Opting for 8GB of RAM (to upgrade later) and a 3TB Fusion Drive instead bring the cost down to about $3000.
      Also, the Cubix Xpander is an external peripheral that allows for the use of second GPU, and the 10GB/s Thunderbolt connection allows for additional drives to be hooked up externally -- including the 12TB Thunderbolt RAID.
      This all sounds impressive, but how future-proof (i.e. ready for the next five years) is this setup? I suspect that it can handle 4K ProRes, but what about 4K RAW (and Davinci Resolve)?
      I have also been communicating with a custom PC builder on eBay who is going to spec out a workstation specifically designed to work optimally with Adobe CS6 and Davinci Resolve 9. I'll post the results of that when I get them.
